Old 04-16-2007, 02:06 PM   #1
02DaWeRXs
Member#: 95302
2002 WRX Wagon
Default Dash clock dead- is it a fuse?
The clock on my dash just suddenly went black...wondering if there's a seperate fuse for it or is my clock really dead? I never knew how much I used that clock until it died...worth buying a new clock or just rig/doublestick tape a travel one in there...one with features (i.e. compass, temp., alarm, etc. hehehe...)
02DaWeRXs is offline   Reply With Quote
Old 04-16-2007, 02:27 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
A common problem with the clocks is cold solder connections on the circuit board inside. If you know how to deal with this you may be able to fix it yourself.
Old 04-16-2007, 04:08 PM   #3
Brighton
Member#: 53542
2002 02TS + 02WRX
TS=Green/WRX=Silver
Very simple fix with a soldering iron. Do some searching and there's a pictorial HOWTO somewhere.
Brighton is offline   Reply With Quote
Old 04-19-2007, 01:38 PM   #4
02DaWeRXs
Member#: 95302
2002 WRX Wagon
Thanks...time to whip out the soldering iron...But how do I get the "pod" that hodls the clock out? I know it snaps out at the back(closer to the windscreen) but are there screws in the front?
Thanks for the help...But I really did want a compass
Old 04-19-2007, 08:19 PM   #5
Brighton
Member#: 53542
2002 02TS + 02WRX
TS=Green/WRX=Silver
Pull it from the back and there's pressure clips. Once the back is raised the front has two hook type attatchments. Just twist it upwards and it'll eventually comes free. (It can take a bit of force, try and spread the pulling evenly across the housing so it doesn't snap)
Old 04-24-2007, 07:10 PM   #6
shate
Member#: 147131
Default Same problem here
I've gotten the clock pod out. How do I get the clock off the back of the pod? I tried pushing on what looked like latches, but it didn't seem to help.
Also if anyone has more info on what might need to be soldered once I get in there, I'd really appreciate it.
shate is offline   Reply With Quote
Old 04-27-2007, 06:37 PM   #7
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
I can't much help you on getting the clock out of it's pod... there were only two clips on my Forester.
You're going to resolder the resistors. There are three on on the cicuit board, on the same side as the LCD. One is marked 510, two are marked 300. The 510 usually has a failed solder or two(mine was free floating in the housing). Dab some new solder on both joints of all three resistors. It should work now.
The pics and writeup I used are here: http://www.subaruforester.org/vbulle...ead.php?t=3350
Another short writeup here: http://www.seacoastsubarus.com/forum...hread.php?t=35
This fix is super easy and there is no excuse for not fixing it yourself. I had no prior soldering experience and fixed it in under 5 minutes.
SoobATV is offline   Reply With Quote
Old 05-01-2007, 09:15 PM   #8
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Bump for a great thread, thanks in particular to SoobATV. My clock kicked the bucket and dispite my previous bad luck soldering I was able to fix this.
Paul
Snowphun is offline   Reply With Quote
Old 05-02-2007, 12:45 AM   #9
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
Yaahee! I am so smart! I am so smart! Ess, Emm, Arr, Tee!
Yeah, it's a painfully common failure, at least thru the '04s. Most just toss the clock and buy a new or used one or mounted gauges in it's place... I spent less on the iron/solder than I would on a well used clock.
Glad to see it worked for ya, Snowphun... spread the word.
Old 05-02-2007, 12:57 AM   #10
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
depends on what car it's in they can get over heated in forester's. The clock is tied in with the sterio often times as well.
Old 05-02-2007, 01:16 AM   #11
gedden
Member#: 145597
2002 RS
Thanks for the info! I fixed mine last weekend. Too simple.
gedden is offline   Reply With Quote
215/40/17's on bugeye wrx, how bad is it? LASERBLUE135 Tire & Wheel 15 06-07-2010 07:56 PM
need 2 led lights red,and green they will go where my dash clock is jeremywrx15554 Private 'Wanted' Classifieds 2 10-24-2008 10:05 PM
Dash clock is out! Wildde North West Impreza Club Forum -- NWIC 8 04-23-2007 02:07 PM
WTB: dead WRX/STi dash clock pleiad7 Private 'Wanted' Classifieds 1 01-19-2007 05:13 PM
Is my starter dead or is it a bad connection? DoinkMobb Service & Maintenance 13 12-30-2003 07:42 PM
