Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 07-31-2006, 11:10 AM   #1
TeRonde
Member#: 118859
1997 Ford F150
White/dents/scratches
Default Resolution of '06 STI smoking problem.
Background. 2006 WRX STI 1173 miles. Broken in per SOA reccomendations. 93 octane used exclusively. Car started smoking badly on start up for about 5 seconds. After smoke dissipated, car idled normally and drove normally. The car was not down on power from what I could discern. I brought it into the dealer for service to rectify the issue.
I got my car back from the dealer today after 9 days out of service. Their were no DTCs stored and fluid levels were full. The A/F sensor was showing 1890 on start up. Compression normal. Leak down normal. SOA advised dealership to replace A/F sensor. Car was then test driven. I recieved the car back from the dealership with 1319 miles. That's 146 miles more than it had when I dropped it off. 146 miles seems a bit excessive. I was told that SOA advised the dealership mechanic to do this. Does that sound appropriate? The mechanic almost has more miles after break in than I have...god knows how badly it was beat on. I am sure there were more than a few full throttle runs to ensure the maintenance discrepancy did not recur. What do you guys/gals think?
TeRonde is offline   Reply With Quote
Old 07-31-2006, 11:58 AM   #2
Tgui
Member#: 44771
That sucks. I'm pretty sure 146 miles is too excessive. You can either force them to give you another car, or realize you'll eventually be beating on your car far harder than those techs could ever have.
Well, thats what I tell myself whenever some besides myself drives my car. "Ok, remember that time I (insert), yeah, cant believe she held together on that"
Still isn't a good feeling though, sorry man.
Tgui is offline   Reply With Quote
Old 07-31-2006, 12:26 PM   #3
Cooter05WRX
Member#: 110567
2009 JK
Sunburst Orange
You know if the problem is fixed I wouldn't worry to much about 146 miles on it. Knowing a few mechanics it can take some miles to make sure the problem doesnt continue to occur. Now if the problem comes back then it is time to complain.
Cooter05WRX is offline   Reply With Quote
Old 07-31-2006, 01:08 PM   #4
problemcat13
Member#: 73398
04 11 VW GTI
APR Stage 1 (300ft/lbs)
If I knew they fixed the problem, I wouldn't care if they had driven it 300 miles. When troubleshooting/testing something, you've got to put it through a hundred scenarios to see if you can get the problem to reoccur under any circumstance (to make sure your assumption and fix was correct).
So has the problem reoccured after replacing A/F sensor, or does that seem to have fixed it? Hope so, and good luck!
problemcat13 is offline   Reply With Quote
Old 07-31-2006, 01:10 PM   #5
BryanH
Member#: 993
146 miles doesn't really seem that much to me....but then again thats a daily commute for me.
Is the car fixed? If so be happy. If not....
BryanH is offline   Reply With Quote
Old 07-31-2006, 01:14 PM   #6
salisburyv
Member#: 41863
2015 STI
Crystal Black Silica
146 miles is not excessive. If SOA told them to test drive it to ensure the repair took, then I would be thankin them for their thoroughness. I've put 350 miles on customers cars to evaluate and verify repair is complete.
Still isn't a good feeling though, sorry man."
give you another car? what are you smokin?
salisburyv is offline   Reply With Quote
Old 07-31-2006, 01:46 PM   #7
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
.....I hear that. My wife and I put 120+ per day on her Civic during our commute (60 each way).
Old 07-31-2006, 03:37 PM   #8
CALISTIYLIN
Member#: 106026
05 STi
trollin......
CALISTIYLIN is offline   Reply With Quote
Old 07-31-2006, 10:57 PM   #9
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
146 miles? ouch.
Sucks for that tech.
A/F sensor pays 1.0 hrs
146 miles of driving would probably be 3 hrs alone, not to mention following the trouble tree and going back and forth with SOA that tech has probably at least 10hrs into that job. I sure hope he has good punch times for it and the rep authorizes them some straight time.
Old 07-31-2006, 11:07 PM   #10
jargon
Member#: 107150
i'd be pissed
jargon is offline   Reply With Quote
Old 07-31-2006, 11:11 PM   #11
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
Originally Posted by kwright69_02
i'd be pissed
The only people that should be pissed are the technician (get's paid by the job) and the service writer / manager (get paid a commision based off how many hours they sell)
You as a customer should be happy that they worked on the car as much as they did even when they were not getting paid!
Old 07-31-2006, 11:45 PM   #12
TeRonde
Member#: 118859
1997 Ford F150
It's not my fault it took 9 days to determine a faulty A/F sensor. On a side note, what IS an A/F sensor? I know what a MAF is...I know what an O2 sensor is. The service manager did not know for sure. Oh, and he had way more than 10 hours into the job. The car was either being test driven or up on a lift in the service bay the entire 9 days. Anyways, thanks for the insights people. The car runs great now.
Old 08-01-2006, 12:15 AM   #13
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
A/F sensor measures the air/fuel mix of the engine. It makes sure that the mixture stays near stoich, neither going too lean nor too rich.
146 miles may seem a bit high, but at the same time if it's a goofy code that is rarely seen(or never seen before on a Subie), then I think they were covering their booties by making sure that the light wouldn't come back on.
Mika
finnRex is offline   Reply With Quote
Old 08-01-2006, 01:02 AM   #14
Charge
Member#: 3313
Well, figure they probably test drove the car first to try to make the problem occur. They had it for 9 days? Perhaps it took 2-3 days of early morning startups and drives to try to reproduce the issue? Were they even able to reproduce it or did they just replace it on your word? I bet they could have put 35-50 miles on the car easily just trying a few days of test drives.
Then figure running it through it's paces a bit to verify that it was fixed correctly.
While 146 is high...it doesn't appear excessive to me.
Charge is offline   Reply With Quote
Old 08-01-2006, 08:15 AM   #15
BryanH
Member#: 993
Then stop bitching and go home happy.
Not to be too blunt about this but....146 miles to make sure the code doesn't come back is squat.
Ok?
Old 08-01-2006, 09:40 AM   #16
TeRonde
Member#: 118859
1997 Ford F150
The car immediately smoked badly the first morning they started it (cold starts only). I'm going to need to get a factory service manual for this car. I have never had a car with an A/F sensor. I always thought the O2 sensor was for keeping the air/fuel mixture correct. I think Finnrex has probably hit the nail on the head. The dealer mentioned they had not seen this before on a car with nothing done to it. The part was sent to SOA for analysis.
Bryan, there was no code, which contributed to the troubles diagnosing it.
Thanks again everyone. This place reminds me of being at work.
Old 08-01-2006, 12:35 PM   #17
CALISTIYLIN
Member#: 106026
05 STi
I wonder why dealerships don't like to do warranty work
Old 08-01-2006, 12:38 PM   #18
Hayes
Member#: 11808
Are you sure it oil smoke (bluish) and not normal condinsation (white)?????
Hayes is offline   Reply With Quote
Old 08-01-2006, 02:17 PM   #19
TeRonde
Member#: 118859
1997 Ford F150
It was fuel mixed with oil. I have no idea how oil was getting into my intercooler but the main cloud was fuel (white) with a touch of oil (blue) mixed in.
Old 08-01-2006, 02:37 PM   #20
nito822
Member#: 50490
07 097/800 UGM STI
Dirty
2+ hours of driving seems excessive regardless. Making sure the car's problem was fixed (especially if all they did was replace the O2 sensor) doesn't take 146 miles IMHO.
nito822 is offline   Reply With Quote
Old 08-02-2006, 02:31 PM   #21
vapore0n
Member#: 21356
2010 BMW 335i
oil gets in the IC because of the valve cover vents, the pvc vent, or a leaky turbo seal.
Reason why people put catch cans.
vapore0n is offline   Reply With Quote
Old 08-02-2006, 02:51 PM   #22
TYWRAP
Member#: 17732
94 JZA80 2JZGTE
That is BS!. 146 miles? To fix a smoking at start up problem? Did he start the car 146 times and go for a mile trip around the block? wow
I'd find out how far his commute mileage was and see if it figures out to be his commute for a week.
-jon
TYWRAP is offline   Reply With Quote
Old 08-02-2006, 05:42 PM   #23
DJ_STI
Member#: 56826
2006 Subaru Evo IX
Cute & FABULOUS Miata
146 miles sure is a lot, when I had my sychros replaced in the evo, they drove it for 5 miles, that's it. I would demand a new car or maybe atleast and extended warranty
DJ_STI is offline   Reply With Quote
Old 08-02-2006, 06:02 PM   #24
BryanH
Member#: 993
BS.
synchros are a whole different deal. Its a hard part that is easily diagnosed and replaced. This is a completely different situation.
Sorry you cannot recognize that.
A whole new car for 146 miles..... you cannot possibly be serious.
Old 08-02-2006, 10:15 PM   #25
GrinderAK
Member#: 87551
97 OBS, 01 RS
2014 SWP FXT
146 is excessive, maximum test drive time for a problem like that shouldve been 50 miles, MAXIMUM.
GrinderAK is online now   Reply With Quote
Strange whirring noise from rear of '06 STI scrawshaw Transmission (AT/MT) & Driveline 0 01-09-2007 02:30 PM
'06 STI vs. '06 Forester STi on tonight's episode of Fifth Gear! khyrox1 News & Rumors 97 11-06-2006 06:34 PM
Pix of '06 STI Glovebox Bill Simonsen Electrical & Lighting 4 08-11-2006 12:24 AM
Valentine 1 in '06 STi hardwire problem scottjua Car Audio, Video & Security 13 01-03-2006 02:07 AM
Pics of '06 STi and WRX Sedan trahsub News & Rumors 1 07-21-2005 08:41 PM
