Old 12-14-2001, 04:47 PM   #1
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Default DMS gold vs KYB/AGX with GC... what would you choose?
Price isn't the issue.... my friend has 02 WRX sedan and is split between both......
I told him he should buy the DMS 40mm golds for his REX..... I have the KYB/AGX on my RS and recommended to stepping up and buying the better suspension....
Please post your comments and opinions or what you would do...
Tks.
Robin
Robin2 is offline   Reply With Quote
Old 12-14-2001, 05:37 PM   #2
trboCIVIC&WRX
Member#: 6426
thats like apples to oranges.
do the golds.
trboCIVIC&WRX is offline   Reply With Quote
Old 12-14-2001, 06:19 PM   #3
preza
Member#: 1454
2000 2.5 RS-T
DMS all the way if money is no issue, KYB/AGX in my book dont even compare to the DMS'
preza is offline   Reply With Quote
Old 12-14-2001, 06:35 PM   #4
mitch808
Member#: 10228
2002 Subaru WRX
No comparison....
But if he goes the lowcost route, make sure he knows the shortcomings... Do a search and you'll see.
mitch808 is offline   Reply With Quote
Old 12-14-2001, 06:47 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah pretty much what they said
agx/GD is almost exactly half the cost...
you get what you pay for
Old 12-14-2001, 06:49 PM   #6
Silverscooby27
Member#: 9124
2014 335i xDrive
Well, I have the KYBs with Eibach Prokit, and I like 'em. I don't have enough experience on the track that I really need anything more. Plus, my kidneys will die on the crappy roads here if I had anything much stiffer. My buddy has coilovers on his Audi, and asked me if I could hook him up with struts because of the roads, so you have to choose for yourself. . .
Silverscooby27 is offline   Reply With Quote
Old 12-14-2001, 08:10 PM   #7
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
It is worth noting that DMS are like no other coilover of which I am aware, in that they are more comfortable than stock on the WRX, when you go with the stock 180/180 spring rates.
SilverScooby, I had the Pro-Kit/AGX combo on my Legacy GT wagon. When I switched to the DMS, the car handled better and was a lot more comfortable.
As far as the original topic, that's a trick question, right? The other respondents are correct: there is no comparison in terms of toughness and ride quality. If I had the money...hell, if cost is no object, have him get the 50mm DMS. Nothing succeeds like excess.
What's interesting is that DMS are often compared to other coilover systems but objectively (yes, I love mine, but...) I don't know of a another coilover that you can drive to the rally or rally cross, run the event, drive home, or run on the track if that's what you want, yet are comfortable even on the crappy Chicago roads.
Kevin
gtguy is offline   Reply With Quote
Old 12-14-2001, 08:42 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Based on my personal experience, the DMS Golds are significantly smoother on the street. I'm not sure what the Prokit spring rates are, but it seems like most guys that go with the GC coil-overs run 275f/225r or something like, as opposed to the 180f/180r or 225f/180r that are "stock" on the DMS Golds. Combine lower spring rates with much better damping characteristics and the DMS Golds are way more comfortable than the KYB/AGX + GC setup. I've ridden in a few Imprezas with KYB/AGX's and springs of one sort or another and I was really disappointed at how harsh the ride was. My first ride was long before I had the DMS Golds and was looking into suspension options - the KYB setup dropped off the list immediately.
Does he have good coilovers or garbage coilovers? What brand? What spring rates? Etc etc. You can't make a blanket iimplication that coilovers are bad based on your buddy's thoughts about the X Brand coilovers on a completely different vehicle.
Oh, by the way, I love the coilovers on my Mustang, so I recommend everybody get them for their Subaru.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 12-15-2001, 12:10 AM   #9
Silverscooby27
Member#: 9124
2014 335i xDrive
I guess anybody who likes their setup and goes against the crowd gets the flame, huh?
Read my post more closely before you get nasty. It doesn't say anywhere that I don't like coilovers. All it says is that I'm happy with my setup, and my friend with coilovers is not. BTW, I have no idea what brand they are, but I can guarantee they aren't "garbage" coilovers.
Old 12-15-2001, 12:30 AM   #10
Freeskier
Member#: 3962
2001 F250 7.3L TD
2011 STi
How well will the DMS 40's hold up to rally cross and maybe a few rallysprints here and there (once or twice a year)? Or should I really fork up the cash for the 50mm's that will only see approx. 50 kilometers of stages per year.
Stefan
Freeskier is offline   Reply With Quote
Old 12-15-2001, 01:31 AM   #11
Dave_Clark
Member#: 1015
The DMS Golds are not meant for rallying. That's what the 50mm Giants are for. They are built to take it. The DMS Golds are a little smaller and intended for fast road and occaisional track use.
Having said that the occaisional rallycross or gravel road isn't going to hurt them. They are still much stronger and robust than your typical KYB, etc. or japanese coilover.
Also, let's revisit something here. Although they are adjustable for ride height they are a shorter body shock and not intended to raise the car above stock ride height. In fact stock ride height is a bit too high. They are meant to lower the car about 25-30mm (or a bit lower than that if you like.) Any shock has an ideal travel range. If you try to operate them outside of that range (for example if you raise them too high and only have an inch of droop travel from static ride height) then you are liable to experience less than ideal handling and ride quality, noise, and perhaps even damage the shock.
Even on the rally cars we run stock ride height so there is no need to lift the car for a rallycross which is typically much smoother. You can easily run lowered with DMS and not worry because the car is not going to bottom out like it would with stock suspension (just ask gtguy.)
Just a little education because I know some people have the wrong idea about coilovers.
To answer your question Stefan for what you are doing the Golds should work just fine.
Silverscooby: Have your friend with the Audi talk to us. DMS makes stuff for him, too.
Dave_Clark is offline   Reply With Quote
Old 12-15-2001, 02:42 AM   #12
gtguy
Member#: 2184
Bottoming? What's that?
Kevin
Old 12-16-2001, 01:34 AM   #13
Ken Levin
Member#: 1416
2/01 WRX SportWagon
Yes, it's like apples and oranges. Depends on what you're looking for. Some of us are happy with the GC setup because it meets our needs and fits the budget.
My GC KYB/AGX, Eibach combination works well for track days when the struts are set full hard. Roads aren't experienced as particularly harsh when the adjustment is moved towards the softer settings. And adjustment is fast and simple. And, I have height adjustment as well.
That said, if I wanted to spend more than twice as much, the Golds seem like the way to go. I would like to test a set....
Happy Motoring
Ken Levin is offline   Reply With Quote
FS WI: KYB AGXs with GC coilover springs for 02-04 wrxs Deus ex Machina Private 'For Sale' Classifieds 28 02-21-2006 11:26 PM
98 Golds v.s. Speedline rims...what would you choose? kevinsUBARU Tire & Wheel 9 11-29-2005 10:50 PM
What would you choose ? Pinkeye Off-Topic 22 09-04-2004 09:40 AM
If you could name one food to be totally healthy, what would you choose? somebody else Off-Topic 32 12-15-2003 03:31 PM
KYB/AGX with GC or tein HA chazthespaz Brakes, Steering & Suspension 3 05-05-2003 11:36 AM
