Old 04-26-2007, 07:30 PM   #1
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Default Help with swapping a 96 Legacy 2.5 DOHC motor (Same for same)
A friend has a 96 Legacy 2.5 with a DOHC motor. It seems that the motor has the standard head gasket issue that all of those motors seem to have. The issue is that the motor has been overheated to the point that its seriously damaged. Does anybody know what other year/vehicle motors will swap into this car without any wiring? Since its a DOHC motor, I was wondering about the 98 2.5RS motor (also a DOHC). By the way, if anybody has a compatible motor, please PM me!
dexterous is offline   Reply With Quote
Old 04-27-2007, 12:19 PM   #2
austenf740
Member#: 21519
02 WRB WRX
98 RS
It should be any DOHC motor pre-98 except for the 99 Legacy GT which seems to have been a year behind I believe. I found this information out when looking for cam gears that would fit my 98 RS engine and found some off of a 99 Legacy GT. Forester also had a DOHC engine in 98 only i believe and the outback had it from 96-98 I think.
I have a list somewhere so if I find it I will post up. You could also find a working short block and swap it in as long as the heads are not damaged too.
austenf740 is offline   Reply With Quote
Old 04-27-2007, 01:02 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
In '99 the LGT, Legacy Outback, and Forester all kept using the DOHC engine. Technically, the '96 engine is a one year only engine, but any of the other DOHC Ej25's through '99 will work. Also, some importers stock a world market DOHC Ej25 that was used even later. It will also work, but requires that you use your exhaust manifold...
Old 04-27-2007, 01:34 PM   #4
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Whatever you do when you swap the new motor in do not use those crappy graphite gaskets. With any used engine you find it is a good idea to take the block and heads to a machine shop to cut a small amount off the block deck and the head surface. It shouldn't cost more then a couple hundred but will ensure there is no surface warpage that will cause future gasket seating problems or failure.
MY99 2.5GT is offline   Reply With Quote
Old 04-27-2007, 01:35 PM   #5
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
I still have my block and heads as well as all of the components for them but they are in pieces. So extensive re-assembly may be needed.
Old 04-27-2007, 02:38 PM   #6
austenf740
Member#: 21519
02 WRB WRX
98 RS
Are you sure about the Forester having the DOHC in '99? I was told of a forester that was a '99 with a SOHC in it but i guess subaru could have started using a different engine in the middle of the MY or the date of that car was wrong. You are right about the legacy outback having the DOHC still in '99 though.
Old 04-28-2007, 12:18 AM   #7
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
so you took the block COMPLETELY apart? I.E. crank, rods and pistons all laying on the shop floor next to the block halves?
~Josh~
Old 04-28-2007, 06:37 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Doing almost any earlier 2.5L swap is easy. Usually the biggest difference is things related to the intake manifold (sensors and some brackets). Sooooo...swap intake manifolds if required.
NJ - 96 Legacy 2.5 Dohc Engine ( good condition ) $900 cash pickup linnboi Engine/Power/Exhaust 0 09-28-2009 06:23 PM
Best radiator for Legacy 2.5 DOHC? Marnix Normally Aspirated Powertrain 1 02-25-2009 04:30 PM
Desperately need a 96 Legacy 2.5 DOHC motor! dexterous Private 'Wanted' Classifieds 3 04-27-2007 01:27 PM
Anyone know of Injector/Rail Upgraded for 2.5 DOHC motors? MY99 2.5GT Normally Aspirated with bolt-on Forced Induction Powertrain 24 02-07-2007 09:37 PM
96 legacy 2.5 head same as 2.5RS? WRC1 Normally Aspirated Powertrain 14 08-16-2006 09:21 PM
