Old 04-25-2007, 10:32 PM   #1
lvfc_rook_1503
Member#: 120727
2006 WRX
OBP n Verocious Tuned =]
Question Where do I go from here?
Hey all I have an 06 wrx. This car is my daily driver so i can't afford unreliable power or getting into a project that could potentially have the car down for a few days. But I am lookin to get some more power.....Heres what i have so far
Invidia DP
Magnaflow Catback
K & N Drop in filter
Silicone Hoses
STI TMIC
VF39 Turbo
Cobb AP tuned to the VF39 map
Short Throw Shifter and stiffer shift bushings
NX-Ntercooler Sprayer
TEIN coilovers with EDFC
Front Strut Bar
Front and Rear sways and endlinks
and bigger wheels and rubbers
I was planning on getting a protune in may but i was told that an intake and then a protune would probably produce more hp. So now i'm leaning towards that but not sure whether to go with a short ram or a BIG MAF intake. Does anyone have any other suggestions for what i should do before the protune? I heard the 06 injectors are pretty decent so i'm trying to avoid changing them. But any help would be greatly appreciated
lvfc_rook_1503 is offline   Reply With Quote
Old 04-25-2007, 11:00 PM   #2
mjackle
Member#: 71169
How about Meth injection? This kit is inexpensive... http://www.snowperformance.net/product.php?pk=47
mjackle is offline   Reply With Quote
Old 04-25-2007, 11:55 PM   #3
STIred05
Member#: 115223
2005 Subaru STI
Ewg, meth, header, TGV's, and maybe an intake + turbo inlet. Other than that your options are sort of limited w/o breaking the trany. The engine should be able to handle that power if the tune is good.
STIred05 is offline   Reply With Quote
Old 04-25-2007, 11:59 PM   #4
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
More Power = More problems...
Of course, i don't mean at all times more power will equal more problems... but more that there is a greater chance of problems associated with more power.
If you can't afford to fix problems associated with more power... in case murphy's law does strike... Then I'd recommend keeping everything the way it is.
A GOOD tune... a REPUTABLE tuner... etc could be a good idea. a Half-assed tune is a bad idea...
BigJ04STi is offline   Reply With Quote
Old 04-26-2007, 06:31 AM   #5
BOXER28
Member#: 64756
just go get protuned
BOXER28 is offline   Reply With Quote
Old 04-26-2007, 06:45 AM   #6
lvfc_rook_1503
Member#: 120727
2006 WRX
Replying to the statement about murphy's law.....its not that i can't afford to fix things so please don't shy away from ideas due to price. I'm just saying somethin such as a blown tranny or internals......cost wise no prob i can fix them i just cant afford to have the car down for stuff like this that would have to be taken to a shop if ya know what i mean.........
and although i say money is not a problem buyin an STI is not an option either lolol
also just out of curiousity.......whats an EWG????
Thanks all
Old 04-26-2007, 06:55 AM   #7
BOXER28
Member#: 64756
ewg = external wastegate it helps control boost better.. your vf39 has a internal wategate to regulate boost pressure it keeps the door on the wastegate closed until the desired boost pressure is reached and then opens the door when it hits it... alot of people have boost creep issues so they either port out the stock wastegate or go to an ewg set up..
Old 04-26-2007, 09:53 AM   #8
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
You can go up to an 18g or 20g... and get protuned... Then have some solid usable power that way...
Old 04-26-2007, 03:09 PM   #9
lvfc_rook_1503
Member#: 120727
2006 WRX
i looked into the 20gs origionally but someone told be i would basiclly have to have the car towed to the shop to be protuned cause there was no set map from cobb and that was to drastic to run the car without a tune.........is that true cause the closest GOOD pro tuner to me is about 2 hours away
Old 04-26-2007, 03:40 PM   #10
lvfc_rook_1503
Member#: 120727
2006 WRX
also can the EWG be put on with the turbo in the car or do i have to remove the turbo completely?
Old 04-26-2007, 03:45 PM   #11
neonglh
Member#: 127886
An EWG is in the up pipe, so you replace the stock up pipe with that of one that has a flange on it for an external wastegate. Doing this would require you to remove your turbo, and then up pipe, and replace it with the new one, then the waste gate and dump tube, and then place your turbo back on.
--mark
neonglh is offline   Reply With Quote
Old 04-26-2007, 04:12 PM   #12
lvfc_rook_1503
Member#: 120727
2006 WRX
thank you for the info you guys are awesome
Where do I go from here? dylanhauge Interior & Exterior Modification 19 05-07-2007 04:30 PM
Where Do We Go From Here? firstHKS Built Motor Discussion 2 01-23-2007 01:05 PM
Where do I go from here? Log inside. 9d2TSi Engine Management & Tuning 8 06-15-2006 03:14 PM
Where do I go from here (I have money to spend!) swalker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 10-14-2003 03:20 PM
New Car !! so.. where do I go from here? songcho Texas Impreza Club Forum -- TXIC 1 08-16-2001 09:52 AM
