Old 04-25-2007, 01:35 PM   #1
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
Default Picture of my new Ultimate Racing twin scroll kit
HEY EVERYONE CHECK ON PAGE 6 FOR NEW PICTURES OF THE FINISHED ENGINE AND PAGE 8 NEW PIC AND VID...CHECK IT OUT!!
TO BE CONTINUED
PAGE 10 DYNO VID AT 17psi
Here are the new pictures with the heat wrap sealer
came with:
all hardware
twin scroll header
two uppipes
two dumpipes
downpipe + reducer
i already have the gt40r turbo and wastegates so i just needed the piping
my car is going into the shop may 9th....can't wait to get all of this installed
blowbyu24 is offline   Reply With Quote
Old 04-25-2007, 01:43 PM   #2
STIenvy
Member#: 37112
2003 WRX
kit looks great
STIenvy is offline   Reply With Quote
Old 04-25-2007, 01:59 PM   #3
06_Aspen_STI
Member#: 114223
2006 Subaru STI
Aspen White w/ Gold Wheel
Make sure you post some pic's after its done
06_Aspen_STI is offline   Reply With Quote
Old 04-25-2007, 02:08 PM   #4
WRX_Aruba
Member#: 93668
My15 Impreza WRX STi
why do you have 2 uppipe? cause its twin scroll?
WRX_Aruba is offline   Reply With Quote
Old 04-25-2007, 02:15 PM   #5
calib17a
Member#: 64150
Can you take some close-up pics of the uppipe flange. Looks great. I'm running the jdm vf36 setup and am waiting for AVO to come out with gt30r turbos to work with the jdm setup. Runners and uppipe look definitely larger than the jdm version. Dual dump tubes are flanged for the 38mm Tial? How much did it run?
calib17a is offline   Reply With Quote
Old 04-25-2007, 02:55 PM   #6
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
the two pipes lead into the divided exhaust hausing of the turbo
Old 04-25-2007, 02:57 PM   #7
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
yes i can take a pic.
yeah i have two tial 38mm wastegates
the whole kit was very expensive, but i think 600whp is also priceless with full boost around 4200-4300rpms
Old 04-25-2007, 07:00 PM   #8
BOXER28
Member#: 64756
all i can say is wow and good luck with it im also going with an ur kit just a tad bit smaller though..lol
BOXER28 is offline   Reply With Quote
Old 04-25-2007, 07:09 PM   #9
kyleblix
Member#: 73495
Audi Q5, Ford Raptor
Wow, that looks like a great kit. pics of install please
kyleblix is offline   Reply With Quote
Old 04-25-2007, 07:11 PM   #10
fastwrx25
Member#: 126441
03 bugeye
that looks like one helluva kit. you should coat or wrap those pipes!
fastwrx25 is offline   Reply With Quote
Old 04-25-2007, 10:55 PM   #11
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
you caught me to it, i am almost done heat wrapping everything, i will finish it tomorrow and post some more pictures...i took my time and did it carefully, so hopefully it works out....and yeah my arms are ichy from using that stuff, beware of anyone planning on doing it, wear long sleeves!!
Old 04-25-2007, 11:05 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....MOST wraps direct them to be soaked in water and applied WET.
Old 04-25-2007, 11:13 PM   #13
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
yes i did do that, i had a pan and ran the wrap through the water and then applied the wrap...thanks tho
Old 04-25-2007, 11:21 PM   #14
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
congrats on the new setup! looks really nice!
jigga is offline   Reply With Quote
Old 04-25-2007, 11:23 PM   #15
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
thanks everyone on the positive comments...its been a long time coming...this time last year i was just starting to save and pick out parts so im only 2 weeks away from dropping her off
Old 04-25-2007, 11:33 PM   #16
Stoneman
Member#: 145537
2007 Impreza 2.5i
Metallic Silver
600+ whp? Wow. Are you going to use that as a daily driver or just drifting???
Stoneman is offline   Reply With Quote
Old 04-25-2007, 11:40 PM   #17
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
Im almost done wrapping everything
so far i have gone through
2 - thermotec 1''x 50ft
2 - thermotec 2''x 50ft and just starting to use the second one
I can't believe how much wrap it took, but i did do the wraps close together for best efficiency....tell me what you guys think of the job and i dipped the wrap in water before putting on just to make that clear and used fasners from lowes to tie down the wrap
Old 04-25-2007, 11:45 PM   #18
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
Its gonna be my DD until i have the funds to get another DD
plans are a very conservative tune on 93 oct pump gas for about 450whp
aggressive 93 oct pump gas tune for about 510whp
tune on C16 for about 600whp and maybe a few more give or take
this is all going to be done through hydra ems
Old 04-25-2007, 11:53 PM   #19
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
I don't see this kit anywhere on their site.
Did you have them custom fab this for you?
My eventual plans include a twin-scroll setup (albeit significantly smaller that yours), so I was curious....
IronMonkeyL255 is offline   Reply With Quote
Old 04-25-2007, 11:54 PM   #20
eqlized_aero
Member#: 88699
2015 TS EFR7163 818S
V9 Spec C Type RA 92x
I hope you're going to wrap the passenger side of that header.
You should also use a silicone sealer like DEI offers so that the wrap doesn't get too much moisture build up and won't absorb oil well.
eqlized_aero is offline   Reply With Quote
Old 04-26-2007, 12:03 AM   #21
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
yep, its custom built for me....like big valley's was
Old 04-26-2007, 12:05 AM   #22
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
yes i am, im not finished yet, but i thought i would go ahead and post pics, and i have the dei silcone sealer so as soon as i get done wrapping and its all dry im going to seal it
Old 04-26-2007, 12:10 AM   #23
_sti_05
Member#: 72313
16 STi
very nice, post up some pics when its done.
_sti_05 is offline   Reply With Quote
Old 04-26-2007, 12:27 AM   #24
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
oh, did you ask the guys at UR before wrapping things up? For the cost of all the stuff, it would be a shame to have any warranties revoked due to a slight oversight. Might be prudent to make sure that it is okay first
Old 04-26-2007, 01:42 AM   #25
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
it was custom built on a sti so the kit is going to fit perfect, im not sure what you mean by warranties revoked though?
Pictures of my new kitchen... aka "the most horrible generic style-void of a kitchen" 2k2 Off-Topic 56 11-21-2009 11:49 AM
my new gp moto twin scroll rotated turbo! 06redsuby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 02-15-2008 12:30 AM
Full Race Twin Scroll Kits APS04silverwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-21-2007 08:04 PM
Pictures of my new body kit! ImprezedRS Member's Car Gallery 14 04-29-2002 11:11 PM
New pictures of my new hood bra and emblem!! kevinsUBARU Tri-State Area Forum 4 08-19-2001 11:21 AM
