04-19-2007, 10:39 AM | #1 |
Member#: 15607
Vehicle:I'm not the type to make angry |
95' 2.2 w/ 98' DOHC 2.5 heads?
Ok boys and girls here's my thing.
I've got a really low milage 2.2 n/a engine, a set of really crazy 98' DOHC heads and way too much time on my hands The 2.2 block is a 1995 and 9.7:1 according to factory specs. Combustion chamber size is 40cc (?) on the 2.2 heads and 46cc (?) on the DOHC heads. Doing some rough math this will knock the compression ratio down to about 9:1 (roughly). What are some of my options in the way of getting the compression up without doing pistons? Milling the heads .030 = .20 up in ratio Thinner Head gasket = Unknown due to inability to find a thinner gasket info? Now my other option is to close up the compustion chamber by welding, not my favorite option. Anyone tried this combo with any success? Anyone have any gasket info or links? Thanks, Dylan
04-19-2007, 02:03 PM | #2 |
Member#: 106225
Vehicle:02 WRX STied PSM 03 L, 05 GT Legacy Wagons |
Just put a turbo on it and call it a day!
Ryan |
04-19-2007, 05:34 PM | #3 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
I ran 98 DOHC heads on a 94 Legacy turbo short block. In my 98 RS oh but i had a big turbo too
04-19-2007, 05:48 PM | #4 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
yep,
Really the only way to do this build properly is to slap a turbo on it. Otherwise you need custom pistons. Thin HG's or shaving the heads are both questionable approaches... |
04-20-2007, 12:05 AM | #5 |
Member#: 15607
I agree, but was just looking for a decent temp motor till I get my H6 ready to go in.
04-20-2007, 12:23 AM | #6 |
Member#: 60122
NWIC
Vehicle:1986 911 Turbo Guards Red |
H6 will be teh SEX
04-20-2007, 11:54 AM | #7 |
Member#: 832
RMIC
Then just slap it together and run it NA. It won't be a rocket ship, but it won't suck ballzors either...
Would DOHC NA 2.5 heads work with STi 2.5 block? | 2slofouru | Subaru Conversions | 11 | 02-21-2007 01:04 PM |
1997 Dohc 2.5 with 1997 2.2 Heads? | narib2001 | Normally Aspirated Powertrain | 3 | 01-23-2007 01:01 AM |
2.0L with 16g or 2.5? | 2mprzya | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 12-25-2006 08:49 PM |
Will a DOHC f2.5 intake manifold bolt up SOHC 2.5 heads | w chapman | Normally Aspirated Powertrain | 9 | 10-11-2005 10:24 PM |
DOHC 2.5 head gaskets!!!!!!! | joemamad | Legacy Forum | 13 | 10-25-2002 05:36 PM |
