Old 05-01-2007, 11:31 PM   #51
07imprezadrifter
Member#: 147720
2007 Impreza 2.5i
Urban Metallic Gray
Originally Posted by vision.dynamix View Post
Considering the smilie is called "Roll Eyes (Sarcastic)" and is typed :rolleyes :...I wonder where he got the idea from.
Ever think that I didn't put let my mouse sit over it and didn't type it. And on the other vBulletin forum I go on it is labeled as "Look up"
I wonder why people have such attitudes on here......
-John
07imprezadrifter is offline   Reply With Quote
Old 05-01-2007, 11:38 PM   #52
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
i use switches for any thing i add to my car...
I have blue strobes for my FMIC at car shows and back lit plexi glass on my amps and i just put it all on switches like these..
http://www.radioshack.com/product/in...entPage=search
as a break in the ground.
-C
Chp_Stix is offline   Reply With Quote
Old 05-01-2007, 11:41 PM   #53
07imprezadrifter
Member#: 147720
2007 Impreza 2.5i
Urban Metallic Gray
Any thing I put in I wanna have a switch on. Any ideas on where to put LEDs. I dont wanna just have a color lit cab, I wanna have them in strategic spots so it looks nice. I would like to put one up on the gauges and in the cup holders in the center console box and in the little compartment below the cd player, but I don't know where I can run wires/drill holes to any of these. Also if I want to fill a drilled hole on any in any of these spots waht should I use?
-John
Old 05-01-2007, 11:49 PM   #54
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
you could build a strip with 1/8" plexi and mount your led's in that and attach it in the foot wells.
If you go with a FMIC set up you could light up the piping under hood
Gauges cluster, glove box, ashtray, center console, along the side of the center console, around the shifter base, or near any handles etc. I have also seen it done along the edge of the gauge cluster on the small flat spot along the bottom edge.
just some ideas anyways!
Old 05-02-2007, 12:05 AM   #55
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
Originally Posted by Alan l. View Post
I thought about doing this too. Something subtle...
Question - If i pick up led's with a 12v resistor already built in, is it ok for me to just tap power from lets say my radio illum. wire or the cig. plug light wires? What about powering 2-4 of those said leds with either of those two sources?
Also, do we have any place in all four of the doors where theres power only when the car is turned on or when the interior lights are on?
See my previous posts. Just pick up the part # that I mentioned above. It has built in resistor and flush housing unit. All I had to do was to drill the 9/32" hole and stick the led in, screw the small washer on the back to keep it tight. The led is flush in the cupholder. As to hook up, see my previous posts.
Now, I put the 2nd led in tonight just above the 1st one. The 2 led's are not bright at all...still not anywhere near the blue one in the pic above. It's very sutle. I got some pics but there not that great and I didn't bring a big enough memory stick w/me to my brothers. I'll get them later this week.
jikhead is offline   Reply With Quote
Old 05-02-2007, 12:09 AM   #56
07imprezadrifter
Member#: 147720
2007 Impreza 2.5i
Urban Metallic Gray
I just took a run out to my car with a few LEDs the biggest problem is that the LEDs I have are nondiffused and 30* viewing angle. Which means unless I diffuse the tip, there will be a projected circle.
-John
Old 05-02-2007, 12:12 AM   #57
07imprezadrifter
Member#: 147720
2007 Impreza 2.5i
Urban Metallic Gray
I think for the little storage space in the dash under the deck I am gonna put in a 4" CCFL but now I need to figure out how to get it out.
For the foot wells I am gonna put in some 12" CCFLs i will post pics in a few weeks after I get them in.
Time for sleep I have a final at 8am.
To let you guys in on a nice site I LOVE, oznium.com
Is there any easy way to get in behind the sidewall of the center consol to easily wire up a switch. I wanna put it about where the shifter is, where you can fit your hand up under it. it would be alot easier to run wires this way. Also where should I run the wires to?
EDIT: Oops sorry for the double post
Old 05-02-2007, 12:41 AM   #58
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
wow great site!!! ordered led's and ccfl rings and tubes uber cheap too!!
Old 05-02-2007, 10:06 AM   #59
DieselClown
Member#: 36135
2005 WRX
pretty neat idea. i'm going to be playing with the lighting in the cabin this summer. I want light by the footrest,.
DieselClown is offline   Reply With Quote
Old 05-02-2007, 10:22 AM   #60
Whiplash
Member#: 5589
'04 WRX
'99 Legacy Wagon
Sorry I havent posted back on this since I showed that pic, but you can get a pack of these LEDs from PepBoys or Circuit City for pretty cheap. It usually comes with 4 of them.
When you drill the hole, dont make it too big. If you get it just right, the LED holds into place very well. Another trick to get the light to spread out nicely is to sand or file the round tip of the LED flat. Thats how I did mine and that why it has such a wide light output.
I will take more pics when my battery on my camera gets charged up.
Oh, I also have them on a switch that is hidden, so I dont have to have them on all the time.
Whiplash is offline   Reply With Quote
Old 05-02-2007, 10:39 AM   #61
Alan l.
Member#: 90085
I want to put some in the door handle so that area glows at night like the Eclass. I would sand the bulbs so its not too bright and disperse the light output more.
Does anyone know if theres a power source inside each of the doors that I would tap power from only when the lights are on?
Alan l. is offline   Reply With Quote
Old 05-02-2007, 10:40 AM   #62
Whiplash
Member#: 5589
'04 WRX
'99 Legacy Wagon
Heres a pic without the bottle in the cup holder. Its really not bright at all. Very subtle to me. I have the LED mounted on the back wall of the cup holder so its not shining up on the roof like it would if it was mounted on the bottom of it. And I put a pic of the gauge cluster also. The LEDs in that are under the bezel.
Old 05-02-2007, 10:41 AM   #63
Whiplash
Member#: 5589
'04 WRX
'99 Legacy Wagon
This is my next project.
Old 05-02-2007, 10:46 AM   #64
Kiel
Member#: 133439
2003 WRX
Sonic Yellow - Stage Taxi
Originally Posted by 07imprezadrifter View Post
Ok well you can look at it as rolling eyes if you want. I don't see the eyes moving. I see the eyes looking up. Therefore the smiley is looking up, and your a pro so I would look up to you to do it right. Take it how you wish.
-John
Kiel is offline   Reply With Quote
Old 05-02-2007, 11:34 AM   #65
Mechie3
Member#: 120152
When I roll my mouse over the smiley it says "Roll Eyes (sarcastic)"
I would take a piece of acryline rectangular stock and make an insert. Make a hole perpendicular to the end (the seam where the piece meets when you bend it) and inseart some led's. The acrylic will acts like a fiber optic and, if you do it right, the light wont' escape out of the inside diameter as the angle of refraction is too great, but you can make it come out of the top. If you etch the sides in patterns you can get the pattern to light up.
Mechie3 is offline   Reply With Quote
Old 05-02-2007, 11:38 AM   #66
07imprezadrifter
Member#: 147720
2007 Impreza 2.5i
Urban Metallic Gray
I never said it doesn't say that when I roll my mouse over it, so why do you need to say that.
And what are you talking about. What are those directions to do?
-John
Old 05-02-2007, 01:47 PM   #67
Mechie3
Member#: 120152
-John
I said that with a " " as in, wink wink...let's all have a laugh....
Those directions with make an insert for your cup holder and illuminate it while hiding (for the most part) the actual illumination source and allowing you more control of the illumination pattern.
Old 05-02-2007, 03:30 PM   #68
dgilman360
Member#: 147411
2007 IRL + 89SupraT
i heard u could use a small resistor might be wrong
dgilman360 is offline   Reply With Quote
Old 05-02-2007, 03:42 PM   #69
07imprezadrifter
Member#: 147720
2007 Impreza 2.5i
Urban Metallic Gray
why the rolling of the eyes? thats kinda rude... but whatever... if i am back mounting it i just use the black hot glue we have, traps the light in from behind so it doesnt escape out the back and holds it in place.
i use this method almost daily we use the clear LED's that emit blue light so that the fabric/plastic/vynal color from around it goes through and makes it a color match by defualt. It actually looks quite clean and most people don't even notice the LED until it is lit!
I will post pics tomorrow in a sample piece of flat ABS
-C
Did you get a chance to snap a few pics yet? I would like to see how people are flush mounting them. I supposed I could use super glue around the corner for strength and hot glue for the rest for support. But I would rather see how a pro does it.
-John
Old 05-02-2007, 05:13 PM   #70
ERIKBROCKHOFF
Member#: 142599
How do those blue leds look when the factory gadgue cluster is iluminated. Or doe you just use these because that looks tight.
ERIKBROCKHOFF is offline   Reply With Quote
Old 05-02-2007, 08:50 PM   #71
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
I took some day time photos of mine today. I used my camera phone, so they're low quality but you can get an idea of how the install looks. I don't have the night time photos. They didn't turn out good at all. I'll have to try again when I have more time to mess w/my brother's SLR settings. Click the link below
http://pictures.sprintpcs.com/share....Page=slideShow
Old 05-02-2007, 09:27 PM   #72
brian123
Member#: 129268
black all the way around
You only have 8k miles on your 04!?!?! wow lucky do you not ever drive it?
[/quote]
brian123 is offline   Reply With Quote
Old 05-03-2007, 12:12 AM   #73
Whiplash
Member#: 5589
'04 WRX
'99 Legacy Wagon
A lil over 8,600 miles to be exact. Ill have the car 4 years this August. First 2 years I had it I lived 2 miles from work. Now its become my shop car for shows and promotions.
Old 05-03-2007, 02:08 AM   #74
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
This is really tempting. What did you guys tap it into? Is there a way to get it to dim with the rest of the interior lighting?
sheepdog is offline   Reply With Quote
Old 05-03-2007, 04:38 AM   #75
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
whiplash how did you wire up the leds in your cluster? have a write up possibly? also any picks witht he cluster lit up...im way interested in doing this.
B00st3dWRX is offline   Reply With Quote
FS CA: JDM STI cup holder with business holder orwrx Interior/Dressup/Audio & Security 17 04-06-2011 06:07 AM
card holder in replacement of cup holder 949 Interior & Exterior Modification 2 02-24-2009 01:54 PM
FS: JDM Cup holder & business card holder, 02 WRX Cluster and MORE! *pics* iimiketii Interior/Dressup/Audio & Security 17 02-13-2008 10:46 AM
JDM Cup holder and Business card holder *pics* racerx66 Interior/Dressup/Audio & Security 8 03-02-2007 01:33 AM
Dual Front Cup Holder and Rear Cup Holder? 2k2 Interior & Exterior Modification 5 12-18-2001 03:55 PM
