Old 12-15-2001, 03:24 AM   #1
darkangelgrafix
Member#: 13340
1992 Ford Exploder
Ivy Gold
Exclamation Starter Problem
I recently started having problems with my 2002 impreza outback sport. Every morning for the last 2 weeks I've had trouble starting it. It will choke and after about 5-10 tries it will fly no problem. Im going to take it apart again this weekend and I suspect its either the fuel pump or the pressuere reugulator, if anyone has had this problem, post a solution, otherwise ill post one in a few days after i fix it.
P.S. If you need any performance parts call me at 858-695-0827 (Guerilla Racing) or visit my web www.grperformance.com (not finished) and i can hook you up, and if I don't carry it, I'll find you someone that does.....
Bojan 3 Beran
darkangelgrafix is offline   Reply With Quote
Old 12-15-2001, 07:27 PM   #2
Avenger
Member#: 1234
Is it cranking over by not starting or is it not cranking over?? Why don't you just bring it into the dealer?
Avenger is offline   Reply With Quote
Old 12-16-2001, 02:00 AM   #3
darkangelgrafix
Member#: 13340
1992 Ford Exploder
Ivy Gold
Exclamation starter
It turns over but it dosen't start. I figured it out. Its the fuel pressure regulator, it drops the pressure overnight and if I keep turn the key to the secon position but dont start it and keep it there for a minute it starts fine. The low grade vaccuum hose was the culprit of that one.
PS I dont trust dealers with their own business let alone my car.
Old 09-18-2002, 09:28 AM   #4
tnutrnut
Member#: 20617
2002 2.5RS Impreza
blue
Default STARTER PROBLEM
DID YOU FIX THE STARTING PROBLEM?
I HAVE HAD THIS PROBLEM IN MY LAST 2002 2.5 RS IMPREZA AND NOW THE NEWER ONE THEY GAVE ME. HELP!!!!!!
tnutrnut is offline   Reply With Quote
Starter problems turns into locked up engine problem Minnesota1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-05-2007 06:03 PM
Starter problem soxx Newbies & FAQs 4 03-14-2004 06:52 PM
starter problems aschnell Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-25-2003 09:33 PM
('93-'01) '98 obs starter problem geepondy Impreza Forum 2 07-01-2003 05:51 PM
Starter problem 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-14-2002 10:30 AM
