#1 |
Member#: 37678
SCIC
Dammit, my manual says 16.9 gallons or something insane, but my refill light goes on at just below a quarter tank, which takes about 10-11 to refill.
#2 |
Member#: 93830
South East
Vehicle:2011 German Electrical Nightmare |
the most i ever put in my WRX (05) was 13.7 gallons. Yes, the light was on for a while.
#3 |
Member#: 4429
E. Canada
Vehicle:2006 9-3 SC Aero |
Is the gas gauge linear? The temp certainly isn't.
#4 |
Member#: 42145
Vehicle:6-4 jockin da bish- es and slappin the ho's. |
which impreza?
#5 |
Member#: 37678
SCIC
Ts (as if the put different gas tanks in each Impreza.)
#6 |
Member#: 42145
#7 |
Member#: 486
Vehicle:2004 Forester XT bug spattered |
Most Imprezas have a 15gal tank as far as I know. The '08s have a bigger tank with the new design.
#8 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
read your owners manual.
it should be 16.9, but its something like 14.1 lmp gl (lamp gallons), thats all it shows on the gauge. This is to to give you a 2.6 to 2.8 reserve quantity so you dont run out of gas. |
#9 |
Member#: 486
I've run out of gas before and cranked 14.95 gal in before it came out the filler neck.
*shrug* I dunno. |
#10 |
Member#: 31973
Vehicle:2003 WRB WRX 2010 Corolla, aluminum |
Yeah the manual states your reserve tank size. So unless you run the car with the light on for an extended period of time you won't ever have to fill it all the way back up.
Except apparently porter. |
#11 |
Member#: 42145
#12 |
Member#: 37678
SCIC
I'd be inclined to follow the owners manual, but as I said, my light comes on at a frackin quarter tank, and as this thread shows everyone says something different.
#13 |
Member#: 37678
SCIC
Oh, and why do I only get 22mpg, eh?
It's all an interconnected conspiracy. ![]() |
#14 |
Member#: 486
#15 |
Member#: 42145
#16 |
Member#: 37678
SCIC
Dunno. I fill up around 220 miles, which leads me to believe I'm driving something fun and ferocious, like a 6.0 GTO...then I hit the gas, and accelerate to 60 in 9.4.
#17 |
Member#: 30206
Vehicle:2005 Outback XT centralohiosubarus.com |
the gas tank on my leggy is 16.9, and the light comes on at 2.9Gal left.
I read that in my manual, and have lived by it. |
#18 |
Member#: 453
Vehicle:2013 VT |
not having the fuel computer in the Imprezas made it hard to determine, but at least on my new legacy ive run it very close to empty and actually filled it close to the stated 16.9 gallons. Plus my empty fuel light kicks in when i have an estimated 3-4 gallons left in the tank, usually when the trip computer indicates about 90 miles left in range.
#19 |
Member#: 4835
Vehicle:2003 Baja 5MT Yellow w/ 220,000 miles |
Legacy is 16.9 gallons. 1993-2001 Impreza is 14.9 gallons. 2002+ is 15.9 gallons. Look in the Owners Manual!
![]() Realize you cannot use every drop of gas in the tank. So you can 'run out of gas' and still have gas in the tank. The fuel pickup is not touching the bottom of the tank, to reduce suction of dirt, etc. into the fuel pump. SO u cant use all 15.9 gal. or whatever. If i fill up my bugeye right when the light comes on, I can put in 11-12 gallons. It seems like I can drive forever with the fuel light on and still never takes close to 15.9 gallons. I'm glad the light comes on when i have a few gallons left! |
#20 | |
Member#: 37678
SCIC
#21 |
Member#: 83039
Vehicle:2005 LegacyGT Ltd 5m ಠ_ಠ |
Mine is very linear as best I can tell, but it does say empty after about 14 gallons are gone. 2 gallons of reserve makes sense to me.
My old car was worse. For one thing the gauge wasn't linear at all. It was slow at first then sped up a little after the halfway mark. Even then empty meant it had only used about 10 or 11 of the 16 gallons. |
#22 |
Member#: 486
#23 |
Member#: 453
Vehicle:2013 VT |
My WRX fuel guage was really nonlinear. I think the top half represented the first 2/3 of the fuel tank and then when it hit the halfway mark, it dropped like a rock and i was hitting empty before i knew it.
The LGT fuel indicator is much more linear, it actually corresponds to my real fuel capacity and expected range. midway point really means a half tank. Ed |
#24 | |
Member#: 16779
SCIC
Vehicle:2008 God's Gift to Turbo Wagons (MS3) |
What the hell is a lamp gallon? ![]() It's imperial gallon (~1.2 US gallons). baaahahahahha |
#25 |
Member#: 34670
South East
Vehicle:If she smokes she pokes |
I was about to point and laught too! Lamp gallon?
| Thread Tools | |
| Display Modes | |
| 2006 Impreza gas tank fill - fuel tank filler neck problems. | Psybin | Warranty Issues & SOA Problems | 11 | 01-08-2007 09:48 PM |
| ('93-'01) 93 subaru impreza gas tank ?? | edean37 | Impreza Forum | 0 | 08-16-2005 10:16 PM |
| 99 RS owners...How big is your tank? | SpamMansXe | Normally Aspirated Powertrain | 12 | 12-25-2002 04:36 PM |
| how big is the impreza stock exhaust pipe? | STi Boy | Normally Aspirated Powertrain | 6 | 03-01-2001 03:06 AM |
| How much is an Impreza worth? | Snoopy | General Forum Archive | 36 | 06-06-2000 06:04 PM |
