Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 12-06-2012, 03:48 PM   #176
yaya20
Member#: 130354
You can also shave a little bit off the mounting area of the 02-04 switches and they will fit the 05-07 door cards. (This does not apply to the front drivers door)
yaya20 is offline   Reply With Quote
Old 12-06-2012, 04:01 PM   #177
Zach Thomas
Member#: 278763
2004 WRX
That's what I did for my door cards, I wasn't all that excited about it at first but it's held up great.
Still haven't extended my mirror switch harness yet though...
Zach Thomas is offline   Reply With Quote
Old 12-06-2012, 11:06 PM   #178
mistathugh4844
Member#: 235548
2002 wrx hybrid
Either way it only takes a minute or 2 per switch
mistathugh4844 is offline   Reply With Quote
Old 03-09-2013, 08:45 PM   #179
Andy_013
Member#: 246299
2004 Impreza WRX
Platinum Silver Metallic
Hey where did you guys find the 05-07 radio brackets? I'm using a 07 impreza center console and radio hits the top of the bezel.
Andy_013 is offline   Reply With Quote
Old 03-11-2013, 04:29 AM   #180
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Dealer. You'll need to order these.
Radio Bracket 66201FE100 $3.16
Radio Bracket 66201FE110 $3.16
Bast is offline   Reply With Quote
Old 03-11-2013, 08:34 AM   #181
Andrew025
Member#: 303408
04 STi
Originally Posted by Smurftastic View Post
So trying to understand this... collecting parts right now... is it or is it not possible to re-use the 02-03 ebrake handle with the right DIY modifications? I am curious what the issue breaks down to... the mounting location, the cable length, or some structural difference with the handle itself?
Picture of each. If I remember correctly, the white one is the 05+
Andrew025 is online now   Reply With Quote
Old 03-12-2013, 12:32 AM   #182
Andy_013
Member#: 246299
2004 Impreza WRX
Yep your right.
Called the dealership and order it today. Around here it's 4.69 each
Old 08-19-2013, 04:33 PM   #183
stlnation
Member#: 321805
2002 Jdm v9 STI
has anyone had the problem of the ebrake does not lock up the rear wheels? i swapped the sti ebrake and kept the wrx ebrake cable. I adjusted the cable as tight as it will go but it wont hold my car on even a slight incline.
stlnation is offline   Reply With Quote
Old 09-12-2013, 01:04 PM   #184
Mr.Blue
Member#: 368012
02 WRX
World Rally Blue
Will 07 interior work in my 02?
Mr.Blue is offline   Reply With Quote
Old 09-12-2013, 03:37 PM   #185
Andrew025
Member#: 303408
04 STi
*reads thread title *
Nope, not at all. Totally impossible.
Old 09-12-2013, 03:59 PM   #186
Mr.Blue
Member#: 368012
02 WRX
World Rally Blue
Read the title wrong my bad
Old 09-12-2013, 10:07 PM   #187
emazz104
Member#: 281811
04 WRX
World Rally Blue
Yeah, you need to add washers or nuts or something to tighten the cable even more. You can't tighten the cable enough with the adjustments, so you have to space it out to get more adjustment.
emazz104 is offline   Reply With Quote
Old 03-01-2014, 06:58 PM   #188
sledge_hammer
Member#: 125784
2004 Wrx
Alright guys got everything done except these two brackets. Where do they go?
sledge_hammer is offline   Reply With Quote
Old 03-01-2014, 07:02 PM   #189
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
The middle one goes under the top vent, not sure about the other two.
Old 03-03-2014, 09:51 AM   #190
sledge_hammer
Member#: 125784
2004 Wrx
Originally Posted by SimonTuffGuy View Post
These are the clips missing from holding the hvac in place. I have them to hold the bottom of the bezel surround in place, but they are missing in the hvac area. Anyone have a part number on them?
Bump for part number
Old 03-03-2014, 10:03 AM   #191
sledge_hammer
Member#: 125784
2004 Wrx
Old 08-21-2014, 04:23 PM   #192
kaminaricelica07
Member#: 113042
2002 WRX Wagon
I need these too...no luck. I swapped mine almost 2 years ago and my HVAC controls has only 2 hold it (opposite corners).
best thing to do is buy a bezel on eBay for cheap just to get those clips...
kaminaricelica07 is offline   Reply With Quote
Old 08-21-2014, 04:27 PM   #193
kaminaricelica07
Member#: 113042
2002 WRX Wagon
search for WRX RADIO CLIMATE DASH CENTER CONSOLE or something similar
Old 03-17-2015, 12:39 PM   #194
wolfgangaddesso
Member#: 413183
2004 impreza wrx
red
What about the security box thanks
wolfgangaddesso is offline   Reply With Quote
04 to 05+ center console swap mgsm666 Subaru Conversions 2 11-19-2012 08:42 AM
04 to 05 center console??? reddrex Interior & Exterior Modification 18 11-16-2012 03:28 PM
04 to 05 center console mbaker Interior & Exterior Modification 2 05-06-2009 01:39 PM
For those 02-04 who wants newer center console fluxcapacitor SCIC Private Classifieds 13 01-31-2008 09:55 AM
02-04 center console to 05+ center console swap? Wrx1234 Newbies & FAQs 2 04-15-2007 04:25 AM
