Old 04-22-2007, 02:51 PM   #1
warnockm
Member#: 65633
2002 Impreza WRX
Default Troubleshooting an oxygen sensor problem
I have a 2002 WRX and i just got a P0031 error: Heated Oxygen sensor voltage low. Theres a lot of discussion about this problem on the forums, so i'm going to follow the previous advise and check out the wiring first.
I ran into my first problem. Exactly where is the front oxygen sensor located!? I'm looking around the exhaust as it leaves the engine. I'm looking on the passenger side, and I've removed the airbox to get a better view, but i can't see anything w/ a wire coming out.
warnockm is offline   Reply With Quote
Old 04-22-2007, 04:37 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
If you remove the passenger side wheel you will see a (approximate) 1/4 circle panel in the fender well held in by 4 plastic pops. Remove that and you will get access to the oxygen sensor. It is about 4" before the start of the uppipe. You can also follow the wiring down to the sensor. The wire clips onto a bracket that shares a bolt with the passenger side rear coil pack.
cdvma is offline   Reply With Quote
Old 04-22-2007, 05:48 PM   #3
warnockm
Member#: 65633
2002 Impreza WRX
thanks. I found it just fine. All of the wiring appears in tact so i'll keep testing things.
BTW, i found this bracket literally lying on a piece of metal near the wheel. I don't think its related to this problem, but i have no idea what it is:
thoughts?
Old 04-22-2007, 10:20 PM   #4
madcat
Member#: 82465
2014 Forester 2.0 XT
MBP
I've got one of those in my parts-left-over-after-mods box. No idea where it goes. So far, the car is holding together, so I'm not too worried.
madcat is offline   Reply With Quote
Old 04-22-2007, 10:21 PM   #5
Feign
Member#: 68604
06 STi
Is it plugged in? I just did an uppipe swap and somehow ended up not plugging the thing back in.
Feign is offline   Reply With Quote
Old 04-22-2007, 10:26 PM   #6
warnockm
Member#: 65633
2002 Impreza WRX
Yes, i did check the connections at the sensor and at the connector by the airbox and they seem fine.
Theres 4 wires. The black should have power, 14V, but how can i check the readings on the sensor? is there a voltage or impedance range i should be aiming for?
Old 04-23-2007, 12:28 AM   #7
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
IIRC the sensor data is not voltage but variable current (amperage) so measuring it will require some trickery or cutting a wire in half. Best thing might be to borrow one from a buddy that is known good and swap it in.
Old 04-23-2007, 12:48 AM   #8
madcat
Member#: 82465
MBP
PM'ed relevant FSM pages.
Old 04-23-2007, 07:30 AM   #9
turd_ferguson
Member#: 114609
How many miles do you have? My factory sensor died at about 70k miles and it's been working great since I replaced it.
turd_ferguson is offline   Reply With Quote
Old 04-23-2007, 10:50 AM   #10
warnockm
Member#: 65633
2002 Impreza WRX
Just turned over 70k this month! I suspect it is the sensor but wanted to check the wiring just in case.
Old 04-23-2007, 11:07 AM   #11
Mayor McCheese
Member#: 117018
79 Rexor on Dubs
Paws McGillicutty
Just a heads up when you replace it. The front "02" sensor is called a A/F ratio sensor. Good luck.
Mayor McCheese is offline   Reply With Quote
Old 04-23-2007, 11:51 AM   #12
Feign
Member#: 68604
06 STi
http://www.wrxfanatics.com/lofiversi...hp/t21059.html
Did you check the entire length of the wires? Also, there's a small bracket that the thing is wiretied twice to. If you pull off that little plastic piece that gives access to the sensor and look up with a flashlight, you should be able to see where it's attached. Make sure it's attached to at least one of those points.
Old 04-23-2007, 01:49 PM   #13
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
There is a heating element in the O2 sensor, most likely the problem is with the senosr, the voltage low code, would happen if you have a short in the wiring, or sensor heating element. if you are getting battery voltage at the O2 plug, tap into the harness and check with the sensor plugged in, the heating element is like a filement in a light bulb, and will burn out over time, you can ohm test the sensor although I do not know what the readings are suppost to be.
crampfan is offline   Reply With Quote
Old 04-29-2007, 09:24 PM   #14
warnockm
Member#: 65633
2002 Impreza WRX
I just hooked up the OBD-II connector and checked the codes and got two codes: P0102 & P0113, along w/ the previous P0031. i cleared the codes and only the P0031 came back. P0102 Mass Air Flow (MAF) Circuit Low Input and P0113 Intake Air Temp Circuit High Input. Not sure if these are related.
Also, where's a good place to buy oxygen sensors for subarus?
Thanks,
Old 04-29-2007, 09:52 PM   #15
MasterKwan
Member#: 98961
2003 WRX
Well the temp gauge and MAF are housed in the same unit. You probably got those codes if you ever turned the key on with the MAF disconnected.
Old 05-01-2007, 07:41 AM   #16
warnockm
Member#: 65633
2002 Impreza WRX
Along w/ where to buy, what kind do you recommend? searching the forums i found some talk about Bosch sensors, but didn't see where to purchase them. I also need to pick up an o2 sensor socket.
Old 05-01-2007, 04:35 PM   #17
Mr.Sparkle
Member#: 83725
2015 WRX
I just ran into the same issue and was searching online for 02 sensors. Densos seem to run a bit more than the Bosch and the cheapest I could find was $149. However that place was all out and wasn't expecting any more for a week or so, so I ordered one form Advanced Auto Parts for $168 shipped. If you look you can probably find one for cheaper. Just make sure it is a pre catalyst or front sensor. The rear sensors are much cheaper.
Mr.Sparkle is offline   Reply With Quote
Old 05-01-2007, 07:44 PM   #18
warnockm
Member#: 65633
2002 Impreza WRX
Cool thanks, i found them. I'll take it they are "upstream" sensors. Upstream from the Cat?
Old 05-08-2007, 04:45 PM   #19
warnockm
Member#: 65633
2002 Impreza WRX
Got my new sensor today and i have another question. The socket needed looks like a spark plug socket, but will not fit because of the wire. When i emailed partsamerica to ask about hte socket, they said to use a spark plug socket.
Does the 2ft wire remove from the oxygen sensor? I know oxygen sensor sockets are split. Was the tech support from parts america wrong?
thanks,
Old 05-08-2007, 09:11 PM   #20
madcat
Member#: 82465
MBP
I just use a 22mm wrench. It works fine if you are careful.
Old 05-08-2007, 09:29 PM   #21
Brighton
Member#: 53542
2002 02TS + 02WRX
TS=Green/WRX=Silver
Harbor Freight and other places sell a specific O2 sensor socket, 22m with a cutout for the wire. Shouldn't cost too much.
Brighton is offline   Reply With Quote
Old 05-08-2007, 11:09 PM   #22
warnockm
Member#: 65633
2002 Impreza WRX
Finally got the thing replaced. Thanks everyone! The bosch sensor changed beautifully and the wire casing seems a little better than the OEM. I reset the code and checked the Oxygen sensor outputs from both sensors. The dealership wanted $350 parts and labor to do this, and i got the parts from partsamerica/advance auto for $179. not bad! thanks again.
Old 05-09-2007, 02:35 AM   #23
calib17a
Member#: 64150
Since the front sensor is actually an a/f ratio sensor, could it be replaced by
the vw wideband sensor from Turboxs?
calib17a is offline   Reply With Quote
Old 05-09-2007, 09:17 AM   #24
Jon [in CT]
Member#: 2992
02 WRX Sedan
If you had inspected the sensor body closely, you would have found that your 'Bosch' sensor was actually made by Denso, which also makes the OEM sensor.
Jon [in CT] is offline   Reply With Quote
Old 05-09-2007, 01:16 PM   #25
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
No, it's a completly dif. type of wideband.
oxygen sensor vs air/fuel sensor paintbing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-02-2008 01:09 PM
FS: Front oxygen sensor 04 WRX 02 sensor Chino Bling Engine/Power/Exhaust 4 11-20-2007 11:56 PM
Oxygen Sensor problems on 2000 Impreza 2.5 RS Antonio Domit Subaru Conversions 4 09-25-2004 12:56 PM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Warranty Issues & SOA Problems 20 12-12-2001 05:04 PM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Normally Aspirated Powertrain 11 12-03-2001 01:42 AM
