Old 12-13-2001, 08:31 AM   #1
BlueMofo
Member#: 12971
Angry static shock
heya,
so I'm driving along with a big smile on my face and I get home and park in the parking lot, right ? I get out of my car, and touch the metal door and ZAP ! I get this HUUUGELY powerful electrostatic shock !
Can someone explain to me why this happens? I thought for a bit and the best I could come up with was that the tires rolling on the pavement create static by losing electrons, which charges the car negatively ? And so you get this huge ZAP when you ground the car by touching it with your hand.
How can I get rid of this problem ? Is this the reason I see people with those little pieces of kevlar fabric hanging from their rear bumpers ?
Thanks for your help.
BlueMofo is offline   Reply With Quote
Old 12-13-2001, 09:03 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
yeah this happens in the fall/wintertime...
it's got a lot to do w/your shoes...
different shoes will allow ya to get zapped!
just be wary!
jamie
www.subiegal.com
Old 12-13-2001, 09:29 AM   #3
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Once your car gets all charged up it is difficult for it not to happen too....one thing you can do is use the middle of your arm as a contact point; it is a little less sensitive than your fingertips when touching the door. (Like the underside of your forearm).
Cold dry weather seems to bring it on the worst....
If you have a Subie then with no window frame on the door it's harder to do this.....on a vehicle with window framed doors then it's a little easier.
Doesn't necessarily alleviate the problem but helps minimize the impact.
I honestly can't answer *where* the static charge comes from but from my own personal guess it is partially generated by you sliding out of the seat (or so it seems) upon vehicle exit.
DrBiggly is offline   Reply With Quote
Old 12-13-2001, 09:39 AM   #4
Red-Impreza
Member#: 3884
Lightbulb
If that were the case, you'd get the shock when you touched the ground, not the car.
I'm guessing you don't have a leather interrior.
This happens to me all the time (I live in the desert, no need for winter, our air is dry all the time). The most common cause is friction between your clothes an the car seat. When you rub against the cloth of the seat you are the one that gets a static charge relative to the car. (Much like rubbing your feet in dry socks across a carpet.) Moisture in the air or on the material (or static dissapitive shoes) will allow the static to dissapate slowly, avoiding the sudden shock.
Touch the door metal before you get out. Keep touching it as you climb out. You will still get a bit of a shock, but it should reduce it. I believe you can also find fabric treatments to help avoid this (for your car seats) or possibly change the fabric softener you use in your laundry. Or get a leather interrior. Leather won't usually generate the static.
-Bud
Red-Impreza is offline   Reply With Quote
Old 12-13-2001, 10:46 AM   #5
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Default You're defnitely not the only one
I posted a similar question in the Car Audio Forum and got some pretty good suggestions as to how to prevent getting shocked. I think the thread was "shocked on Subies" or something.
Jason
2.5GT is offline   Reply With Quote
Old 12-13-2001, 10:57 AM   #6
yuns555
Member#: 10978
04 yunos
resale red
OMG! this happens to me all the friggin time. i've become paranoid about touching anything metal. i read that '94 accords had grounding issues and the toll collectors were weary against these cars because they would get shocked everytime the driver would give him toll. anyways, i thought similar case, i took my subie in and asked the mechanic to take a look, i could only wonder he said about me after i left. hehe. of course there was nothing he could do. basically, i am still getting shocked really bad in winter and i wear all sorts of shoes. if you should ever figure it out, please save this brother.
yuns555 is offline   Reply With Quote
Old 12-13-2001, 11:13 AM   #7
wrx182
Member#: 9531
2002 WRX Sport Wagon
contact taichih on the board - there is an option in japan, these little things that go on the doors & eliminate shock, i think it's like $50 for them...
wrx182 is offline   Reply With Quote
Old 12-13-2001, 12:22 PM   #8
Tweek!!!
Member#: 3963
2005 STi
Default OR......
you could just touch your key to the door when getting out to let IT take the shock.
That way you don't get burned at the point of contact from the spark...the key takes the heat.
wj
Tweek!!! is offline   Reply With Quote
Old 12-13-2001, 12:47 PM   #9
motorob
Member#: 2878
06 Evo IX MR
It seems like some cars are worse than others, and the worst I ever had was a few Subarus ago. I had an '88 DL that would about knock you flat when getting out of the car in the winter. At night you could see the spark jump off the chrome door handle.
motorob is offline   Reply With Quote
Old 12-13-2001, 12:48 PM   #10
Rebellion
Member#: 8069
2002 Impreza WRX
Sedona Red + Mud!
i still got shocked through the key.. i just grab the door latch thingie in the door frame when I get out (before my butt leaves the seat) .. no shockie...
Rebellion is offline   Reply With Quote
Old 12-13-2001, 12:59 PM   #11
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
It's a combo of things... first the tires... low-rolling resistance tires(RE92's) are poor conductors... something about the carbon content, I think... it's bad in the winter because the air is dryer and doesn't conduct as well either. But all these non-conducting surfaces build up static charges. When you're in the car, you're insulated by all the plastic and carpet... when you get out and touch the metal the static discharges into you. if you were barefoot it would be worse. Different shoes can make a difference tho because they let you become slowly charged like the car so there's no charge difference between you and the car so you don't get shocked... it slowly bleeds off tho after you're out of the car so you don't get shocked again later...
mrbell is offline   Reply With Quote
Old 12-13-2001, 01:01 PM   #12
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
It is funny a hell to see your passengers shock the hell outta themselves I'll try and wait till they get out first!!!
Jason
Old 12-13-2001, 01:47 PM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
just be wary!
jamie
www.subiegal.com
your shoes combined w/ the dry air and cloth seats...i get shocked ALL the time.
jeremy
Old 12-13-2001, 01:50 PM   #14
ImprezaRS2000
Member#: 779
1998 STi Wagon
It's a Subaru thing. My girlfriend ALWAYS gets the shock! Hehe!
ImprezaRS2000 is offline   Reply With Quote
Old 12-13-2001, 03:23 PM   #15
2Point5RS
Member#: 3639
When you exit your car, hold on to the door.. you won't get shocked. Just make sure you grab the door before you touch the ground.
2Point5RS is offline   Reply With Quote
Old 12-13-2001, 03:29 PM   #16
yuns555
Member#: 10978
04 yunos
resale red
trust me, you'll get shocked regardless. i also tried to close the door by pushing on the window, thinking that i'm safe, when i reach for the door to a restaurant or work...........pop.
Old 12-13-2001, 05:03 PM   #17
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
It's not just a subaru thing... my mom's old honda did it to me and her maxima does it from time to time... the worst was a friend of mine's cavalier.... of course it could have just been that I was wearing a wool peacoat and sweaters and it was the middle of winter in massachusetts so it was REALLY REALLY dry... at one point I shocked myself on a door... a house door... a friggin' unpainted WOOD DOOR!!!!!!!
Old 12-13-2001, 07:54 PM   #18
Bradus
Member#: 10036
2008 Infiniti G35x
Volvo XC90-T6
Not sure if they sell them here in the USA - although I imagine they must do - but in England you could buy a 12-18" long rubber strip that attached to the underpart of your car and would touch the ground when the car was still. This helped the static energy to escape prior to you or someone else leaving the var and getting shocked.
Anyway else see these being used, or is it just a UK thing?
David
Bradus is offline   Reply With Quote
Old 12-13-2001, 08:16 PM   #19
kensington
Member#: 9113
2k4 WRB STi
RIP#92 Fred"G-Money"Zippy
I remember seeing in a friends old mazda little rubber nubbins on the door that seemed to suck up the juice. Maybe that's what Tai Chi can get ? Someone should probably find out because it's starting to piss me off. Not enough for me to find out for myself though.
kensington is offline   Reply With Quote
Old 12-13-2001, 09:29 PM   #20
codemunky
Member#: 1804
It's the flux capacitor.
Put the anti-static mat on.
Radio mars for help.
codemunky is offline   Reply With Quote
Old 12-14-2001, 03:15 AM   #21
Darwin
Member#: 2704
2001 Impreza 2.5 RS
Blue Ridge Pearl
For me, the window isn't even safe. I get shocked through the tinting.
Darwin is offline   Reply With Quote
Old 12-14-2001, 04:47 AM   #22
Imprezard
Member#: 3016
CBA GH8
WR Blue
That's why I always wear gloves to drive in winter.
I don't like cold steering wheel either
Imprezard is offline   Reply With Quote
Old 12-14-2001, 09:53 AM   #23
Red-Impreza
Member#: 3884
Lightbulb
Putting a ground strap on the car won't help you. It probably wouldn't even help the car avoid building up a charge.
The potential difference is between you and your car not the car and the ground. Tap the window or part of the metal bodywork with a knuckle as you get out. Or get some of that anti static fabric spray and spray your seats.
Old 12-14-2001, 10:40 PM   #24
wrxguy
Member#: 12189
2002 WRX sedan
Lightbulb me tooo
I get zapped closing my door as my feets is on the ground
hmmmmmmmm
wrxguy is offline   Reply With Quote
Old 12-14-2001, 11:06 PM   #25
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
My alarm has remote window rollup. I usually drive with the window down and the heat up. Don't ask why, it's a guy thing and we have no idea why we do it. Anyway, my windows are usually down when I get out of the car. I am holding the top of the door in the middle usually when I get out. I have yet to be shocked by my suby. My passengers, however, always get shocked. HEHE
Drac9 is offline   Reply With Quote
static shocks!!! Doughboy Car Audio, Video & Security 2 03-11-2003 02:21 AM
solution found: impreza electro static shock lstepnio General Community 72 03-11-2002 12:14 AM
Static Shock DCC Newbies & FAQs 10 01-05-2002 10:45 AM
