Old 04-14-2007, 03:12 PM   #1
turboso
Member#: 102071
2007 STi
Default Is it safe to tap ECU wires??
How safe is to tap ECU wires, and what is the best way to do it??? Are those clamps bad for the wires. Can this connectors damage the wires???
Also is the ECU affected by tapping wires like A/F and knock sensor.
Also what can be done if you damage a wire close to teh ECU, can it be fixed??
turboso is offline   Reply With Quote
Old 04-14-2007, 03:26 PM   #2
rkramer
Member#: 118209
2015 WRX Limitec
don't tap the ECU A/F wire, there is NO good reason to ever touch that one. ignore whatever your turbo timer or A/F gauge tells you, do NOT touch that wire!
(and yes, people have reported all kinds of problems from tapping both... if you tap the knock sensor it reduces the sensitivity the ecu has regarding knock)
Old 04-14-2007, 03:39 PM   #3
turboso
Member#: 102071
2007 STi
If you already tap it, removing the tap and putting electrical tape, would the resistance still is affected?
Old 04-14-2007, 08:47 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
as long as it wasn't mostly severed it should be fine.
Is it safe to cruise around with a DP and no ECU ndn_ninja15 Rocky Mountains Impreza Club Forum -- RMIC 9 05-01-2009 12:02 AM
Is it safe to do a core exchange for a 2004 ECU? scooby9 Engine Management & Tuning 3 04-04-2005 02:57 PM
Is it safe to drive with a re-flashed ECU before the mods are done? sdseagles Engine Management & Tuning 6 04-04-2003 12:07 AM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
Is it safe to use stock ECU with up-pipe and turbo back exhaust (1 cat)? gtr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-11-2001 08:32 AM
