Old 01-01-2011, 10:35 PM   #101
zkiller
Member#: 221287
2015 WRX
ISM
This thread really makes me wish I had auto HVAC controls.
Regardless, I may have to give this a go.
zkiller is offline   Reply With Quote
Old 01-02-2011, 07:54 AM   #102
JDMCRIS
Member#: 223690
2001 WRX
Anrazith
Will the newer hvac controls fit my bgeye conector , my consol looks like this right now
http://streetridez.net/original.php?...2&picID=328810
Cam i switch to this ?
Thanxs in advance for your help and a happy new year to all of you
chris
Uploaded with ImageShack.us
JDMCRIS is offline   Reply With Quote
Old 01-02-2011, 11:11 AM   #103
Technobee
Member#: 256265
Great post, thanks
Technobee is offline   Reply With Quote
Old 01-02-2011, 11:22 AM   #104
mattinct
Member#: 44695
2005 WRX
Red
Nice writeup.
mattinct is offline   Reply With Quote
Old 01-02-2011, 11:38 AM   #105
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
chris
All you need to make it work is a 06 TR radio bezel and 05-07 radio brackets. The auto ac controls and radio bezel are not plug and play into 02-04 WRX.
MD04WRX is offline   Reply With Quote
Old 01-02-2011, 11:49 AM   #106
zkiller
Member#: 221287
2015 WRX
ISM
I don't think he does. Looking at his linked pic, he has auto hvac controls in his bugeye already, so he should be able to just swap it out for the 05+ controls.
Old 01-02-2011, 12:02 PM   #107
MD04WRX
Member#: 72891
2014 Molten ST
You maybe correct. It looks like he has a 04 STi dash swap. If that's the case the wiring and HVAC would have been swapped (to make it work), so he doesn't have the "bugeye connector" he referred to in his post. In that case he may only need to add the radio brackets.
Old 01-02-2011, 08:23 PM   #108
Ethan_Drift
Member#: 264930
2011 GT, Evo 8
Does anyone have the part number for the e-brake or ashtray?
Ethan_Drift is offline   Reply With Quote
Old 01-02-2011, 08:44 PM   #109
zkiller
Member#: 221287
2015 WRX
ISM
Going through the list on SubaruPartsForYou.com, I think I found the part number for the ashtray:
Ashtray Insert - Part # 66160SA001
I couldn't find a part number for a 05+ e-brake on there. Oddly enough, they do list four different part numbers for the e-brake assembly between the 02-04. Really weird - I'm confused.
Old 01-02-2011, 09:18 PM   #110
Ethan_Drift
Member#: 264930
2011 GT, Evo 8
That^ P/N is for the ashtray, I need the housing number. Sorry I wasnt clearer =/
Old 01-03-2011, 06:45 AM   #111
JDMCRIS
Member#: 223690
2001 WRX
Anrazith
Sorry for the lat answer guys and thanxs for the replay .
Just to clarifiy, i liv in switzerland and i got my bugeye wrx in may 2001, my bugs center consol allready comes like it is right now no modifications from my side (i got it brand spanking new) i donnt know if this was only on the edm models ......
So you think i only need to connect the newer unit to my oem connector i got ?
That will be awesome
Thanxs guys
chris
Old 01-03-2011, 07:29 AM   #112
zkiller
Member#: 221287
2015 WRX
ISM
Chris, there is no way for us to know for sure since we don't have access to a bugeye with factory stock auto hvac controls over here, but I would assume that the controls/connectors in your car are identical to those found in USDM 04 STI's, which are of course compatible with the 05+ auto hvac controls.
Personally I would try to get a used set of 05+ auto hvac controls off the forums or ebay for cheap and just try hooking it up before going out and buying a complete 05+ center console, just to be safe.
BTW, I am originally from Germany and very much miss my old EDM bugeye.
Old 01-19-2011, 05:43 PM   #113
Frogg
Member#: 267429
1997 Legacy GT Wagon
Has anybody tried to swap in the 08+ STI console?
Frogg is offline   Reply With Quote
Old 01-24-2011, 12:10 PM   #114
Frogg
Member#: 267429
well?
Old 01-24-2011, 01:10 PM   #115
12sechatch
Member#: 132458
Okie Dokie Fine
they're completely different. You'd need to swap the entire dash...which I doubt would even fit to begin with.
12sechatch is offline   Reply With Quote
Old 01-24-2011, 02:55 PM   #116
Frogg
Member#: 267429
i know they are different...but i mean with some cutting of the new console and of the existing dash....but i guess no ones tried it. Maybe I will...
Old 02-14-2011, 02:03 PM   #117
WRBryce
Member#: 223862
2003 vf34'd WRX S/W
http://opposedforces.com/parts/impre...llustration_5/
Number 6.
6 Reinforcement complete-center
Hope that helps answer the part number that is missing!
WRBryce is offline   Reply With Quote
Old 02-14-2011, 07:53 PM   #118
zkiller
Member#: 221287
2015 WRX
ISM
Even with cutting I doubt it would fit.
Old 02-18-2011, 06:07 PM   #119
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
bought the console kit from Millennium Auto Parts, so let's see how this goes!
kevin85193 is offline   Reply With Quote
Old 03-08-2011, 03:35 PM   #120
sopmoney
Member#: 146031
03 tomei ftw!
psm
Does anyone know the part number for the tr radio bezel
sopmoney is offline   Reply With Quote
Old 03-13-2011, 10:53 AM   #121
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
mine is just about complete.
Old 03-15-2011, 01:18 PM   #122
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
Well, this should be the complete list. I had a little time at lunch to make this.
(1)92112FE500OE cONSOLE BOX
(1)92178SA020 BRACKET CONSOLE (bend the rear piece of the bracket to fit)
(1)92132SA030OE COVER CONSOLE
(4)904520014 TAPPING SCREW - TRUSS HEAD
(1)92123SA020 BOOT HAND BRAKE
(2)92177SA000 MAT CONSOLE BOX
(1)92126FE000 COVER SHIFT LEVER
(1)92123SA000 BOOT SHIFT LEVER
(4)045005143 TAPPING SCREW- TRUSS HEAD
(1)92114FE110 LID ASSEMBLY- ASH TRAY
(1)66160SA001 ASH TRAY ASSEMBLY-INSTRUMENT PANEL
(1)66063FE000OE PANEL- CENTER LOWER, SIDE RIGHT
(1)66063FE010OE PANEL- CENTER LOWER, SIDE LEFT
(4)909130018 CLIP
(6)904500025 TAPPING SCREW (numbers could be off)
(1)66086FE000OE CONSOLE-INSTRUMENT PANEL
(2)045005143 SCREW
(1)66203FE201 REINFORCEMENT COMPLETE-CENTER
(1)66069FE020 PANEL-CENTER, LOWER
(1)66061FE010 PANEL-CENTER
(1)83037FE020 SWITCH-HAZARD
(1)26001SA070ML LEVEL ASSEMBLY-HAND BRAKE (USE your old parking brake cable)
Retail on this is $838.01 + tax
Old 03-26-2011, 02:15 PM   #123
FATgc8
Member#: 98838
2005 STi
CGM
Does anybody know if someone makes a harness conversion or something to make the 05+ STi auto climate controls fit on a 02-04 wrx when you do this conversion?
FATgc8 is offline   Reply With Quote
Old 03-27-2011, 01:50 PM   #124
jr4284
Member#: 192336
2006 STiPad
I have a leftover one that I can sell you, but it has automatic HVAC, not manual HVAC.
If you do the TR conversion, you can always do what I did:
jr4284 is offline   Reply With Quote
Old 03-27-2011, 02:39 PM   #125
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
That is insanity, sir.
Smurftastic is online now   Reply With Quote
04 to 05+ center console swap mgsm666 Subaru Conversions 2 11-19-2012 08:42 AM
04 to 05 center console??? reddrex Interior & Exterior Modification 18 11-16-2012 03:28 PM
04 to 05 center console mbaker Interior & Exterior Modification 2 05-06-2009 01:39 PM
For those 02-04 who wants newer center console fluxcapacitor SCIC Private Classifieds 13 01-31-2008 09:55 AM
02-04 center console to 05+ center console swap? Wrx1234 Newbies & FAQs 2 04-15-2007 04:25 AM
