Old 04-22-2007, 06:49 PM   #1
jcan0045
Member#: 125696
04 sti
wrb
Default Results from Dyno!
2004 subaru wrx sti
Perrin TBE
Perrin EBCS
SPT Intake
sorry i couldnt post the dynosheet my scanner is currently not working.
Max HP/TQ:
260/269
257/260
258/260
Whats the problem?
jcan0045 is offline   Reply With Quote
Old 04-22-2007, 06:50 PM   #2
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
what kind of dyno?
ray101381 is offline   Reply With Quote
Old 04-22-2007, 06:51 PM   #3
jcan0045
Member#: 125696
04 sti
wrb
does it have to be a tuning problem? nothing else i can think of
Old 04-22-2007, 06:53 PM   #4
mxboy15u
Member#: 105115
What are you tuned with?
mxboy15u is offline   Reply With Quote
Old 04-22-2007, 07:01 PM   #5
jcan0045
Member#: 125696
04 sti
wrb
I am tuned on a Custom Map.
The dyno was a DynoJet
Old 04-22-2007, 07:02 PM   #6
mxboy15u
Member#: 105115
What is your Boost? A/F? Timing? Did the tuner say he was fighting a problem and therefore not able to achieve better numbers?
Old 04-22-2007, 07:16 PM   #7
jcan0045
Member#: 125696
04 sti
wrb
the only thing he said happened was that my OEM BPV wouldnt hold the 21 psi he was trying to tune for so he left it alone at 18psi from my previous tune. so boost was at 18 psi. i dont know how to read the A/F chart to tell u what it was. idk what timing was
Old 04-22-2007, 07:16 PM   #8
DigitalPunk
Member#: 124236
2006 WRX Built EJ257
Version 8 Twinscroll
could the boost controller be a problem?
DigitalPunk is offline   Reply With Quote
Old 04-22-2007, 07:17 PM   #9
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
It wouldn't hold 21psi so he just went right back down to 18psi? Who was the tuner/tuning shop?
wrxfactor is offline   Reply With Quote
Old 04-22-2007, 07:19 PM   #10
jcan0045
Member#: 125696
04 sti
wrb
the tuner was Eric Hargett at initial timing peformance in columbus ohio.
he left it at 18psi till i get a new bov/bpv or crush my OEM.
Old 04-22-2007, 08:20 PM   #11
jcan0045
Member#: 125696
04 sti
wrb
i have my dyno sheet on my computer i just dont know to post it. help please?
Old 04-22-2007, 08:30 PM   #12
pauls07wrx
Member#: 146940
07 wrx
wrb
copy and paste.
pauls07wrx is offline   Reply With Quote
Old 04-22-2007, 08:31 PM   #13
zman519
Member#: 118086
2003 WRX
go hear http://photobucket.com/ up load it to photobucket and then copy the IMG Code in to your post
zman519 is offline   Reply With Quote
Old 04-22-2007, 08:32 PM   #14
zman519
Member#: 118086
2003 WRX
Originally Posted by pauls07wrx View Post
copy and paste.
WHAT ARE YOU TALKING ABOUT?
Old 04-22-2007, 08:48 PM   #15
jcan0045
Member#: 125696
04 sti
wrb
Old 04-22-2007, 08:49 PM   #16
jcan0045
Member#: 125696
04 sti
wrb
sorry about the sizing and the white border. my first time. thanks!
Old 04-22-2007, 09:04 PM   #17
mxboy15u
Member#: 105115
I imagine if your boost was up a little bit your #s would be a lot better. Your A/F looks good and very smooth power.
Old 04-22-2007, 09:10 PM   #18
jcan0045
Member#: 125696
04 sti
wrb
i dont think 3 psi more will give me the other 40 to 50 hp. this was only tuned on a road tune not a dyno yet. do you think a dyno tune then road tune plus the other 3 psi will give me additional horsepower other people with similar mods have?
Old 04-22-2007, 10:04 PM   #19
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
looks like the torque comes on real linear, must be smooth but could use some more oomph down low
bren wrx is offline   Reply With Quote
Old 04-22-2007, 10:19 PM   #20
Nicklz
Member#: 94096
2003 WRX
IPS i was there
for 3 runs at $40
Nicklz is offline   Reply With Quote
Old 04-23-2007, 10:22 AM   #21
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Well now that we know some info, you might be making "more" power when you get on a dyno. I know Ed (Vaus) tunes cars using road dyno software and it reads pretty low. Could be the road tuning software your tuner used. As mentioned, your AFRs look good. If you planned on crushing the stock BPV why not just take it off and do it in a vice at the shop and go back out?
Old 04-23-2007, 11:19 AM   #22
benw
Member#: 103320
1998 swapped
Forester L
looks like your torque curve is funny. Most protuned stage 2/TMIC STIs will hit peak boost and torque around 3500! Yours is after 4,000 and a gentle ramp-up. Looks very conservative and smooth.
benw is online now   Reply With Quote
Old 04-23-2007, 11:30 AM   #23
jcan0045
Member#: 125696
04 sti
wrb
so you think if i had the same tuner do a dyno tune then a road tune and tune for 21 psi with the stock crushed i will see alot higher of numbers?
Old 04-23-2007, 11:30 AM   #24
x99percent
Member#: 27108
2004 STi
2004 A4
AFR may look smooth, but it also looks to be leaner than what most people tune for. Eyeballing it... it looks to be at ~12:1 on the graph.
x99percent is offline   Reply With Quote
Old 04-23-2007, 01:09 PM   #25
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
That is correct but we do not know if that is in the tailpipe (somehow) or not. If it was tailpipe it would be richer than it shows, but now that you mention it, I originally thought it to be around 11.5:1 but I see it a little better now that I'm more awake.
Dyno results from IPS Motorsports Dyno Day event pannell77 Mid West Subaru Owners Club Forum -- MWSOC 7 05-26-2009 11:05 PM
Results from dyno 3/6 300whp AutoSpeedWRX Proven Power Bragging 15 03-11-2004 03:23 PM
Ladies and gentleman, today's ASR dyno tuning results from Van Dyne Engineering... Digital_Boy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 04-17-2001 11:35 AM
Dyno results from MY00 RS!! Keiho Technical Forum Archive 20 06-02-2000 12:55 AM
