Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 12-12-2001, 08:06 PM   #1
Member#: 11602
1999 Impreza RS
Angry AT oil temp light & lagging
My 99 RS just today when I was driving down the interstate I stepped down on the gas to pass a car when the car started to lag, it would not accelerate, then it did, then it started lagging again, then the AT oil temp light came on and it would not drive properly until I stopped the car and shut it off and then restarted it. It happened a couple more times in different gears whenever it stepped down on the accelerator. What is my problem? Do I have to reset the ECU again or something I don't know. Please advise as to this is really bothersome and not good.
deehram29 is offline   Reply With Quote
Old 12-12-2001, 09:03 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Your tranny fluid is overheating- resetting your ECU will not fix that. See if you're low on fluid for starters.
Old 12-12-2001, 11:23 PM   #3
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Is this a cross-post?
The ATF Temp light = TCU code. You may have a communication problem with the TCU, take it to the dealer and have them read the codes for you or fix it if it's in Warranty.
SubyTechMaster is offline   Reply With Quote
AT oil temp light flashing chuckles Transmission (AT/MT) & Driveline 53 08-04-2014 10:29 PM
AT OIL TEMP light flashes at startup... BoardRider Legacy Forum 3 04-21-2003 09:31 PM
AT Oil Temp Light SeanLiew Transmission (AT/MT) & Driveline 2 04-05-2002 06:05 PM
AT oil temp light & lagging deehram29 Normally Aspirated Powertrain 3 12-13-2001 12:56 PM
AT Oil Temp Light??? fuzzbox Normally Aspirated Powertrain 5 11-08-2000 04:44 PM
