Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 12-12-2001, 05:07 PM   #1
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Default Quick Water Pump Question
Do water pumps make any noises before they fail and begin to leak coolant? When I changed my oil last, I noticed the coolant resevior was down very slightly. The past few days I swear I've smelled coolant when I first enter my car.
I've also noticed at idle a soft "squeaking" sound that tends to disappear after the engine is up to normal operating temperature. Could this squeaking possibly be my water pump? The car has 101K miles with the original pump, so it is probably due to go sometime soon.
Thanks in advance
AJ
BJamerican is offline   Reply With Quote
Old 12-12-2001, 05:50 PM   #2
motorob
Member#: 2878
06 Evo IX MR
I doubt that the squeaking is related but you never know. The best thing for you to do is have your cooling system pressure tested, that will tell you where the coolant is going. There are a number of other possibilites besides the pump, including but not limited to: leaking hose, leaking heater core, leaking raditor, headgasket, etc. etc. Another thing to keep in mind is that it can be good practice to replace timing belt driven water pumps along with the timing belt (as you MAY be about to discover the hard way.) You should have replaced your t-belt at 60K, and will need to again at 120K. You have to remove the belt to replace the pump if you do it now at 101K. Since the pump only costs c.$60-80 (I'm guessing..) and labor for the t-belt R&R alone will be more than that, not replacing timing belt driven water pumps at the timing belt replacement is false economy IMO.
motorob is offline   Reply With Quote
Old 12-12-2001, 09:52 PM   #3
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
My fiance just had her timing belt and water pump done on her Legacy Outback. The dealership did not charge any labor for the water pump, only parts, as all the work with removing the timing belt was already done. If I remember right, the guess of cost of $60 - $80 is about right. Saved a chunk of money.
Keith99RS is offline   Reply With Quote
Water/meth injection water pump question atomic4877 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 09-24-2009 05:29 PM
quick water pump question darkmist2k1 Subaru Conversions 5 10-02-2006 11:43 PM
Water pump question Rocketcar Service & Maintenance 1 01-28-2006 02:41 PM
timing belt,water pump question. help WRC STYL Service & Maintenance 0 01-09-2003 06:43 PM
water pump question IggDawg Normally Aspirated Powertrain 4 07-08-2002 07:47 AM
