Old 04-21-2007, 12:40 PM   #1
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Default APS TGV Delete servo install help!!!!!!
which way do i line up the teeth on the APS servo to the sensor gear????
All4bSpinnin is offline   Reply With Quote
Old 04-21-2007, 01:18 PM   #2
STIBungy
Member#: 51684
The sensor should start off closed.
STIBungy is offline   Reply With Quote
Old 04-21-2007, 01:25 PM   #3
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
The sensors are not on the TGV's... ive got em plugged into the box on each side, when i put the sensor with the larger clip on, should i put it on at an angle and it should have a hint of resistace?
Old 04-21-2007, 01:27 PM   #4
Freon
Member#: 88322
2009 BMW 135i
If you have a DBW car you can just flash the CELs off and remove the sensors and motors completely with no ill effect.
Freon is offline   Reply With Quote
Old 04-21-2007, 01:54 PM   #5
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
ya i know, but nobody in town can flash em and i already bought the TGV servos...
ok, i got the servo's on, they cleared the code... so i took it down the road drove around for a minute and then hit WOT, once i did that the car still felt like it was in limp mode and then BANG, car shut off, and limp mode was back...
i cleared the code, im gonna go pick up an OBD2 scanner for when it does it agian.
This means that one of two things could be happening...
1. the tuner that i saw 2 weeks ago about clearing the code erased my tune and the car is boost spiking agian or...
2. I just dont have the TGV servo's installed to where the TGV sensors believe that the throttle is opening up all the way...
FS: APS TGV delete Servo Couplings meo Engine/Power/Exhaust 1 03-05-2010 01:22 PM
FS: APS TGV delete Servo Couplings meo Tri-State Area Private Classifieds 0 03-05-2010 12:56 PM
APS TGV Delete Servo Couplers Dasani Engine/Power/Exhaust 3 12-25-2006 01:23 AM
APS TGV Delete Servo Couplers Dasani TXIC Private Classifieds 3 12-24-2006 09:12 PM
APS TGV Delete Fix / Servo Couplers engineerx Private 'For Sale' Classifieds 6 02-23-2006 01:56 PM
