Old 04-16-2007, 12:40 PM   #1
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Default what will my impedence be?
So I am looking for the answer to this question. I am looking to get a 4 channel amp to power my front speakers and my subwoofer. I have a dual voice coil 4 ohm subwoofer. If I wire this in paralell and bridge it off 2 of the channels is that running at 2 ohms? If I wire it in series is that running at 8 ohms? I am wanting to run it in paralell off of the 2 channels and have it run at 2 ohms. I know off of a mono block sub this runs at 2 ohms but was not sure if it is the same running off of 2 bridged channels...
Thanks in advance!
rxer311 is offline   Reply With Quote
Old 04-16-2007, 12:41 PM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
yep, it's the same....
Old 04-16-2007, 12:49 PM   #3
rxer311
Member#: 107099
'07 STI
Satin White Pearl
So now I just need to find a 4 channel amp that is stable bridged at 2 ohms...
Old 04-16-2007, 12:51 PM   #4
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
yep, most "should" be...but not all, depends on what your looking at...
Old 04-16-2007, 12:51 PM   #5
Boost4U
Member#: 16459
1998 2.5RS
I'm running a Kicker KX600.4 running as you have described. Runs great. Contact S/N: RossWRX he'll hook ya up for a smokin deal. He can also answer all you questions and then some.
Boost4U is offline   Reply With Quote
Old 04-16-2007, 12:53 PM   #6
rxer311
Member#: 107099
'07 STI
Satin White Pearl
I am running a phoenix gold 250 watt RMS sub. Thinking about a kenwood excelon or similar.
Old 04-16-2007, 12:59 PM   #7
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Just browsing around it doesn't look like there are many amps stable bridged at 2 ohms...
Old 04-16-2007, 01:15 PM   #8
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Most of the ones that are 2 ohm stable are going to cost some $$$. Most amps are only 4 ohm stable when bridged. You'll need to look at the PG Xenon series, JL Slash series, and some of the more high end amps out there.
khail19 is offline   Reply With Quote
Old 04-16-2007, 01:21 PM   #9
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Seriously.... man, i though MOST were 2ohm stable bridged.... What price range are you looking at??
I'll give you my advise..... Ebay....
Old 04-16-2007, 01:24 PM   #10
rxer311
Member#: 107099
'07 STI
Satin White Pearl
I am looking on ebay. I was looking at a soundstream, ma audio, etc
Old 04-16-2007, 01:25 PM   #11
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Here is another question then...could I run 2 channels for the front and just use 1 channel for the rear? But then it would be playing in stereo and the bass would only be half playing right?
Old 04-16-2007, 01:34 PM   #12
rxer311
Member#: 107099
'07 STI
Satin White Pearl
And even another question...if an amp is putting out 240 watts bridged at 4 ohms what would it be putting out at 8 ohms? I have a 250 watt rms sub and want it to be close...
Old 04-16-2007, 02:28 PM   #13
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Well, at 8ohms, you "halve" the output power....
Say 250w @4ohms
125w @8ohms
But ~500w @2ohms...
This doesn't ALWAYS hold true, but is a retelatively good "rule of thumb" in 12v audio....
I don't know if you have seen me post this graph i'm about to post before, but if not, it's the Ohms Laws "wheel" and if you can understand it, it's the "Holy Grail" of the electrical world.... search on it, learn about it, feel your knowledge grow...
Old 04-16-2007, 02:35 PM   #14
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Thanks!
Old 04-16-2007, 02:38 PM   #15
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
No problem, i hope it helps and doesn't confuse...
Old 04-16-2007, 02:40 PM   #16
LastResort
Member#: 99289
I'd check the specs. Some amplifiers reduce output voltage when driving a small impedance load. This causes the output to be much lower than expect. I run a 10" 4Ohm DVC on two 50W channels, un bridged and set to mixed mono. Plenty loud, this obsession with 2ohm and 1ohm stable amplifiers is really beyond justification.
LastResort is offline   Reply With Quote
Old 04-16-2007, 03:02 PM   #17
s-t-izzle
Member#: 145230
05 STi
Stage 2 -- Aspen White
Cool Go For It
I Agree With Last Resort On His Comment. I Would Try Running The Amplifier At 2ohm Mono...the Worst That Could Happen Is The Amp Will Get Too Hot And Send Itself Into Protection Mode....should This Happen, Just Change It To 4ohm Stereo, But Be Sure If You Run It In Stereo That You Use A Y-adapter On Your Rca Cable So That You Dont Mix The Signals On A Dvc Sub. So Long As You Dont Bury The Amp In Your Trunk Or Under A Seat...give It Good Ventilation, It Should Work Pretty Well. Start With The Gain/sensitivity Low And Work Your Way Up To The Listening Level You Want. You're Not Going To Be Able To Pound It Very Hard. One More Thing....make Sure You Have A Very Good Ground And That Your Power Wire Is Adequate And fused.
s-t-izzle is offline   Reply With Quote
Old 04-16-2007, 03:29 PM   #18
elladamerie
Member#: 145132
2006 WRX
Red
I always bought Rockford Fosgate amp and I was never disappointed, I own 3 Rockford amp, and four speakers
I looked the specs on their official website then search on ebay
Anyway, if you give us the spec of your speakers and subwoofer, I'm pretty sure we can advice you which amp you should buy.
elladamerie is offline   Reply With Quote
Old 04-16-2007, 03:40 PM   #19
rxer311
Member#: 107099
'07 STI
Satin White Pearl
I have a hodgepodge of a "system". I have JL tr 6.5 components up front (4 ohm 10-75 watts rms). I have ma audio 5.25" in the rear (4 ohm 60 rms). I have a phoenix gold octane 12 " sub (4 ohm dvc 250watts rms 500 peak). I am also thinking 5 channel amp for everything!
Old 04-16-2007, 03:56 PM   #20
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Why don't you just run two amps? Or if it must be one amp, look for something that is class D for the subwoofer, and that will usually run 2 ohms.
TAPOUT is offline   Reply With Quote
Old 04-16-2007, 04:11 PM   #21
elladamerie
Member#: 145132
2006 WRX
Red
5 channel amps are costy, Rockford has one it's called Power 1000, It can give enough power for your speakers, but it will be too much for your sub.
I suggest you buy a rockford P450.4 for your speakers.
and a rockford P300-1 for your sub. You will wire your sub to have 2 ohm load
It had 50w more than your sub, so I suggest you don't much your gain like crazy or you might have some problem.
Old 04-16-2007, 04:48 PM   #22
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Most are 2 ohm stereo stable. Since each channel only sees half the impedence when bridged, that makes them only 4 ohm mono stable.
02BlueSuperRoo is offline   Reply With Quote
Old 04-16-2007, 04:48 PM   #23
LastResort
Member#: 99289
Gain has almost nothing to do with watts.
Old 04-16-2007, 06:56 PM   #24
rxer311
Member#: 107099
'07 STI
Satin White Pearl
I got this amp from another auction for $140 shipped. He was a private seller who bought the amp and never hooked it up. Still in the plastic in the box. I think I got a good deal. What do you think?
http://cgi.ebay.com/SOUNDSTREAM-5-CH...QQcmdZViewItem
Old 04-16-2007, 10:06 PM   #25
rxer311
Member#: 107099
'07 STI
Satin White Pearl
What does anybody think about that?
Will my amp be too much power for my 10'' Solobaric L7 BangWRX Car Audio, Video & Security 13 11-04-2006 03:05 AM
what will my AWHP be with a tune? neokenxx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-10-2006 11:57 PM
what will my final drive and power be like with this combo? EJ22Boom Transmission (AT/MT) & Driveline 2 01-16-2005 04:52 PM
What will my cr be with a v7 or v8 mated to 98rs heads sime Normally Aspirated with bolt-on Forced Induction Powertrain 4 08-07-2004 06:28 AM
What will my travel from PA to Maine be rallynutdon New England Impreza Club Forum -- NESIC 5 12-05-2002 09:57 PM
