Old 04-21-2007, 02:08 AM   #1
nerdydorkus
Member#: 67062
Default Can I use Liquid Gasket Sealant on OEM Gaskets?
I'm getting ready to do my up/down install tomorrow morning and I got everything I need. I bought new oem gaskets for the uppipe and I also bought "Hi-Temp RTV Silicone Gasket Sealant." Is this stuff safe to use with OEM gaskets. It says put a thin even coat to one side of the gasket, put it on the uppipe, then coat the other side of the gasket. I bought this stuff for a little extra insurance against leaks. It also says safe to use on paper or composite gaskets.
Let me know if I should use this stuff.
Thanks in advance.
nerdydorkus is offline   Reply With Quote
Old 04-21-2007, 04:39 AM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
you want the stuff in the copper colored tube, not the red or black.
it's way more durable on exhaust parts.
By the way, it works best if you let it cure for at least 10 minutes before putting the gasket in place. Coat both sides thinly (you can hold the gasket by the edges) and then hang it on a hook on your wall or something to let it dry for a few minutes.
nhluhr is offline   Reply With Quote
Old 04-22-2007, 02:37 AM   #3
nerdydorkus
Member#: 67062
thanks, i took your advice and returned the black stuff i initally bought and got copper gasket sealant. I started up the car with no leaks at all. Only thing is this stuff takes much longer to cure. 2 hrs to set and 24 hours to cure. Have to make sure it cures fully or splatter might get into the turbo from the uppipe.
Dont laugh at me it took me 9 hrs to finish my up/down install. I overkilled everything (locktite on everything, torque everything to exact spec, anti-seize lubricant, copper gasket sealant) and wanted to make sure everything was perfect. I even modified the stock downpipe heatshield (with the shape of the cat) along with the turbo heatshield to fit the new downpipe.
Old 04-22-2007, 12:41 PM   #4
tube
Member#: 139485
2004 16g WRX DomTune
Java Black Pearl
Nice job, now when you go to upgrade your turbo, it will be an even bigger pain in the ass!
I hope you know loctite breaks down at 400 degrees... You don't think your exhaust parts get that hot?
tube is offline   Reply With Quote
Old 04-22-2007, 01:32 PM   #5
nerdydorkus
Member#: 67062
uhh, didnt know that. now i feel stupid. oh well =P
Old 04-22-2007, 02:05 PM   #6
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
It's ok... just check the exhaust bolts/nuts after you've driven a couple times... make sure they are all there and all still tight.
Old 04-22-2007, 04:35 PM   #7
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I've found that the recommended torque settings are adequate so even with loctite failing, you should be ok since you torqued them properly. I've yet to see anyone I've installed an uppipe for come back with leaks and I've never used any extra stuff so you should be good. Feels good to be done doesn't it?
cdvma is offline   Reply With Quote
Old 04-22-2007, 08:03 PM   #8
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
You may also be interested to know that the copper gasket maker is only good to 700F.
jac04 is offline   Reply With Quote
Old 04-22-2007, 08:20 PM   #9
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
which is just fine for most of the exhaust. It's used more as a filler material to pack into the little crevices that might turn into leaks down the road.
Old 04-22-2007, 08:22 PM   #10
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
APS recomends you use that copper gasket stuff without a gasket if you have aps exhaust and a turbo. I was wary but after 5000 miles it's held up fine.
nicholam is offline   Reply With Quote
Old 04-22-2007, 09:34 PM   #11
jac04
Member#: 49895
09 Forester
I agree, but he was specifically talking about using it on the uppipe. Even the high temp RTVs tend to turn brittle over time at those temps.
Old 04-22-2007, 09:52 PM   #12
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I use it on the uppipe too and although it does break down, it also contributes to a good seal by filling in small scratches or gaps that might turn into leaks later.
Old 04-23-2007, 03:36 AM   #13
dankEe
Member#: 97958
ASPEN
9 hours?
wow
lol
alot of breaks huh
- Danny
dankEe is offline   Reply With Quote
Old 04-23-2007, 04:28 PM   #14
nerdydorkus
Member#: 67062
Originally Posted by dankEe View Post
9 hours?
wow
lol
alot of breaks huh
- Danny
actually no, i am just really a perfectionist.
Old 04-23-2007, 04:39 PM   #15
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I work really slow too when I have no time constraint
Old 04-23-2007, 06:50 PM   #16
REDI-wgn
Member#: 38068
03 WRX Wagon
Is that the spray one that you used ?
Reason I ask because i use the spray one and its definitely not that long to cure
REDI-wgn is offline   Reply With Quote
Old 04-24-2007, 03:13 PM   #17
nerdydorkus
Member#: 67062
nope, no spray. i got the tube one and spreaded it evenly on the gasket with my fingers. then i knifeedged the inside hole of the gasket to remove excess sealant.
Should I apply gasket sealant on intake manifold gasket? gopsu Newbies & FAQs 0 07-30-2009 11:54 PM
What can I use to record audio on my comp? Stroke Off-Topic 4 08-13-2004 02:03 PM
Sealant on exhaust gaskets? Yay or nay? NicGordon Service & Maintenance 7 03-10-2004 01:02 PM
Can you use normal crush washers on Fumotovalve? garface Service & Maintenance 12 11-14-2003 02:29 PM
Can I use 2.5L clutch on 2.2L tranny??? Aspen Normally Aspirated Powertrain 2 12-12-2000 10:04 PM
Message Board Statistics All times are GMT -4. The time now is 10:36 AM.
