Old 12-13-2001, 01:22 PM   #1
Oquipah
Member#: 9689
1998 Legacy GT
Question Minor Oil Leak Discovered!
Okay, I recently had the free car care clinic inspection performed by my local dealer. They sent me home and then I realize that at the bottom of the invoice sheet they noted
"a minor oil leak at the oil pump"
1. I thought the pump was located inside the pan?
2. Anyone know a ballpark cost for repair?
3. When is the STi coming?
Thanks,
Oqui
Oquipah is offline   Reply With Quote
Old 12-17-2001, 12:35 AM   #2
thng
Member#: 8062
First, I would try to cerify that myself before sweating it out...
My story is; as I was taking down my up pipe to install and egt sensor bung I noticed a little seeping (or just oil staining) at the head gasket (driver's right) towards the front.
With the exhaust manifold bolted up there would have been no way I would have seen this until it started to become a bigger leak.
It doesn't seem to be happening on the left side...
Now, I'm curious, is any one else having this happen?
thng is offline   Reply With Quote
Old 12-17-2001, 11:07 PM   #3
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
You may still be under warranty first off. Second if it is minor wait til your t-belt is changed ( it will save you around 200 labor)
Old 12-19-2001, 12:08 AM   #4
Gmachine
Member#: 8789
2006 Legacy Spec B
I just had the oil pump changed out on my 2000 legacy outback.
The work was covered under warranty. While doing my last oil change @ 36k miles I noticed oil starting to coat the underside.
The dealer suggested since they were going in,I could have the
T-belt and Drive belts changed out for just the price of the parts
(which I get for 20% off )
Gmachine is offline   Reply With Quote
Old 12-19-2001, 01:40 AM   #5
Oquipah
Member#: 9689
1998 Legacy GT
Unhappy
Hopefully the repair is covered in my extended warranty (3rd Party).
Next time I go in for an Oil change and maintenance schedule I'll probably get it fixed.
What does that run $$ ?
Thanks for the responses.
Oqui
possible oil leak and radiator leak MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2006 08:23 PM
source of leak, discovered. subajew Normally Aspirated Powertrain 4 08-13-2005 02:47 AM
weird oil leak/AC leak? NateDogg Service & Maintenance 2 05-03-2004 05:23 PM
Long-term effects of minor uppipe leak treybomb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-25-2002 01:55 PM
is it bad to drive around with a minor exhaust leak? WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-15-2002 10:54 PM
