Old 04-26-2007, 05:49 PM   #1
killthelights145
Member#: 88071
Default need help with coilover ride height
well the rear is rubbing with my 235's so i decided to raise the rear a bit
when i went to adjust them i put them on the same thread (on the coilover shaft) so they matched but one side was heigher than the other. what could be causing this?
in other words one side went up when i adjusted them but the driver side still rubbed
edit: i went to raise it even more and it sill rubbed... im 5 threads higher than the opposite side too, and still rubbing
killthelights145 is offline   Reply With Quote
Old 04-26-2007, 06:48 PM   #2
ButtDyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
What alignment and what coilovers with what spring rates?
ButtDyno is offline   Reply With Quote
Old 04-26-2007, 07:10 PM   #3
killthelights145
Member#: 88071
allignment is close to stock
fn01r-c 17X8 235 45 17's coilovers are tein ss-p 5k f and 5k r
they all go up and down fine, but the rear drivers side if i try to raise the ride height im afraid that it will be too different from the passenger rear. seems like it doesnt wanna go up like the passenger side did.
Old 04-26-2007, 07:16 PM   #4
gregr01
Member#: 49333
04 STi
java pearl black
different corner weight = different ride height
Look at any stock vehicle and the corners will be a slightly different heights.
Since you have coilovers you can adjust ride height for correct corner weights (corner balancing), or you can adjust for aesthetics so ride height is visually even all around (at the cost of optimal handling).
gregr01 is offline   Reply With Quote
Old 04-26-2007, 07:56 PM   #5
killthelights145
Member#: 88071
i did adjust it, but it wont go up for some reason, i keep turning and turning it and it wont go up....im just trying to make it stop rubbing, ill take it in for an allignment tomorow
Old 04-26-2007, 11:35 PM   #6
ButtDyno
Member#: 17301
is the "dark side"
Stock alignment + wide wheels + not that stiff springs + lowering... it isn't totally surprising that there is some rub there. Changing any of those things should help, I would think
Old 04-27-2007, 08:53 AM   #7
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
He'd have to be really low to be rubbing on 235's.
Old 04-27-2007, 09:06 AM   #8
ButtDyno
Member#: 17301
is the "dark side"
Are you rubbing on the fender liner or the fender lip?
Old 04-28-2007, 06:44 PM   #9
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
check your coilover. maybe the threads on the bottom piece (the bottom section that bolts to the hub) are stripped. jack up that corner, remove the strut bolts, and make sure the bottom bracket spins freely up and down on the shoock body. if it spins, but doesn't go up or down, the threads are stripped. if the threads are ok, you should be able to totally unscrew the bottom piece from the shock and inspect it.
lil'redwagon is offline   Reply With Quote
Anyone need help with an install? RubbleDTD Mid Atlantic Impreza Club -- MAIC 0 06-03-2010 05:23 AM
coilover ride height help please. Burtonscustom Brakes, Steering & Suspension 32 02-12-2007 02:40 PM
Subie Community: Need help with son's ride cboggess General Community 23 07-21-2005 10:14 AM
Coilover ride height question mindchatter Brakes, Steering & Suspension 8 06-14-2005 11:03 AM
Need Help with Coilovers jonmacs22 Brakes, Steering & Suspension 0 04-03-2003 10:35 AM
Message Board Statistics All times are GMT -4. The time now is 04:49 AM.
