Old 04-18-2007, 12:34 AM   #1
slayers_x
Member#: 101220
MY05 imprezaRS
riding on open diff
Default 2 Different Sets of Tires
I been reading around the forum that having two different sets is bad and can mess up your center differential for the STi and the WRX follows somehow. 1/4" rolling circumference...
WRX = front open diff and rear vLSD
STI = front LSD center diff and rear LSD
GC RS = front open diff and rear vLSD
GD RS = front and rear open diff
i'm just wondering how does it affect me since i have the GD RS with both front and rear open diffs. it is okay to run? or will i somehow out of nowhere destroy my diffs?
slayers_x is offline   Reply With Quote
Old 04-18-2007, 02:35 AM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
The important think is the 1/4" rolling circumference. If you absolutely have to use 2 types of tires, measure the circumference of all 4 and make sure the lowest number is within 1/4" of the highest number.
Also, try to keep the same type of tires all around - it wouldn't be smart to run snows in the front and azenis in the back, for example.
rougeben83 is offline   Reply With Quote
Old 04-18-2007, 07:49 AM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
It's the CENTER diff you will hose
UkNuck is offline   Reply With Quote
Old 04-18-2007, 08:56 PM   #4
slayers_x
Member#: 101220
MY05 imprezaRS
riding on open diff
where's the center diff for an RS?
Old 04-19-2007, 06:38 AM   #5
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Rtfm. . The front and rear diffs don't matter in this case. What matters is your center diff will be trying to equalize the speeds of the front and rear tires all the time causing it to work harder.
waktasz is offline   Reply With Quote
Old 04-19-2007, 08:48 AM   #6
Howl
Member#: 57830
In simplistic terms, as the power comes out of the transmission is goes into the center diff, which splits the power between the front and rear driveshafts. The power going along the front driveshaft is split again at the front diff sending power down each of the front axles, and the power going along the rear driveshaft is split again at the rear diff sending power down each of the rear axles. If you use tires of different sizes the axles will be trying to move at different speeds. Axles can move at different speed for short periods of time, but if they are forced to spin at different speeds for a long period of time heat builds up in the diff and it fries.
If you put one smaller tire on one side of the car and one larger one on the other the axles on either side will be spinning at different speeds and your front or rear diff will fry. If you put two smaller tires on the back and two larger tires on the front (or vis versa) the front drive shaft and the rear drive shaft will be moving at different speed and that will fry your center diff.
Howl is offline   Reply With Quote
Old 04-19-2007, 10:48 PM   #7
MPEJ20
Member#: 93697
2015 WRX Limited
CWP
Default im having the same problem
i got a flat tire a month ago and had to replace it with different manufacturer tire, same size but different tread and speed rating....i ve been driving on it for 2000miles so far...how close am i to damaging my center diff??? getting scared and ordering pirelli pzero nero today....help!!!
MPEJ20 is offline   Reply With Quote
So how bad is it really to have 2 different types of tires on the front and rear? 0260B4U Tire & Wheel 4 10-01-2008 12:09 AM
How bad is it really, to have 2 different sets of tires on an AWD car? WhiteFox Tire & Wheel 12 03-19-2008 03:22 PM
2 different sets of tires on a gc jakeachy Newbies & FAQs 6 11-26-2007 09:08 PM
stupid question, ok to run 2 diff sets of tires? Ghost Rider Tire & Wheel 9 10-13-2006 03:27 PM
100,000 mile warranty + 2 free sets of tires.. alacrity024 Off-Topic 2 12-17-2004 12:53 PM
