Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Old 04-13-2007, 10:20 PM   #1
Dasani
Top Scoob 005
Member Sales Rating: (62)
Member#: 58098
10.4 @ 137.46mph
Cosworth, TSR70, MZM Tune
Subaru Stars SX Performance Fuel Pressure Regulator
FOR SALE: SX Performance Fuel Pressure Regulator
Will/Will Not Ship: Will Ship
Status: SOLD
How To Contact: PM
Description:
This is left over from my Mustang days of the mid-to-late 1990s and has just been sitting in the garage - I figured maybe someone could use it.
SX Performance regulators offer aircraft quality and precise pressure regulation for all engine combinations up to 1500 BHP. Components are CNC machined from 6061-T651 aircraft grade aluminum. Finish is to military specifications, anodized with Nickel Acetate in high wear areas.
The SX Performance fuel regulator 15402 provides pressure adjustability from 35 to 90 PSI. The use of fuel resistant fluorosilicone diaphragms not only provide the same high temperature protection that formally only aircraft use for their fuel systems, but also provide extended life over the competition's rubber based compounds. The extra light weight diaphragm assembly provides excellent pulsation dampening, to dampen the pressure spikes caused by fuel pumps and cycling injectors.
The model 15402 provides -10 AN inlet ports with a 1/8" NPT gage port. The 15402 regulator can support enough flow and power to support two SX Performance 18203 fuel pumps for systems well beyond the 1000 horse power barrier. Fittings and hardware are provided with each SX Performance regulator, along with instructions, mounting bracket and hardware. Each SX Performance regulator is not only compatible with automotive gasolines of all grades, but also with methanol.
More information is available here: http://www.sx-performance.com/Regulators.htm
-D
Dasani is offline   Reply With Quote
Old 04-20-2007, 10:50 AM   #2
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Bump!
Old 04-25-2007, 10:53 PM   #3
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Sold.
SX Performance Fuel Pressure Regulator Dasani TXIC Private Classifieds 2 04-25-2007 10:52 PM
For Sale: SX Adjustable Fuel Pressure Regulator pbnj9786 Private 'For Sale' Classifieds 5 08-03-2004 07:39 PM
Fuel Pressure Regulator and/or Fuel Rails? mav1c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-19-2003 03:23 PM
FS SX Fuel Pressure Regulator Andrew Bay Area Impreza Club Forum -- BAIC 0 10-11-2002 02:15 AM
SVX Fuel Pressure Regulator Solved Idle Pressure Problem the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 23 11-05-2001 09:20 PM
