Old 04-16-2007, 07:26 PM   #1
FraserMcHaggis
Member#: 146007
2005 WRX STi
Default Where can I find a good write up on hardwireing a V1
I just picked up my 2005 STi last week. Now I want to put the V1 in it.
Is there a good resource area for write ups?
(Yes I am new to Subarus, but not all wheel drive turbo cars)
FraserMcHaggis is offline   Reply With Quote
Old 04-17-2007, 11:20 AM   #2
12sechatch
Member#: 132458
Okie Dokie Fine
there is a thread on here about hardwiring a v1 into your 12v from your auto-dimming mirror. search for it and im sure you'll find it...good luck
12sechatch is offline   Reply With Quote
Old 04-17-2007, 11:42 AM   #3
absoluturq
Member#: 146421
its easy....take the non squigly wire it comes with....run it thgrough A pillar, down to the fuse box, and put it in the misc. slot..
thats how it was with my car, but what do i know about subarus
absoluturq is offline   Reply With Quote
Old 04-17-2007, 02:23 PM   #4
piekarski17
Member#: 131178
05 WRX
FP 18g'd tuned by Jorge
1) get a phone cord.
2) cut one end off
3) strip the 2/4 wires on the inside
4) grab 2 at a time and hold to 9v battery. you'll have correct connections when v1 clicks
5) mount v1 above rear view mirror
6) run phone cord along top of windshield, down a-pillar, under steering column and into center council
7) tap into cig lighter
8) solder then cover w/ electric tape
piekarski17 is offline   Reply With Quote
Old 04-17-2007, 07:36 PM   #5
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
You don't even need to go through that trouble. It comes with a hardwiring adapter, so you don't need to deal with stripping wires for it.
And you can wire it into the harness that's used for the auto-dimming rear view mirror, no need to run wires down the A-pillar or anywhere other than 3" through the space between the headliner and the roof.
RP31 is offline   Reply With Quote
Old 04-17-2007, 07:40 PM   #6
RP31
Member#: 123574
CGM STi
And to answer the OP, read these threads:
http://forums.nasioc.com/forums/show...ntine+hardwire
Then, when you want a setup like this:
Let me know.
Old 04-17-2007, 07:46 PM   #7
springwrxsti
Member#: 136696
2007 STI Ltd.
Urban Grey Metallic
Lightbulb V1
Get the remote indicator direct from Valentine One, mount it in the slot on top of your steering column against the dash display, then mount your V1 as suggested above your rear view mirror, then you have the best of both worlds. All the wiring directions and connections are included with the remote display from Valentine One.
springwrxsti is offline   Reply With Quote
Good write up on Master Brake Cylinder Bench Bleeding Soulofdarkness Brakes, Steering & Suspension 4 09-11-2010 03:34 AM
Where can I find a good clutch for my car? ImprezaTs Canada Region Forum 4 01-30-2006 01:46 PM
where can i find a GOOD DEAL on some brake pads? blackie Private 'Wanted' Classifieds 12 08-19-2005 12:24 AM
Ebay gauge pod = POS. Where can I find a good one? powerlabs Interior & Exterior Modification 4 06-01-2005 02:14 PM
Where can I find a good inexpensive spring compressor? waitandbleed92 Brakes, Steering & Suspension 11 02-01-2005 03:07 AM
