Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 04-23-2007, 07:52 PM   #1
TH motorsports
Vendor Sales Rating: (84)
Member#: 145643
95 Impreza L-ish
Blueish Green
OMGHi2U Exedy, competition Clutch, flywheels, act, plus more
EXEDY CLUTCHES
Exedy Stage 1 Organic Clutch Kit
15801 1997-02 Impreza RS "2.5L EJ25 Non Turbo, SOHC"
15801 1997-02 Impreza RS "Non Turbo, SOHC"
CLICK HERE FOR PRICE
15802 2002-04 Impreza WRX "Turbo, Pull Type, (GC8, GF8, GDA)"
15802 2002-05 Impreza WRX "2.0L EJ20T Turbo, Pull Type, (GC8, GF8, GDA)"
15804 2006-07 Impreza WRX "2.5L EJ25T Turbo, Push Type"
15803 2004-06 Impreza WRX STI "Turbo, Pull Type, US Model"
15803 2004-07 Impreza WRX STI "2.5L EJ25T Turbo, Pull Type, US Model"
Exedy Stage 2 Cerametallic Clutch Kit
15900 2002-04 Impreza WRX "Turbo, Pull Type, (GC8, GF8, GDA)"
15900 2002-05 Impreza WRX "2.0L EJ20T Non Turbo, SOHC"
15950 2002-05 Impreza WRX "2.0L EJ20T Turbo, Pull Type, (GC8, GF8, GDA)"
15952 2006-07 Impreza WRX "2.5L EJ25T Turbo, Push Type"
15951 2004-06 Impreza WRX STI "Turbo, Pull Type, US Model"
15951 2004-07 Impreza WRX STI "2.5L EJ25T Turbo, Pull Type, US Model"
Exedy Hyper Single Clutch Kit
FH01SD 2002-04 Impreza WRX "Turbo, Pull Type, (GC8, GF8, GDA)"
FH01SD 2002-05 Impreza WRX "2.0L EJ20T Turbo, (GC8, GF8, GDA), (4)"
FH02SD 2004-06 Impreza WRX STI "Turbo, Pull Type"
FH02SD 2004-07 Impreza WRX STI "2.5L EJ25T Turbo, (4, 8)"
Exedy Multiplate Clutch Kit
FM022SD 2004-06 Impreza WRX STI "Turbo, Pull Type, (4)"
FM022SD 2004-07 Impreza WRX STI 2.5L EJ25T
Exedy Carbon Clutch Kit
FM012SBMC 2002-05 Impreza WRX 2.0L EJ20T
FM022SBMC 2004-07 Impreza WRX STI 2.5L EJ25T
Exedy Lightweight Racing Flywheel
FF02 1997-02 Impreza RS
FF02 1997-02 Impreza RS "2.5L EJ25 Non Turbo, SOHC"
FF01 2002-04 Impreza WRX
FF01 2002-05 Impreza WRX "2.0L EJ20T Turbo, Pull Type, (GC8, GF8, GDA)"
FF502 2006-07 Impreza WRX "2.5L EJ25T Turbo, Push Type"
FF501 2004-07 Impreza WRX STI "2.5L EJ25T Turbo, Pull Type, US Model"
PM FOR HOT PRICES
COMPETITION CLUTCH
Stage 1 - Gravity Series 2400 Clutch Kit
The economical solution for moderately modified cars or simply aggressive individuals with stock power. Offers 40-50% of torque capacity and maintains stock pedal feel.
$295 SHIPPED!!!!!
2001 2005 -4 Cyl.2.0L Impreza
2001 2005 -4 Cyl.2.0L WRX
Stage 2 - Street Series 2100 Clutch Kit
This assembly provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life.
Stage 3 - Street/Strip Series 2300 Clutch Kit
This segmented Carbon Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 500 mile break-in REQUIRED with this set-up.
Stage 4 - Strip Series 1620 Clutch Kit
This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity.
Stage 4 - Strip Series 0620 Clutch Kit
This assembly, available with a six puck rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 250% increase in torque capacity.
Stage 5 - Strip Series 1420 Clutch Kit
This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 300% increase in torque capacity.
Stage 5 - Strip Series 0420 Clutch Kit
This assembly, available with a rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 300% increase in torque capacity.
IronMan Street/Strip Series 1680 Clutch Kit
This assembly features our advanced hybrid iron and carbon friction material riveted to our high torque disc assembly in a six puck style. The IronMan provides outstanding stability, smooth engagement, and less wear on opposing surfaces. Offers 175% increase in torque capacity.
Forged Aluminum Flywheel
Qualities of the CCI Forged Aluminum flywheel:
A. Grade 8 Aircraft quality friction surface bolts.
B. Course ground surface to maintain coefficient of friciton.
C. Stepped pin to maintain plate balance and placement.
D. Tig-welded safety tab to eliminate ring gear seperation.
E. Heilicoil bolt holes to insure proper torque value and eliminate thread damage.
Allows engine to more rapidly transfer power to the drive train and to have quicker throttle response. Motor will rev faster under acceleration. Reduces typical turbo "lag" with turbo-charged engines. Increases supercharger efficiency due to less parasitic drag on the crank. Improves mid-range torque in normally aspirated engines.
Meets and exceeds SFI spec 1.1 and 1.2
PM FOR HOT PRICES
How to order?:
Call 1-800-959-0145 ext 4 (Adam K) toll free and mention the sale
**Master Card, Visa, Discover, AMEX** OR PM US!!!!!!!
EMAIL: [email protected]
WE ALSO USE AIM: adamkthm
TH motorsports is offline
Old 04-24-2007, 04:38 PM   #2
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
bumpiness
Old 04-26-2007, 01:51 PM   #3
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
PM's sent...thanks for the orders
Old 04-26-2007, 08:56 PM   #4
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
THanks for the order!!! we got more!!!!
Old 04-27-2007, 10:56 AM   #5
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
bump for the morning
Old 04-27-2007, 07:49 PM   #6
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
evening bump
Old 04-28-2007, 07:59 PM   #7
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
bump bump
Old 04-30-2007, 10:08 AM   #8
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
monday morning bump
Old 04-30-2007, 01:22 PM   #9
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
afternoon bump
Old 04-30-2007, 05:33 PM   #10
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
pm's sent
Old 04-30-2007, 08:11 PM   #11
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
evening bump
Old 05-01-2007, 10:27 PM   #12
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
pm's sent
Old 05-03-2007, 03:02 PM   #13
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Bump for afternoon
Old 05-04-2007, 02:56 PM   #14
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
PM's sent out
Old 05-07-2007, 12:44 PM   #15
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
OMGHi2U
morning monday bump
Old 05-07-2007, 05:04 PM   #16
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Check out the competition clutch products
Old 05-08-2007, 05:30 PM   #17
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Bump Bump Bump
Old 05-09-2007, 03:50 PM   #18
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Old 05-14-2007, 03:51 PM   #23
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
TTT thanks everyone
Closed Thread
Exedy Street Clutch and ACT Streetlite Flywheel powdeez Drivetrain 12 10-22-2009 10:49 AM
ACT, Exedy, Spec clutches/flywheels on sale EviL Performance Drivetrain 15 06-09-2008 09:10 PM
Exedy Stage1 Clutch & ACT Streelite Flywheel Install. eddie1982 Transmission (AT/MT) & Driveline 2 06-11-2006 12:33 AM
FS: Brand new Exedy hypersingle clutch/flywheel bigsley18 Mid Atlantic Impreza Club -- MAIC 23 02-25-2005 11:33 AM
Exedy WRX clutch/flywheel stirex Private 'For Sale' Classifieds 13 01-07-2004 01:43 PM
