Old 04-19-2007, 09:50 AM   #1
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
Default 07 WRX VF39 tuned by Hill at Agile
First off i want to thank everyone at agile, from the front desk to the guys working in the bays. Jeremy installed my turbo and boost solenoid all with me looking over his shoulder and asking questions and was very informative and very nice. We had a little scare with coolant burning but Hill found the leak and got to tuning. The whole crew even stayed well after they're supposed to close to get everything bolted back up after the tune. now on to the tune
Hill tuned my car and unfortunately we didn't get stage 2 numbers but it would've been nice to see them if i had known what kind of numbers the 39 was going to put down.
VF39
STi TMIC
COBB Catless TBE
GM Boost Solenoid
SPT intake and Heatshield
NGK 1 step colder plugs lfr7aix
Walbro 255lph fuel pump
Cobb AP V2
-First run 292 wtq 292whp or something close to that
-Final run 338.x wtq 317whp
-Fun run with ice on the intercooler(it was heatsoaking) and boost turned up a bit 357 wtq 325whp
we had the torque number up to 348 and hp at 312 but there was a sizeable bump in the torque curve so i decided to go with the smoother curve and less torque. i'll try and scan the dyno chart in, unless hill can post it for me. this was all on 93 pump gas, i forgot to ask what the IDC's were(maybe 90), but the stock injectors were great and flowed very well, as they are supposed to flow better than STi injectors. boost curve was as smooth as could be, target boost was around 19-20 i believe, 11.2 AFR's.
Hill said these were probably the highest numbers he's seen on a 2.5L WRX with the 39. thanks again to Agile Auto. Can't go wrong with these guys.
ray101381 is offline   Reply With Quote
Old 04-19-2007, 10:01 AM   #2
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
wow, nice tq numbers!
TopEndPull is offline   Reply With Quote
Old 04-19-2007, 10:22 AM   #3
WRX Shenanigans
Member#: 101378
Very nice! Can you post the dyno graph?
WRX Shenanigans is offline   Reply With Quote
Old 04-19-2007, 10:23 AM   #4
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
yup i'm trying to find a scanner, worst case i'll take a picture with my camera.
Old 04-19-2007, 10:26 AM   #5
WRX Shenanigans
Member#: 101378
That's what I did
Old 04-19-2007, 01:44 PM   #6
rhinotech
Member#: 144880
03 Civic
Rollin' hard...
Are you not worried about your 5spd tranny? I've listed my mods below. I talked to a local tune shop (MZM) and I was told that the transmission in our cars wouldn't handle 300whp/wtq. They have a Mustang dyno so that might be the reason (their dyno reads an average of ~20% less than others). Did you do any research or have any troubles with your tranny as of yet? Let me know, im curious!
2006 WRX
VF39
AccessPort v2 (VF39 map right now)
Perrin 3" DP/Knife 3" Custom Exhaust/4" Magnaflow Tip
Walboro 255lph FP
APS Cold Air Intake 65mm
rhinotech is offline   Reply With Quote
Old 04-19-2007, 05:18 PM   #7
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
from what i've read the 05+ transmissions are significantly stronger than the previous years. that being said i think alot of transmission failures are driver negligence and error. I know people with 03(the weakest trans) with big 16g's, vf30's and 34's that run high 12's and low 13's that are still on the stock clutch and trans. i think as long as you don't dump the clutch at 5000rpms and learn to drive i think the trans will last a very long time with my power levels. that being said i'm deciding on a 6speed swap or 1-4 helical ppg's.
Old 04-19-2007, 05:22 PM   #8
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
hmmm.... those are pretty high numbers for just a stage 4 wrx... thats basically an sti with a turbo back...
it gives me an all new respect for the wrx... great job on those numbers.
better get that 6speed in that thing...
All4bSpinnin is offline   Reply With Quote
Old 04-19-2007, 05:24 PM   #9
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
tha transmission will be fine as long as you dont slam it into second gear....
Old 04-19-2007, 05:25 PM   #10
Sypher
Member#: 106366
2006 WRX
pshhh it might not be able to handle a 20g or bigger but I have 40k miles on my 06WRX and I had my vf39 at 10k miles and went back to stock turbo at 38k miles with not a hint I mean a hint of tranny problems. And Ive pulled off a 1.5 60ft with the damn thing, banged gears, gotten side ways and all sorts of horrible and dangerous crap that no human should be doing with a subie and shes still tough as a rock. Might I add I made 305whp and 350ftq with the vf39 so hes pushing basically the same amount I was. His tranny will be fine if he knows how to drive his car. Oh yeah is this the dude wtih the black one with an sti wing? This is the guy wtih the 06 with the front mount. I think I met you at the subie meet at red robin.
Sypher is offline   Reply With Quote
Old 04-19-2007, 05:26 PM   #11
Sypher
Member#: 106366
2006 WRX
eh go wtih an 07 Sti 6 speed if you can fine em, PPG's are pimp YO but overkill.
Old 04-19-2007, 05:34 PM   #12
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
Dyno Charts are up
Old 04-19-2007, 05:54 PM   #13
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
yup it's the black one with the sti wing, what's up tre. steve needs that clip thing for his accessport
Old 04-19-2007, 07:49 PM   #14
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Kindof.
I was stg 2 with plenty of hard 1-2's with no problems.
Just watch out for 3rd dying for no apparent reason..
ExpO is offline   Reply With Quote
Old 04-19-2007, 08:00 PM   #15
Sypher
Member#: 106366
2006 WRX
clip thing? you mean the jumper o_O? I gave that back to him months ago after I tuned andrews car. And whats up man! post up pics of your car and the engine bay so these guys can drool over it, his 07 Is SEXY.
Old 04-19-2007, 09:52 PM   #16
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
2006 WRX
VF39
Walboro 255lph FP
buschur racing dyno'd 389 wftq and something like 312 or so whp on a mustang dyno with their 06 wrx and they've been tracking the car beating on it what not.... its holding up like a champ.
IT'S ALL HOW U DRIVE THE TRANNY!!!!!
I had a stock rs tranny in my build 2.5rsti and it held up to over 400 ft tq and 350 +whp enough said
mxturboracer86 is offline   Reply With Quote
Old 04-19-2007, 11:54 PM   #17
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Great numbers man...get that sucker to the drag strip soon.
And plus 1 on the "tranny will be ok" coments. Diver errors kill the trannys, that and the fact that 90+% of the broken trannys were the 02-03 guys. My 05 has held up so far to about 160 hard passes at the track, with the car in varying stages of modification, from stock to stage 4. The car has run as fast as [email protected] and I shift the crappers out of it. Only recently did I order a new clutch, and that was only to have it handy when the OE clutch finally goes out.
Again, nice numbers, I'm loving the simplicity of the 06+wrx set ups
congrats!
Trey
treystoys is offline   Reply With Quote
Old 04-20-2007, 12:22 AM   #18
Dizzuque
Member#: 98699
2007 SWP WRX
Wow, makes me regret selling my vf39. Awesome numbers.
Dizzuque is offline   Reply With Quote
Old 04-20-2007, 12:25 AM   #19
06CGMREX
Member#: 137777
06 Totalled WRX
'92 Silvia drift Slut
I'm going to guess that dyna packs read higher than dyno jet's and mustang dyno's?
06CGMREX is offline   Reply With Quote
Old 04-20-2007, 01:12 AM   #20
treystoys
Member#: 97436
03 toyota tundra
"I'm going to guess that dyna packs read higher than dyno jet's and mustang dyno's?"
Yes, but that said, its still a solid 300whp car
Old 04-24-2007, 01:14 AM   #21
Mooneyes13
Member#: 113666
60' all over you
what year is your tmic from? did you change the air spilter?
Mooneyes13 is offline   Reply With Quote
Old 04-24-2007, 08:15 PM   #22
Rippen Griffen
Member#: 91708
AD Motorsports FTW
06 OBP - Cobb AP Stg 2
Gonna have to come up and visit to get a ride in the "+300 whp club" car! Congrats Ray!
Rippen Griffen is offline   Reply With Quote
Old 04-24-2007, 08:21 PM   #23
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
my tmic is from an 06 sti, i changed the splitter and bellows to the 06 sti for proper fitment and air flow
Old 08-18-2007, 08:50 AM   #24
vicore_wrx
Member#: 63840
2003 wrx
rally blue
I want a 2.5. I still have a 2.slow
vicore_wrx is offline   Reply With Quote
Old 08-18-2007, 12:23 PM   #25
sperry7
Member#: 110079
06 WRX
Black on Black
LOL their car blew up the transmission while it was on the dyno.
Good one!
sperry7 is offline   Reply With Quote
07 WRX 18g'd Tuned by 555 Motorsports 07HaWkEyE Proven Power Bragging 31 04-23-2010 12:30 AM
07 WRX VF39 Tuned By EQ Tuning Boost_Creepin Proven Power Bragging 24 03-10-2009 01:55 PM
07 wrx 20g tuned by Bobby at PRE sub-e90 Proven Power Bragging 17 10-23-2008 01:05 AM
2.0 vf39 tuned by Andy at Verocious pearljam11 Proven Power Bragging 5 04-03-2008 09:15 AM
06 WRX VF39 tuned by Hill at Agile Matt_H Proven Power Bragging 8 08-22-2007 07:11 PM
