Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-23-2007, 10:29 AM   #1
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Default Can You Hook Up a 6 Wire Fac Sub to a 5 Wires Set Up?
have a 03 stock WRX HU
got a 06 stock STI sub woof w/ harness
everything looks like plug and play, however, no sound from new sub when connected
there are 2 wires tht come off the new harness and dont connect to anything
the wires are purple and orange
any help would be appreciated!!
AliBenn is offline   Reply With Quote
Old 04-23-2007, 06:03 PM   #2
AliBenn
Member#: 487
Acadia Green RS-T
nobody?
Old 04-23-2007, 06:41 PM   #3
Erik.m.olson
Member#: 147027
2010 Forester XT
Red
I have a 2007 impreza and bought a 2006 wrx sub thinking it would work... now im just selling it on eBay then going to buy the proper sub... for a 2007
Erik.m.olson is offline   Reply With Quote
Old 04-23-2007, 07:33 PM   #4
lowranger
Member#: 124370
03 wrx stg 2.34159
Pro tuned by Cobb Tooning
yeah you might be sol with this setup
lowranger is online now   Reply With Quote
Old 04-24-2007, 11:01 AM   #5
AliBenn
Member#: 487
Acadia Green RS-T
crap,
thanks
Old 04-24-2007, 11:02 AM   #6
AliBenn
Member#: 487
Acadia Green RS-T
erik,
does yours have 5 or 6 wires?
Old 04-27-2007, 01:48 AM   #7
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
there are 2 wires tht come off the new harness and dont connect to anything. the wires are purple and orange
The purple and orange wires go to the Left channel input into the subwoofer. The sub needs to see sound on that channel in order to activate, since there is no remote-on wire.
Are those wires just hanging loose, or is there a small, square plug? If there's no plug then the seller should have told you!
You can make a very easy modification to use that sub harness with your older HU. See this thread:
stock sub w/ aftermarket hu
post #18 for pictures, and posts 20 & 21 for instructions.
(You can find that link in the "Stock HU info" thread, listed in both of the FAQs that are "stickied" at the top of the "Car Audio, Video & Security" forums).
Erik.m.olson same trick should work for you too.
SVXdc is offline   Reply With Quote
Old 04-27-2007, 01:54 AM   #8
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
erik,
Umm, where are you seeing 5 wires?
Take a look at the subwoofer harness pictures in this thread:
Stock head unit information -- pin-outs, subwoofer, aux inputs, and more
You should be seeing 6 wires coming from connector that plugs into the subwoofer. This section should be about 4 feet long and covered in a vinyl jacket.
At the other end, 4 of those wires should tie into the 14-pin connectors (one wire going through an inline fuse holder).
The other 2 wires, Orange and Violet, normally go to a square, 8-pin plug.
can you hook a laptop up to a monitor? (broken laptop screen) adam555 Off-Topic 17 05-14-2008 09:41 PM
can you hook up a water temp gauge to the stock sensor? Homemade WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-15-2004 06:26 PM
Can you hook a sub and amp to the stock system? wombatsauce Car Audio, Video & Security 6 01-31-2003 08:00 PM
how can you hook up a cassette player to a CD head unit? 22 Lou Car Audio, Video & Security 12 02-07-2001 11:32 PM
