Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC > NWIC Vendor Classifieds
Closed Thread
Old 05-07-2007, 02:54 AM   #26
mannslayer
Member Sales Rating: (13)
Member#: 94978
do you guys do ecutek?
mannslayer is offline
Old 05-07-2007, 12:49 PM   #27
Dyno Authority
Vendor Sales Rating: (3)
Member#: 144480
OBP 05' STi, 02 WRX
01 RS-EJ205, EG33 GM6
At this time we do not do ECUTek.
Also, PM Sent mannslayer
Dyno Authority is offline
Old 05-10-2007, 11:57 PM   #28
06subienubie
Member Sales Rating: (4)
Member#: 132286
2006 STI
sgm
Subaru Stars
Hey Ryan whats up? I'm running cobbs a/p stage 2 91 oct map on my 06 STI. The problem is my mods put me outside the of the shelf application. I've spoken with Chris H at cobb and he recommends running a wideband O2 sensor to confirm my A/F is safe. Then of course at that point a full tune is probably not much more cost(as opposed to 38G worth of car).For mods I've got a cobb turbo back, injen catless uppipe, borla header and K/N typhoon intake. Chris thinks the mapping is fine but the intake and header are outside the application and i worry about running lean at the top. What do you think?
-Jim
06subienubie is offline
Old 05-11-2007, 11:55 AM   #29
Dyno Authority
Member#: 144480
OBP 05' STi, 02 WRX
-Jim
Hi Jim,
Typically the COBB OTS maps run rich (Read: safe) and as was the case with my own and several other stg2 STi's with the typhoon intake they run even richer. The Typhoon intakes cause the MAF to read more air than is actually coming into the engine, thus delivering even more fuel. For example on my own STi, we had AFR's in the 9's with the OTS map. After a simple air tube scaler correction with the PROTuner we were able to bring that up to the mid-low 11's at WOT. We have also had a Stg2+ which had APS headers (Integral Uppipe) and a Perrin FMIC that also ran as rich with the OTS map.
The best part about the PROTune however is the increased drivability. With my own STi, the car behaves so much smother than it ever had, stock or OTS map. And the extra power is nice too! Even better, I was able to take the car on a road trip to Lake Chelan last weekend and achieved an amazing 30 mpg on that trip.
We can get you in for a PROTune as early as next week. I am confident you will love the results.
Let me know what works for you best.
Thanks,
Ryan
425-869-8324
Old 05-16-2007, 03:50 PM   #30
Dyno Authority
Member#: 144480
OBP 05' STi, 02 WRX
Default Another Satisfied ProTune!
(Originally posted by CJ)
Just got back from Dyno Authority in Redmond, WA and am really happy with how my car turned out. As far as modifications I currently only have catless d/p and catback with Cobb AP v1. Even on the mustang dyno the cars first pull netted 269whp/274 torque and not long after my STi put down 287.9whp/301 torque. Much smoother power delivery great pull to redline as well with very little drop off in power from 6k-7k, I don't have a scanner but possibly Dyno Authority can throw up my graph if anyone is interested. Can't wait to get some track numbers with the new power.
Thanks for the kind words CJ!
Ryan @ Dyno Authority
Old 06-01-2007, 12:39 AM   #31
Dyno Authority
Member#: 144480
OBP 05' STi, 02 WRX
Hey guys,
Just to let you know Dyno schedule is wide open next week.
Ryan
Old 06-04-2007, 02:10 AM   #32
NSFW
Member Sales Rating: (1)
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Is Dyno Authority the same people as FAME? More importantly, do you have access to their lifts & tools & mechanics, to get upgrades installed?
Thanks!
NSFW is offline
Old 06-04-2007, 02:21 AM   #33
Dyno Authority
Member#: 144480
OBP 05' STi, 02 WRX
Thanks!
Yep! Dyno Authority is the sister company of FAME. And yes! our tuner Tim is also our lead technician.
Gimme a call @ 425-869-8324
Ryan
Old 06-13-2007, 12:37 PM   #34
Dyno Authority
Member#: 144480
OBP 05' STi, 02 WRX
Default COBB Recommended Dyno Tuning Checklist
Hey Guys,
I just got this in a newsletter from COBB. It covers some basics about the FAQ's of pre-dyno tuning & things of that nature.
Thanks to Christian for the write-up.
[/left]
[/size][/font]
Technical Documentation
Dyno Tuning Checklist v1.00
1
s t = Mechanical Issues
You need to make sure you are tuning a healthy engine.
We suggest you complete a compression test prior to your tuning appointment. Typical compression test results should be as
follows:
8:1-8.5:1 compression: 150-170 psi per cylinder
8.5:1~9.5:1 compression: 170-210 psi per cylinder
9.5:1~11:1 compression: 210-275 psi per cylinder
11:1+ compression: 250+ per cylinder (highly depends on cams being used)
These pressure values will be less at higher elevations. Compression Tests should be performed on a warm engine and the
throttle should be held fully open while testing.
YOU SHOULD NOT have more than 20psi variance between cylinders. If you
have one cylinder that is showing a greater variance than 20psi then you will need to repair that problem prior to your dyno
tuning appointment. The additional cylinder pressure realized after a custom tune will only exploit the existing mechanical
problem causing further and usually more severe engine failure.
A Cylinder Leakdown Tests can also be performed on a warm engine.
YOU SHOULD NOT have a cylinder leakage of more
than 7% in any cylinder. If you do, then you will need to further test to see where the air is leaking from and to; intake valve
seat, exhaust valve seat, head gasket, piston rings, etc. Please know that even if these test results look good, you can still
have an engine that has some mechanical damage and the tuner/calibrator should be able to recognize the systems and
consult with you about the consequences of further tuning your engine.
2
n d = MAF, Turbo, Vacuum Lines, & Intercooler Systems
Make sure that your intake, vacuum lines, and intercooler piping are sealed when under vacuum and sealed when pressurized like when running full boost. This is super critical especially if the vehicle is using a MASS AIR FLOWsensor to meter air. A vacuum leak after the MAF sensor, but prior to the turbo will make the engine run leaner. A
boost leak after the turbo, but before the engine will make the engine run richer. Major leaks can usually be found
while dyno tuning because the data will look incorrect, but minor leaks are very difficult to find so please pressure test
these parts of your intercooler system.
Make sure you have secured all of your vacuum lines and your intercooler piping so they do not blow off at the tuning
appointment.
Make sure all of the bolts are tightened, in particular, the exhaust system bolts. An exhaust leak prior to the turbo will
lose power and make part throttle tuning almost impossible.
Make sure the blow off valve properly lubricated, seals tight, and is functioning properly.
Copyright 2007 Cobb Tuning, Inc. All Rights Reserved.
TM
Be sure to use the proper oil feed and return lines and that they are installed properly.
Turbo shaft play. You cannot expect a turbo to operate properly if has worn excessively, have the turbo rebuilt or buy
a new one.
3
rd = General Pre-Tuning Maintenance
Make sure all fluid levels are up to par; this includes engine oil, anti-freeze, transmission fluid, differential/transfer
case fluid, brake fluid, clutch hydraulic fluid, etc.
Alignment and wheel balancing, the vehicle must be able to drive straight if it is to be tuned on a chassis dyno.
Bleed the coolant system before you come for the appointment. If your engine has an overheating problem, DO NOT
come for the appointment. Because we cannot tune a car that is overheating.
The vehicle must be streetable and the driveline and drivetrain systems must be in tact and safe, if you have any
clicking CV joints then repair them prior to the tuning appointment. Be sure to inspect your wheel bearings as well.
The same stresses that your vehicles sees on the street are seen on the chassis dyno, although a failure on the
chassis dyno puts your vehicle and the tuner/calibrator in a very unsafe environment until the vehicle and chassis
dyno come to a complete stop.
Inspect and replace your fuel filter (if need be), any blockage in fuel flow to the engine will cause pre-mature fuel
pump wear and can lead to engine damage if the fuel filter clog causes a lean burn condition. Make sure that you
have the proper fuel octane and enough fuel to complete the tune. If you want a tune for race gas, we suggest you
schedule two different tunes because your engine will most likely be heat soaked after the pump gas tune and will
need significant time to cool off. Fuel Pumps, you should not have installed the fuel pump if you see dirt, debris, or
rust in the tank. If there is rust in the tank, replace the fuel tank. You will starve the engine of fuel if you leave junk in
the fuel tank.
If you engine oil and filter have been run for more than 3,000 miles, please replace the filter and your engine oil.
If you spark plugs (& wires) have more than 5,000 miles on them (if they are copper plugs) or 15,000 miles on them (if
they are iridium/platinum), please replace them with new ones. Be sure to gap them appropriately and to use a small
amount of anti-seize when installing the new spark plugs. Bring extra spark plugs, during tuning it is possible to foul
the plugs to a point where they will need to be replaced. New spark plugs are
NOT included in the tuning rate.
Make sure you have appropriately functioning brakes on the vehicle that are suited for your power level. We drive
each vehicle we tune on the street after the dyno tune to verify proper operation. We should feel safe riding in your
car after the tune.
IF YOUR VEHICLE IS OVER 5 YEARS OLD, we highly suggest you remove your fuel injectors and have them
cleaned and calibrated by an injector cleaning facility like
DeatschWerks, RC Engineering, or WitchHunter, Since the
tuner/calibrator is only metering the Lambda (Air/Fuel Ratio) from one location the assumption is that all fuel injectors
are flowing the same rate. If you have one poorly flowing fuel injector, then it is possible to further damage your
engine by completing a dyno tune.
If your vehicle is over 5 years old or is driven in a humid oceanic environment, we suggest you clean your engine
grounds and grounding attachment points. A vehicles electrical signals need to be as clean as possible so the ECM
has good signals coming in and going out. The engine harness should have no exposed wires. Also, do no twist and
tape wires together. Take the time to properly crimp or solder them together!
Battery/Alternator - Make sure these items are strong and operating properly.
Check Engine Lights or Codes - Do not come for a tuning appointment if you a check engine light is on. Please have
this problem diagnosed and fixed prior to your appointment.
If you have a new engine please read through our document about
How to Break-in Your Newly Built Engine.
REMEMBER, dyno tuning time starts when the vehicle is driven into the chassis dyno cell so our goal is to make this time as
effective as possible in order to make the cost to the client as little as possible. A tuner/calibrator's job is to develop a tuned
calibration specific to your vehicle, not fix everything that is wrong with it. If you come to an appointment with a car that is not
in proper working order you may be asked to leave depending upon the severity of the issue. If the problem is a minor and can
be easily fixed at the shop during normal operating hours, then we can fix it, but
NOT FOR FREE.
Closed Thread
2007 STi ProTUNE @ Dyno Authority Dyno Authority NWIC Vendor Classifieds 15 02-17-2009 04:07 AM
Dyno Authority Stage 2 STi numbers C J Proven Power Bragging 11 05-18-2007 01:48 PM
Stage 2 Protune @ Dyno Authority + More laueddy North West Impreza Club Forum -- NWIC 40 03-29-2007 04:00 PM
