Old 04-18-2007, 04:03 AM   #1
EBWRC#1
Member#: 86843
Io Sono
a 500 Driver !
OMGHi2U How good are those Cobb sway bars?
I'm almost at the verdge to order a sway bar package from Cobb. They supoused to be 25 adj rear and 25 front, if I'm not wrong.
Does somebody have them here that can chime in, and explain me his/her experience with this set up?
Have a nice day!
EBWRC#1 is offline   Reply With Quote
Old 04-18-2007, 06:55 AM   #2
snubie
Member#: 138182
2005 WRX Wagon
psm
Love em on my wagon. These were my first suspension mod and they made a difference (tighter feel altogether, reduced understeer and it felt planted in turns). They are spendy for the kit but worth it IMO.
snubie is offline   Reply With Quote
Old 04-18-2007, 08:15 AM   #3
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Swaybar FAQ covers these bars specifically as well as how to choose swaybars:
http://forums.nasioc.com/forums/show....php?t=1152714
Old 04-18-2007, 10:06 AM   #4
kappathirteen
Member#: 124931
2004 STi
2011 Foester XT
I just ordered them, They seem like a great choice from what I have read about them. I look forward to testing them out. Ill post back when they are on. Good luck.
kappathirteen is offline   Reply With Quote
Old 04-18-2007, 10:09 AM   #5
uathatis
Member#: 117300
as good as the hotchkis bars would be :P
keep in mind they are 25 mm hollow. which makes them not as stiff as a 25mm solid
uathatis is offline   Reply With Quote
Old 04-18-2007, 11:09 AM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
They are equivalent to 22mm solid bars.
Tony
Old 04-18-2007, 01:21 PM   #7
boxered
Member#: 61884
I've had a COBB bar on the front now for 2+ years, no problemo.
boxered is offline   Reply With Quote
Old 04-18-2007, 02:10 PM   #8
EBWRC#1
Member#: 86843
Io Sono
a 500 Driver !
You are fenomenal!!
Old 04-18-2007, 02:18 PM   #9
Matt92530
Member#: 94085
2009 BMW 335i
Cloud Gray
Whiteline
Matt92530 is offline   Reply With Quote
Old 04-18-2007, 02:29 PM   #10
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
If your car is an 02 sedan then i'll buy your rear sway bar. PM me for details.
nicholam is offline   Reply With Quote
Old 04-18-2007, 03:30 PM   #11
Geeoff
Member#: 106439
06 WRX TR
'05 Matrix XRS
I've had the Cobb sway bar set with kartboy rear endlinks for a year now and I love them.
Geeoff is offline   Reply With Quote
Old 04-18-2007, 03:43 PM   #12
uathatis
Member#: 117300
Originally Posted by Matt92530 View Post
Whiteline
seconded
Old 04-18-2007, 05:04 PM   #13
orvtech
Member#: 115602
they have clearance problems with angled exahust such as HKS
orvtech is offline   Reply With Quote
Old 05-21-2007, 08:21 PM   #14
SoloSTI
Member#: 113854
2004 Impreza STI
2004 Subaru WRX STI
I just bought the Cobb rear sway bar and they were much better looking quality than the Whiteline.
However the instructions were not too bad, but installing it was a different issue the bar itself measured outside to outside is almost the same as the stock one. But the points where the bushings go is too close to the bend on both ends of the sway bar. The bushings if mounted with the slit facing front would not close (the gap with the slit) because it is sitting at the start of the radius of the bar instead of being in a straight line.
Even with the clamps fully tightened the outer end of the bushing would not touch or close.
Now another problem is that when I make a right turn and hit some bumps something in the back makes a thumping sound. I looked under the car today and I think it might be hitting the plastic that shield the fuel filler pipe.
I have stock struts with pink springs. Aftermarket end links from Turn in concepts I think this are Kartboys. Stock exhaust.
My car never made this sound what could it be? Any ideas?
SoloSTI is offline   Reply With Quote
Old 05-21-2007, 10:04 PM   #15
Blue5spdWRXWgn
Member#: 93606
2002 WRX Wagon - WRB
2005 9-2X - SGM
Bars are often designed with the bend starting inside the bushing as you describe. The purpose of doing this is to keep the bar from walking or shifting laterally out of position.
Blue5spdWRXWgn is offline   Reply With Quote
Old 05-22-2007, 12:20 AM   #16
WRXBob
Member#: 12455
02 WRX
Cobb sway bars, installed for 10k miles, no problems, no noise, no clunk just performance. The rear bar mounted so solid that I believed it actually acts as another control arm.
WRXBob is offline   Reply With Quote
Old 05-22-2007, 01:08 AM   #17
uathatis
Member#: 117300
Installed a rear one someones car the other day, i was impressed with how light it was. we put it on full soft on an 04 sedan. only thumbs up from the person i put it on
Old 05-22-2007, 01:12 AM   #18
wrXmon
Member#: 115454
My '02 WRX Wagon
is being freshened up.
I have a set to put on my wagon.
wrXmon is offline   Reply With Quote
Old 05-22-2007, 01:22 AM   #19
uathatis
Member#: 117300
dude... idk about the cobb front swaybar. on wagon.. it'll put your stock endlinks at a weird angle..
(even wagon swaybars upgraded have been known to bust the front endlinks at like 3k after... oakos.com has some 69$ beefy GC front endlinks).
If you want to go crazy you could grab poser's 27 mm with endlinks (in txic classifieds) for 200 bucks and sell that front bar...
Or just try and find a adj 22 mm whiteline wagon front bar.
pm me if you want any help on that swaybar stuff. i'm in the area
Old 05-22-2007, 08:12 PM   #20
wrXmon
Member#: 115454
My '02 WRX Wagon
Originally Posted by uathatis View Post
dude...
I will take you up on that offer, man. I have a pair of Perrin front end links to go with them.
Old 05-22-2007, 09:37 PM   #21
uathatis
Member#: 117300
One thing man. that cobb front swaybar isn't meant to fit the wagon
it MAY fit. but it may fit weird..ish. whiteline is the only company that makes a wagons specific front bar. a 22 and a 22 adj bar.
Rear is 100% ok though
Also if you bought front perrin endlinks. i'm not sure of the fitment of those on a wagon either. Either way i'm sure you'd be able to sell the cobb bar and front endlinks for a decent price in the classifieds/txic and get some noltec front wagon endlinks from oakos.com... (cheaper than those perrin ones. but fit and are just as good.
turninconcepts.com has good prices on front wagon swaybars also
this is all mostly because the wagon has a different front suspension (gc vs gd)
Old 05-28-2007, 12:37 PM   #22
GeneJock
Member#: 54570
2013 135is conv
Default Ditto on my 2007 STI
Originally Posted by SoloSTI View Post
2004 Subaru WRX STI
Same deal exactly. Bushings were into the bend of the bar. Problem is when you torque to 30 ft.-lbs. it looks as if the bushing may be cut by the bracket. Someone at Cobb said the mounts AND the bushing bracket are directional but I don't see it, though I'll try anyway. I'm also getting the clunking from the rear. I'm hoping that pulling and re-greasing the bushings and trying the bushing brackets in different orientations will help. We'll see.
GeneJock is offline   Reply With Quote
Old 07-07-2007, 03:25 AM   #23
SoloSTI
Member#: 113854
2004 Impreza STI
It is strange because only on right hand turns especially when road surface is bumpy.
COBB sway bars - Stiffness of hollow vs solid bars? ringmaster Brakes, Steering & Suspension 25 07-07-2015 02:43 PM
cobb springs or cobb sway bars MPEJ20 Brakes, Steering & Suspension 10 07-05-2007 04:56 PM
SIMPLE QUESTION! How big are stock STI sway bars? 1FSTREX Brakes, Steering & Suspension 1 10-20-2006 07:19 AM
What size are the stock sway bars? corallo99 Brakes, Steering & Suspension 10 06-14-2001 09:05 AM
Just how bad ARE those cold starts? 8Complex Normally Aspirated Powertrain 23 12-20-2000 07:08 AM
