Old 04-23-2007, 05:54 AM   #1
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Default EJ257 with JDM EJ20D heads
I'm building a new engine for my daily driver:
EJ257 block/crank
STI rods
46cc JDM EJ20D heads (ported) with cams
11044AA610 gaskets (1.37 mm)
10.5 compression ratio
JDM EJ20D/EJ25D intake manifold
I need to have pistons custom made (31.3 mm compression height, 10cc dish) what's a good address? I will supply design/shape of the piston/valve pockets myself.
Marnix is offline   Reply With Quote
Old 04-23-2007, 10:51 AM   #2
DSM_Outback
Member#: 56345
93 Swapped L
Green
I deal with Ross engineers on a weekly basis for custom stuff, aside from a couple hiccups they took care of in a timely manner I would recommend them to anyone wanting a custom piece. +1 for Ross.
DSM_Outback is offline   Reply With Quote
Old 04-24-2007, 03:08 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Thanks, I will contact them for a quote, too.
wrx crank in EJ257 - With 04 wrx heads and sti cams morrocco88 Built Motor Discussion 64 09-05-2009 07:48 PM
compression ratio of EJ257 with DOHC EJ25 heads jkjersey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-20-2006 08:06 PM
Advice for USDM sti block with JDM V5 Heads ryceracerx Subaru Conversions 8 08-28-2005 06:26 PM
EJ257 with jdm ver.8 heads comp ratio oldbluwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 03-31-2005 08:38 PM
expected hp with jdm sti heads on wrx werkInProgress Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-01-2004 07:32 PM
