Old 04-18-2007, 08:06 PM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default Blowing the main fuse to ECU everytime I turn the key
1990 Legacy.
So I pulled the motor out and replaced a piston this weekend.
Reinstalled the motor Sunday. Fired it up about 10-15 times with it still on jack stands until today, when I set it down, AND CLOSED THE HOOD.
Then I turned the key and the 30 amp fuse popped. Scrounged another and stuck it in. Made it down the block. pop. pulled it out, replaced it. pop.
Went and found some more fuses (they are $3.99 each!). Replaced fuse.
Drove about 40 blocks, and 1.5 blocks from the shop, pop. Replaced fuse. pop.
I am out of fuses.
So.....This is the fuse for the power to the ECU. I must have a short somewhere, but when i use the multi-meter, nothing shows up...
Any ideas?
and yeah, I am going to have to tear out the underside and ECU to check ALL the wires.
Old 04-18-2007, 11:48 PM   #2
Arctic Penguin
Member#: 119532
2006 WRX
find the pinched wire
Arctic Penguin is offline   Reply With Quote
Old 04-19-2007, 09:26 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
It was a injector wire. They are hot hot hot off of the ignition relay. But before I figured it out, I fried the ignition relay, so off the to the junkyard to salvage an ECU, and the three main relays that are situated up there.
It runs again.
Stupid Question: Can you use the FWD fuse to drive the car every day? Koss Normally Aspirated Powertrain 21 12-11-2012 01:02 AM
Whats the best way to get a deal at the Borgata? MidnightSti05 Off-Topic 12 08-18-2009 10:36 AM
whats the cheapest way to switch btw maps on the fly?? BoGWAgon Engine Management & Tuning 6 05-20-2007 12:01 PM
I'm gonna pistol whip the next person to make a plane on the treadmill joke Georgethefierce Off-Topic 24 01-18-2006 11:15 AM
