Welcome to the North American Subaru Impreza Owners Club Thursday May 7, 2015
Old 04-23-2007, 09:40 AM   #1
vladrulli
Member#: 100316
Default H4 vs. Z4 ecu..
Tried plugging in the z4 ecu instead of the stock h4... the starter works but the fuel pump does not switch on and so the car does not start...
is there the same pinout on these ecu's or is there some difference? the ej20g was originally mated to a 4eat and thus the h4 is crosswired with a tcu.. could that be the cause of my problem?
vladrulli is offline   Reply With Quote
Old 04-23-2007, 10:53 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That's your problem. Check the wiring of the neutral position swtich. Also, look at the Trans ID pin.
Old 04-23-2007, 11:29 AM   #3
vladrulli
Member#: 100316
well, the thing is that I've already swapped out the auto trans for a 5spd unit and the car works fine with the old ecu... the neutral position switch is shorted... what bothers me is that the starter relay works but the fuel pump is disabled... normally the ecu wouldn't run the starter if the neutral position voltage was wrong...
is it engough to cut the trans ID wire or do I have to ground it in order to identify the manual trans?
Old 04-24-2007, 04:26 AM   #4
vladrulli
Member#: 100316
opened up both ecus today... the insides are totally different...
anybody know if the pin-out on the h4 and z4 is the same?
Old 04-25-2007, 04:15 PM   #5
vladrulli
Member#: 100316
any thoughts on this are welcome!
Old 04-25-2007, 04:43 PM   #6
kingsubi
Member#: 19239
2011 WRX
sounds like the pinout is different!
kingsubi is offline   Reply With Quote
link ecu vs powerfc vs E-ultimate vs megasquirt vs z4 (ej20g) JDMFLCL Pre-2002 Factory Turbo Powertrain 49 01-29-2013 06:12 PM
TW: EJ20G Z4 ECU (tuned by Zero Sports Japan) GripGC8 1993 - 2001 Impreza Specific Parts 20 09-28-2007 05:14 PM
Zero Sports tuned Z4 ECU GripGC8 Subaru Conversions 3 04-10-2007 11:57 PM
EJ20G 6K or Z4 ECU..ASAP!!!! GripGC8 Private 'Wanted' Classifieds 1 03-29-2007 12:31 AM
pinout for 6k or z4 ecu andie44a Subaru Conversions 1 11-19-2006 10:52 PM
