Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 04-22-2007, 02:34 AM   #1
Nuke209
Member#: 108089
2003 WRX
NF Performance
Default Misfiring after spark plug change
I drive an 06 wrx and just changed plugs to copper, I gapped them at .028 and torqued them down to 17lbs
when in boost, the car misfires and I get a cel but it'll disappear
If i keep it on the gas while misfiring, the cel will stay and give me p0301 & p0302
Last edited by Nuke209; 04-23-2007 at 10:49 AM. Reason: had it at .28 when it's suppose to be .028
Nuke209 is offline   Reply With Quote
Old 04-22-2007, 05:32 PM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
are the sparks torque'd down too much or needs to be tighten more?
Old 04-22-2007, 05:41 PM   #3
koochman
Member#: 108407
16 WRX Limited
Pure Red
Also, make sure the coil packs and wires are on tight.
0301 and 0302 are misfire on cylinder 1 and 2. Cylinders 1 and 2 are the front cylinders.
F--1--3--Pass side
R
O
N
T--2--4--Drive side
koochman is offline   Reply With Quote
Old 04-22-2007, 07:30 PM   #4
shadyrex
Member#: 24540
2015 WRX
Check the coilpacks. I switched plugs on my old car and snapped one of the tiny clips that hold the wire harness to it. It took me a bout an hour to figure that one out and had to run to the dealer in the gf's car to grab another coilpack.
shadyrex is offline   Reply With Quote
Old 04-22-2007, 09:22 PM   #5
Nuke209
Member#: 108089
2003 WRX
NF Performance
the coilpacks seem fine, they snap back in and out and nothing broke off
I just took out the plugs and regapped them and retorqued them down...still same problem
Old 04-23-2007, 12:23 AM   #6
fullybuilt_07'STI
Member#: 134236
try gapping them like ten thousands smaller
fullybuilt_07'STI is offline   Reply With Quote
Old 04-23-2007, 02:39 AM   #7
koochman
Member#: 108407
16 WRX Limited
Pure Red
Hot damn, I just noticed that. Its supposed to be 0.028 - 0.031, not .28.
Old 04-23-2007, 03:17 AM   #8
NWstiLTD
Member#: 133458
2007 WRX STI Limited
"urban gray metallic"
I doubt that the gap or torque have anything to do with the misfire. Check that the wires are on tight as previously noted. Did you apply anti sieze to the plug threads? if so you may have gotten some on the porcelain portion...it will conduct and cause a misfire.
Did you pull off the metal end inside the wire at the spark plug or damage the boot?
Lastly did you change to one of those multiple tipped or funky plugs? I have found that some of those can cause strange driveability problems.
If none of these work, try taking a fluke meter and checking the resistance of the wires, the key is that none measure open or ol on the display. As long as there is some continuity you are good.
Oh, and most important!! make sure you didnt crack any of the plugs on installation, any small crack will cause a misfire (usually all the time though)
Well, that pretty much covers most of the possibilities.
Good luck
NWstiLTD is offline   Reply With Quote
Old 04-23-2007, 10:20 AM   #9
Nuke209
Member#: 108089
2003 WRX
NF Performance
Good luck
boot is fine, didn't pull no metal out of it
i did apply some antiseize but only on the thread
it is a v tip spark plug.
I will be putting back the stockers and see how they run.
Old 04-23-2007, 10:43 AM   #10
STIred05
Member#: 115223
2005 Subaru STI
Ya that would make for one hell of a miss. If you do have the plugs gaped right then I would check out the coil packs... look for arcing.
STIred05 is offline   Reply With Quote
Old 04-23-2007, 10:48 AM   #11
Nuke209
Member#: 108089
2003 WRX
NF Performance
sorry, it's .028
LOL
Old 04-23-2007, 11:55 AM   #12
WRXINTX
Member#: 96712
what plugs are you trying to run???
are these the extra long (26.4mm) thread 2.5L plugs???
WRXINTX is offline   Reply With Quote
Old 04-23-2007, 12:27 PM   #13
Nuke209
Member#: 108089
2003 WRX
NF Performance
i'm using coppers for the sti
they're the same length as my stockers
Old 04-23-2007, 12:50 PM   #14
idget_rex
Member#: 103281
I changed mine with Nuke and got the same problems.
1) I changed the stock plugs (06 wrx) to the ngk iridium made for the sti and got p0301. Stumbles hard as soon as I hit boost.
2) Retorqed the plugs and drove around. Cel came on but no code (read with AP) and no flashing cruise. Stumbles and feels like its misfiring under boost. Not as bad as before tho.
3) Replaced stock plugs and now the car runs fine.
idget_rex is offline   Reply With Quote
Old 04-23-2007, 01:06 PM   #15
koochman
Member#: 108407
16 WRX Limited
Pure Red
Post up part numbers!
Did you go colder or hotter?
Old 04-23-2007, 01:26 PM   #16
Nuke209
Member#: 108089
2003 WRX
NF Performance
LFR6A-11
should be stock heatrange
Old 04-27-2007, 10:25 PM   #17
lburrrna
Member#: 146383
2006 Subaru
WB Blue
Post
Originally Posted by Nuke209 View Post
LFR6A-11
are the stock plugs for the 06wrx platinum or iridium? do you have an NGK 1 step colder plugs part number??
lburrrna is offline   Reply With Quote
Old 04-28-2007, 11:47 AM   #18
Mr. Quick
Member#: 73496
2005 STi
Crystal Gray
does anyone know what is the stock gapping is on the STi?
Mr. Quick is offline   Reply With Quote
Old 04-29-2007, 05:23 PM   #19
stisiu
Member#: 146263
28 to 31
stisiu is offline   Reply With Quote
Old 04-29-2007, 07:12 PM   #20
Nuke209
Member#: 108089
2003 WRX
NF Performance
those plugs were copper actually
i just put oem back and everything is fine...
Bad misfire after spark plug change ... doesn't start immediately! DHutch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-21-2010 04:37 PM
Crappy Gas Mileage After Spark Plug Change Dutchman1101 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-14-2008 08:06 PM
Oil temps after Spark-plug change AmolaitoPR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-09-2006 12:27 AM
Starting problems after spark plug change ggergg Normally Aspirated Powertrain 7 09-03-2004 09:25 AM
Help! CEL On after Spark Plug change minx Service & Maintenance 5 01-08-2002 06:33 AM
