Old 04-12-2007, 01:14 PM   #1
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Default Return to turbo water pump?
Not sure about the wrx water pump, but im guessing its the same as the ej22t one, as far as the oil cooler line on the back side of it. right now i have mine plugged since im not using an oil cooler, but when i upgrade to ej22 na heads coolant return is going to be an issue. I will probably wind up t'ing off the manifold lines but I was wondering if I could just run a line to the water pump instead via the oil cooler return?
more importantly, has anyone done this?
mxpunk is offline   Reply With Quote
Groing from NA Legacy Water Pump to WRX Water Pump lgt2000 Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-25-2007 10:38 AM
Ej20G Oil Cooler / legacy turbo water pump / oil pump supermoose Private 'For Sale' Classifieds 2 09-29-2005 01:06 PM
Legacy Turbo Water Pump/housing White 2.5rs Private 'Wanted' Classifieds 1 10-22-2003 02:19 PM
EJ Turbo VS EJ non Turbo water pump DJIMPREZA Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-29-2002 04:36 PM
WRX Chronicles - Return to the Water Temple AVATAR-X Bay Area Impreza Club Forum -- BAIC 0 09-21-2001 11:01 PM
