Old 04-13-2007, 05:01 AM   #1
BlackSTI2006
Member#: 105404
2006 FPGreenSTI SOLD
04 GMC 2500HD Duramax CC
Default Perrin Big MAF-Open Ecu/Enginuity Help
Does anybody have the info on rescaling the MAF for the perrin Big MAF intake?
I am upgrading to Fp Green 2.4" inlet, 7cm housing, iwg. Going with fuel pump, one step colder plugs, big maf,perrin turbo inlet,and 816cc modded stock injectors.
Anyone got a good base map for me maybe?
Just looking to see if anyone has the info for rescaling?
BlackSTI2006 is offline   Reply With Quote
Old 04-13-2007, 02:00 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
it's funny you brought this up because i was talking to a guy about this last night. I have a copy of his map on my laptop(which broke while we were working on it) and we noticed that the MAF was scaled kind of odd. I was wondering if anyone else has got a map for a Big MAF that it could be compared to.
Jeremy
Old 04-13-2007, 04:48 PM   #3
WeldingHank
Member#: 98645
2002 WRX Wagon
multiply the map by 1.1459. tune accordingly from there.
WeldingHank is offline   Reply With Quote
Old 04-13-2007, 05:36 PM   #4
darthvader666
Member#: 145879
I had lots of troubles with the Perrin big MAF. The pipe starts to heat up from the engine bay heat which causes it to go soft and change shape, causes all sorts of funky MAF problems. In the end I gave up and we used a solid pipe instead. Even back to back MAF logs were not consistent. Just my 2c.
darthvader666 is offline   Reply With Quote
Old 04-13-2007, 09:39 PM   #5
BlackSTI2006
Member#: 105404
On an FP Green 2.4" inlet, 7cm, iwg with perrin turbo inlet and front mount, should i go with big MAF or keep my k&n tyhpoon?
Old 04-13-2007, 11:25 PM   #6
WeldingHank
Member#: 98645
2002 WRX Wagon
I woud say so, the stock MAF tops out at 300 G/sec. The Green is more than capable of flowing that much air and more.
edit: did a little digging for you, the green is capable of flowing up to 48lbs/min. Which equates to about 362 g/sec
Old 04-14-2007, 04:14 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
mulitply which map? the fueling map?
or are you talking about the MAF Scaling?
Old 04-14-2007, 06:25 AM   #8
TheMadScientist
Member#: 23717
2005 Big red
You will be chasing MAFV dips and spikes forever. Good luck.
TMS
TheMadScientist is offline   Reply With Quote
Old 04-14-2007, 10:41 AM   #9
jays05
Member#: 78165
05 STI 35r + e85
I've posted my bigmaf calibration before. If you can't find it by searching, I can try to dig it up. Mine idles good, and achieves target AFR at WOT... but there are occasional dips and spikes like TMS mentions.
edit... I searched for 2 seconds and found it. Obviously, use at your own risk.
Code:
0.94	0.98	1.02	1.05	1.09	1.13	1.17	1.21	1.25	1.29	1.33	1.37	1.41	1.48	1.56	1.64	1.72	1.8	1.88	1.95	2.03	2.11	2.19	2.27	2.34	2.42	2.54	2.66	2.77	2.89	3.01	3.13	3.24	3.36	3.48	3.59	3.71	3.83	3.95	4.06	4.18	4.3	4.41	4.49	4.57	4.61	4.65	4.69	4.73	4.77	4.8	4.84	4.88	4.92
1.50	1.72	1.97	2.24	2.53	2.85	3.22	3.64	4.07	4.54	5.06	5.60	6.19	7.43	8.83	10.36	12.06	13.94	16.01	18.26	20.87	23.87	27.21	30.96	35.16	39.64	46.93	55.19	64.33	74.10	84.67	96.13	108.61	122.20	137.01	153.07	170.36	189.26	210.00	233.39	258.37	284.06	310.48	328.83	348.85	359.88	371.18	382.74	394.22	406.06	418.17	429.56	441.16	452.99
jays05 is offline   Reply With Quote
Old 04-14-2007, 11:45 AM   #10
WeldingHank
Member#: 98645
2002 WRX Wagon
the maf scaling, not the voltage part but the G/S part.
Old 04-14-2007, 11:58 AM   #11
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
The Perrin BigMAF housing is metal - Are you saying that your engine bay gets hot enough to warp metal
mick_the_ginge is offline   Reply With Quote
Old 04-14-2007, 12:09 PM   #12
WeldingHank
Member#: 98645
2002 WRX Wagon
its aluminum. Leaving aluminum in the sun on a nice hot day is enough to distort it.
Old 04-14-2007, 08:18 PM   #13
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Is there an equation to go from lb/min to G/sec?
DoctorNick is offline   Reply With Quote
Old 04-16-2007, 02:33 AM   #14
WeldingHank
Member#: 98645
2002 WRX Wagon
1 lb/min = 7.56 g/sec
Old 04-16-2007, 01:34 PM   #15
darthvader666
Member#: 145879
The one I used had a silicon tube before the filter and that was too soft.
Old 04-22-2007, 10:18 AM   #16
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
when adjusting the maf table,
adjust to read for lambda values
read lt & st fuel values (compare to what is acceptable from stock)
then adjust maf table values
Old 04-26-2007, 11:21 PM   #17
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
this might be out of context, but at what PSI does the green flow 48lbs/min?
VideoGameWrx is offline   Reply With Quote
Old 04-27-2007, 02:36 PM   #18
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
where do u get this number from. I am trying to figure it out but cant, then again I don't even know how the MAF truly works, but....
if the stock intake radius is 2.5/2 or 1.25in
and I think the perrin big maf is 3.25/2 or 1.625in
If its proportional to the square of the radius then it's about 1.7 times bigger?
Someone please explain because I really want to know how the MAF works
Old 04-28-2007, 02:39 PM   #19
3barboost
Member#: 73609
2002 wrx
Default 70mm big maf help on 2.0 ecu
I am also battling to come to terms with the BIG MAF from Perrin and the APS 70mm cold air induction
scaling - adjusting injector size all seem to be band aids - surely mathematically we can do this properly ?
just how ?
3barboost is offline   Reply With Quote
Old 04-28-2007, 06:20 PM   #20
WeldingHank
Member#: 98645
2002 WRX Wagon
you take the size in millimeters and turn it into a percentage larger than the stock intake tube. On the Cobbforums you can get a spread sheet that will do the calculation for you.
Old 04-30-2007, 09:19 AM   #21
3barboost
Member#: 73609
2002 wrx
Welding Hank - got a clicky ? to that sheet on cobb forums - I signed up there and searched with no joy
Old 05-02-2007, 07:55 PM   #22
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
I cant find it either. (the spreadsheet) Anyone have a link?
Old 05-03-2007, 01:44 PM   #23
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Jeff Sponaugle from PDX tuning did a bench test with a Perrin BigMAF and a stock MAF back in 2004 that described the flow characteristics. It is not as simple as bumping every flow value up by the increase in open area.
I did a google search and looked at the cached page. I think I saved the document if someone wants it. PM me.
blkscooby is offline   Reply With Quote
Old 05-07-2007, 04:28 PM   #24
blkscooby
Member#: 44422
2009 G8 GT
I can't seem to find that test data from PDX anymore. You cannot simply increase all the flows by the increased cross-sectional area (40%). The Big MAF flows more like +20% at low loads and up to +30% at high loads.
Anyway, it was almost dead on with the MAF table posted in this thread in post #9. Seems to be a very good starting point.
Old 05-12-2007, 11:24 AM   #25
jays05
Member#: 78165
05 STI 35r + e85
Here it is... although in practice, this didn't help me a bit.
http://forums.nasioc.com/forums/show...t=BigMAF+scale
FS : ID 1000cc,Perrin big maf,FP Red, hottwrx02 MAIC Private Classifieds 8 04-25-2011 03:43 AM
3in custom cai piping with perrin big maf or perrin blow thru with big maf Stiguy34685 AccessPort 5 01-29-2009 10:57 PM
perrin big maf- lightly used perrin standard size maf filter sti charles Engine/Power/Exhaust 8 09-01-2008 10:20 AM
FS:NY: '04 STi ECUTEK ECU/COBB AP V1/Perrin Big Maf byroll01 Engine/Power/Exhaust 11 05-28-2007 01:27 PM
Are Legacy Gt Perrin Big MAF Intakes the same as STI BIg MAF??help BlackSTI2006 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-20-2007 02:05 PM
