Old 04-20-2007, 07:49 PM   #1
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Default Crank/no start - no spark - ideas?
Finally swung the motor in - as far as we know all plugs and wires are hooked up properly. Tomorrow morning we'll be checking fuses, etc. I'll bring the laptop and cable to see if DeltaDash could tell me anything. I hope my aftermarket alarm isn't doing something silly.
Is there anything specific these cars are known for doing when sitting for 6+ months?
EDIT: My dumb ass missed that FAT ground wire bundle that attaches to the driver's side of the intake manifold..
PeteDucati is offline   Reply With Quote
Old 04-20-2007, 08:34 PM   #2
Peeblesmx445
Member#: 92202
I lost 4 coil packs after my sat for a year......
Peeblesmx445 is offline   Reply With Quote
Old 04-21-2007, 02:43 AM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Check those the fuses in the engine bay, or where ever they may be located. The main ones for the ECU.
Old 04-21-2007, 07:19 AM   #4
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
We'll be checking the fuses, follow the harness to make sure nothing was pinched or not connnected, and I'll make sure I check the crank sensor.
Another screwy thing.. my gas gauge reads dead empty - pretty sure the tank was damn near full when the motor popped.. I can't imagine how fuses blew while the car was sitting?!?
Old 04-21-2007, 12:45 PM   #5
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
That large ground wire was never bolted to the manifold - I'm an ass.
Old 04-21-2007, 10:23 PM   #6
Jasper
Member#: 80136
2006 Ford F-150
dont feel bad. my first motor "failure" ended up being a blown off IC pipe that i found WAY after i'd already ordered everything (i was sorta hoping for it...cause i wanted to rebuild w/ cams )
i wish my recent screw up was something simple. i lost a HG. theres no explaining that one lol.
Jasper is offline   Reply With Quote
Old 04-22-2007, 04:48 PM   #7
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Water in the gas tank separates and you start sucking in bad gas. I've had a WRX sit for two periods longer than that and the only problems I had were the rotors oxidized and the gas was crap.
cdvma is offline   Reply With Quote
Old 04-23-2007, 06:58 PM   #8
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
Default well?
did it fire up?
Old 04-23-2007, 06:59 PM   #9
babyblue22681
Member#: 51981
03 fast wrx-e55
blue/desert silver
i did that same mistake.....
babyblue22681 is offline   Reply With Quote
Old 04-24-2007, 06:33 PM   #10
STi_Guy04
Member#: 69461
2004 WRB/Sti
11.41 @ 123mph
what do you mean you lost 4 coil-packs, I belive i have some faulty ones as well, what where some of the sympotms your car had when your coils where bad?
My car runs fine when its the motor is cold, it revs freely, Once it gets warm, it will not rev over 3k horrible bucking and stumbling rpm needle jumps around between 2800-3300 Sounds like misfires maybe, sometimes backfires
and it seems to be getting worse, funny thing is that this only happens after 5-7 mins of driving and gets worse untill the car is not drivable?!?!
if anyone has any related issue to this please PM me or give your ideas!!
STi_Guy04 is offline   Reply With Quote
Old 04-27-2007, 07:13 AM   #11
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Originally Posted by jaxscuby View Post
did it fire up?
It fired right up - but it really needs to be tuned.. it's running pig rich.
Old 04-28-2007, 04:08 PM   #12
jnizzle
Member#: 145766
2002 wrx
black
i dono if anyone said this but check your crank gear sensor and or you crank gear when i put mine back it 2 teeth broke off and it wouldnt start for days and finally someone relized that i have teeth missing so i replaced timed and now it runs but now i have a bent valve....oh well fixable!
jnizzle is offline   Reply With Quote
Old 04-29-2007, 04:29 PM   #13
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
...and the compression check I did today came back positive for uneven compression - 90, 120, 140, 140 - less than 100miles on the motor.. it was cranking funny even before we got it running.
Newly assembled hybrid with cranking and no start and no CEL, suggestions? 240sxguy Built Motor Discussion 7 08-20-2012 10:00 PM
No Crank no start mmkay? Trogasarus Electrical & Lighting 3 11-19-2009 11:45 PM
No start, no accessory power Please help tunertrends Electrical & Lighting 3 07-14-2007 12:19 PM
Crank, spark, no start condition - Timing belt dominantset Normally Aspirated Powertrain 4 04-25-2007 04:29 PM
no spark & no fuel = no start Annoying Eric Normally Aspirated Powertrain 7 08-30-2005 08:58 AM
