Old 04-12-2007, 03:20 AM   #1
that one legacy
Member#: 103665
Default BG/BK/BD front sway diameter
yeah, so i've been searching for like 3 days now on like three different forums, and can't find the info i'm needing. so, does anyone know what the front sway bar diameters are for:
'95-'99 Legacy L
'97-'99 Legacy GT
'97-'99 Legacy Outback
'97-'99 Legacy Outback Limited (if different from normal Outback)
the reason i ask is that i upgraded to the 18mm Outback rear sway a few days ago, and now i'm searching for the ideal front counterpart. i read somewhere that the GT front sway bar might be a bit thicker than the stock one on my L, but i can't confirm that. the fact that the GT has a smaller rear sway than the Outback also has me really confused.
so anyway, if anyone knows the answers, or can point me to where i can find them, i would be most grateful!
that one legacy is offline   Reply With Quote
Old 04-12-2007, 03:24 AM   #2
Kraziken
Member#: 38629
1999 Legacy GT (STI)
'95-'99 Legacy L
'97-'99 Legacy GT
I'm not sure what the L is, but I believe the GT front swaybar is 20mm.
Kraziken is offline   Reply With Quote
Old 04-12-2007, 10:26 AM   #3
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I measured the L and it's 22mm with paint...so 20mm?
Wiscon_Mark is offline   Reply With Quote
Old 04-12-2007, 08:08 PM   #4
that one legacy
Member#: 103665
sweetness, thanks for the replies guys! anyone with a later year BG Outback care to measure their front sway bar for me? preferably before saturday morning?
Old 04-12-2007, 09:47 PM   #5
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
I know for a fact that the GT is 20mm. Mine is a MY97, and I measured it with calipers. I also ordered some whiteline bushings for a 20mm bar, and they were a perfect fit!
morrocco88 is offline   Reply With Quote
Old 04-12-2007, 10:49 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
(a) Your measuring device isn't very accurate, and
(b) How frickin' thick do you think paint is?!
Pat Olsen
'97 Legacy 2.5GT sedan
Old 04-12-2007, 11:12 PM   #7
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
whenever i try to measure sway bar diameter i use wrenches......18,20,21 whatever. the outback and GT IIRC have a 18mm rear sway, but you can always get the whiteline adj. rear sway..goes up to 21 or 22 mm. i think its 18,20,22 adjustable. i know my stock rear sway was 15mm!!!!
Old 04-12-2007, 11:54 PM   #8
Sub_Speed_Guy
Member#: 25007
2004 WRX
OEM +
The GT doesn't have a 18mm sway in the rear. I think it's more like 16mm.
Sub_Speed_Guy is offline   Reply With Quote
Old 04-13-2007, 12:19 AM   #9
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Pat Olsen
heh, you're probably right, but with all the rust/paint, I wasn't sure what the diameter was, you know it tends to flake out.
I didn't think the front bar was that thick, but I suppose it was possible...
Old 04-13-2007, 12:56 AM   #10
that one legacy
Member#: 103665
hmm, well if mark's measurements are anywhere near accurate, it looks as if the GT and L have the same front sway, but the L has like a 14mm rear, the GT has a 16mm rear, and the outback has an 18mm rear.
Old 04-13-2007, 01:40 AM   #11
ballitch
Member#: 74907
98 cam'd EJ251
so thats why our cars understeer....hmmm.....
~Josh~
Old 04-13-2007, 01:45 AM   #12
that one legacy
Member#: 103665
tell me about it. i remember not too long after i got my car, i went tearing through an empty parking lot just to see what it was capable of, and damn...even my old civic never understeered like that!
Old 04-13-2007, 10:14 AM   #13
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Well, most Subaru owners don't want oversteer...understeer is much less dangerous for a driver who doesn't know what they're doing. It's much harder to induce oversteer in a Civic.
Old 04-13-2007, 02:40 PM   #14
that one legacy
Member#: 103665
not in an automatic DX civic with a non vtec D15B7 it isn't. that car was understeer city!
Old 04-14-2007, 02:59 AM   #15
that one legacy
Member#: 103665
OKAY, may have finally found the answer.
according to prostreetonline, OEM bushings for the '95 Legacy L are for a 19mm bar: http://www.prostreetonline.com/oem/w...ay+Bar+Bushing
bushings for the '98 Outback are for a 20mm bar: http://www.prostreetonline.com/oem/w...ay+Bar+Bushing
and they don't list the size for a '98 GT, but we already know that's a 20 mm.
now the question is, is it worth paying another $50 just to get a 1mm thicker front sway bar?
Old 04-14-2007, 04:04 AM   #16
ballitch
Member#: 74907
98 cam'd EJ251
nope......buy an aftermarket bar. or dont buy any bar at all.
Old 04-14-2007, 02:42 PM   #17
that one legacy
Member#: 103665
explain please...
Old 04-14-2007, 06:17 PM   #18
linsavy
Member#: 11620
1997 GF4-STiV3 clone
The above is all correct.
I run a 22 front and 22 rear in my 99GT wagon. It's good.
linsavy is offline   Reply With Quote
Old 04-14-2007, 11:18 PM   #19
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
explain please...
It's not worth the upgrade to the GT. Look aftermarket, or just leave it.
Old 04-15-2007, 01:51 AM   #20
oncesir
Member#: 141793
02 WRB WRX Wagon
Sorry to kind of threadjack but, did you notice any difference with the Outback RSB? Is your Legacy an L or GT? TIA
oncesir is offline   Reply With Quote
Old 04-15-2007, 03:47 AM   #21
that one legacy
Member#: 103665
what i'm looking for is if anyone has any concrete numbers on the spring rates (or torsion rates as it might be) between the 19mm L bar and the 20 mm GT/Outback bar. 1 mm might not seem like much, but it actually could make a significant difference depending upon the design of the bars themselves.
Old 04-15-2007, 03:51 AM   #22
that one legacy
Member#: 103665
i actually do notice a very significant difference with the outback RSB on vs. my stock 14mm one. the turn-in is a lot crisper, the rear end used to feel like it was dragging along behind me when turning, but now i actually have to catch myself because the rear end rotates a lot better. i don't have any actual numbers or any scientific evidence to provide, but i can honestly say that the steering feels a lot better, and the suspension itself just feels more solid now. would it have been better to just go with a bigger aftermarket bar? maybe, but i'm not tracking this car, so i figured $50 for a 4mm increase in sway bar diameter was a good investment.
keep in mind though, that i am running on '04 STi springs and shocks, and have been desperately in need of an alignment for months now!
i think i am going to get that outback FSB just to see how it feels, see if maybe it'll make any discernable difference. after that, the next mod will be poly bushings all around, then i should notice a real difference.
Old 04-16-2007, 06:28 PM   #23
linsavy
Member#: 11620
according to this chart it is 23% stiffer http://www.northursalia.com/techdocs/sway/sway.html
My wife never noticed when I put on the 22mm bars. I drive it in the snow like that too. No problem.
Old 04-18-2007, 04:56 PM   #24
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
After installing my Outback RSB my friend said it was the most fun he had had in a car in a long time. Reason was, was that after it had rained, I could powerslide through intersection turns like crazy. You get alot quicker response and definately go into oversteer more readily.
Plays_With_toys is offline   Reply With Quote
Whiteline 20mm front sway bar for BD/BG/BK - $17.43 + shipping Patrick Olsen Legacy Specific Parts 15 10-30-2009 10:54 AM
serious question about hoods BG/BK/BD or BE/BH spdracr00 Legacy Forum 69 01-20-2008 01:16 AM
FS: JDM BG/BK/BD short grill (green emblem) that one legacy Legacy Specific Parts 2 01-22-2007 08:45 PM
Has anyone opened a set of BD/BG/BK headlights? subysouth Legacy Forum 5 12-10-2005 03:09 AM
A little something for the BD/BG/BK owners iON Performance Inc Legacy Forum 22 11-30-2005 02:32 PM
