Old 04-14-2007, 05:40 PM   #1
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
Inexplicably rusting.....
Default how reliable would a 99 rs w/ 110K miles be?
Thinking of making an offer on it, it was always dealer serviced. opinions?
hendo2.5 is offline   Reply With Quote
Old 04-14-2007, 05:50 PM   #2
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
if the timing belt & headgaskets were done it should go for a very long time..
mxpunk is offline   Reply With Quote
Old 04-14-2007, 05:59 PM   #3
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
As reliable as a 20 year old dog?
V6TurboTA is offline   Reply With Quote
Old 04-14-2007, 06:10 PM   #4
cmiovino
Member#: 134005
2004 WRX Premium
Yea, you have to look into the acquaintance more, but timing belt & headgaskets are a good start... You might be able to find one with lower miles if you look a little harder
Old 04-14-2007, 07:19 PM   #5
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
Full mechanical inspection would be needed, including the compression test.
bezerk is offline   Reply With Quote
Old 04-14-2007, 07:21 PM   #6
spongejosh
Member#: 62783
Midnight Black Pearl
depends on the price.
spongejosh is offline   Reply With Quote
Old 04-14-2007, 07:33 PM   #7
MidnightBlackPearl
Member#: 83751
2015 BRZ
Ice Silver Metallic
As long as it's in good condition, there are plenty of miles to go on it.
MidnightBlackPearl is offline   Reply With Quote
Old 04-14-2007, 07:52 PM   #8
SjpWrx
Member#: 22554
2007 Corolla no PW!
WHITE miss my WRX :(
yea whats the price?
SjpWrx is offline   Reply With Quote
Old 04-14-2007, 09:20 PM   #9
92XJET
Member#: 97425
00' GC8, 05' FXT
07' Jeep Commander XK
I paid $6K for a 2000 RS with 121K miles. Never regret the decision one day.
92XJET is offline   Reply With Quote
Old 04-14-2007, 09:45 PM   #10
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
did the '99 RS have the DOHC or SOHC 2.5? check which engine it has because alot of the DOHC 2.5's had headgasket problems and front crank seal oil leaks, check wheel bearings too.
bugeye829 is offline   Reply With Quote
Old 04-15-2007, 01:14 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...if the body is good......do a swap and fergetaboutit
Old 04-15-2007, 01:30 AM   #12
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
at that age making sure it is straight and rust free is more important than anything. mechanical work is easy. body work is not.
if it isnt leaking oil too much and has a new timing belt it should be fine.
and if it is leaking a bit and needs a belt make an offer that reflects that and buy it anyway. timing belt and the front seals is about 300 at least to pay someone else to do it. and while you are in there put in a new water pump and make sure the oil pump isnt leaking. and if you are slighlty mechanically inclined, or have a good friend who is, the job isnt that tough to do yourself.
greg donovan is offline   Reply With Quote
Old 04-15-2007, 03:08 AM   #13
nkx
Member#: 96951
2004 wrx sedan
'10 Outback 6mt-wifey's
the 99 should be SOHC.
nkx is offline   Reply With Quote
Old 04-16-2007, 10:35 AM   #14
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yes, it is. That means it's less likely to have the headgasket problems experienced on the DOHC EJ25s.
Go for it!
Wiscon_Mark is offline   Reply With Quote
Old 04-16-2007, 10:55 AM   #15
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
Buy it You will never regret you decision
These cars are Classics and have you seen the 08??
That will make the GC worth even more
dstan is offline   Reply With Quote
Old 04-16-2007, 11:24 AM   #16
alpinev12
Member#: 90186
2006 Impreza WRX Ltd
2011 Audi S4
highway or city miles?
Rick B.
alpinev12 is offline   Reply With Quote
Old 04-16-2007, 11:27 AM   #17
GripGC8
Member#: 110653
87 FC3S
i payed $7479 for a 01 RS with 113k miles on it fro the original owner.
the car will last you long enough to swap it.
you can get swaps pretty cheap(unless you want a 04+ STi swap)
GripGC8 is offline   Reply With Quote
Old 04-16-2007, 11:53 AM   #18
dromango
Member#: 94531
99' RS
Rally Purple Pearl?
i own two 99 rs's
170k miles on auto, 100k on manual
dromango is offline   Reply With Quote
Old 04-16-2007, 12:30 PM   #19
JCity
Member#: 131845
1994 Acura Integra
R-81
108k miles on mine, i kinda overpaid for it but everytime i drive it i forget about over paying it, i love it.
JCity is offline   Reply With Quote
Old 04-16-2007, 02:05 PM   #20
rallyblues
Member#: 44912
2015 RC350
Add wheel bearings, valve cover gaskets, radiator and the clutch...
and it'll do another 110K
rallyblues is offline   Reply With Quote
Old 04-16-2007, 02:49 PM   #21
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
And I'm still on my original radiator, valve cover gaskets, wheels bearings, and I just replaced the clutch @ 186,000...don't make the guy paranoid.
Old 04-16-2007, 04:21 PM   #22
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
dooooo eeeeeet!
moogoob is offline   Reply With Quote
Old 04-16-2007, 04:52 PM   #23
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
drop in a ej22t block or ej22 n/a block with ej22t pistons and turbo it!
Old 04-16-2007, 05:17 PM   #24
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
If they have good service records and the price is resonable I say go for it. I purchased mine off a second owner for $7k, it had 120k on the clock at the time. He had records all the way back from the first oil change, and the paint & body are cherry, a few rock chips though (that's the price you pay living in Colo. though, but never any rust). A bottle of touch up paint and I was back in business. By far the best automotive purchase I have ever made. Now does anyone have an EJ207 they would like to donate to the cause?
my4isflat is offline   Reply With Quote
Old 04-16-2007, 05:25 PM   #25
my4isflat
Member#: 120002
2000 2.5 RS, '95
My last suby had 325k mi on the clock and I still had the original radiator, valve cover gaskets, clutch, and only replaced one front wheel bearing, and one set of brake pads, although I had to double clutch to downshift I'm sold on Subaru's for life.
99 RS RBP - 82K miles - MD - $6K incajones Private Vehicle 'For Sale' Classifieds 53 08-29-2006 12:11 PM
FS: 99 RS RBP 82K miles $6400 incajones Private Vehicle 'For Sale' Classifieds 12 04-23-2006 08:25 PM
gauging interest 99 rs coupe low miles dayton100 North West Impreza Club Forum -- NWIC 2 03-15-2004 12:32 PM
how reliable is a turboed RS? IMPRZME Newbies & FAQs 8 10-08-2001 12:54 PM
how acurate would a 4eat rs be with the awd fuse pulled be on a 2 wheel dyno? GregBolby General Forum Archive 4 02-14-2001 07:57 PM
