Old 04-28-2007, 03:09 PM   #1
adamoliver
Member#: 56057
2003 WRX
pearl blue
Question replacing front a/f sensor
so I got the CEL p0031 code a few weeks ago on my 2003 WRX. after checking the forum, i found the cause and ordered a new sensor. now i can't get the old one out of the freaking socket. How do you get a wrench around the sensor - do i have to take off the heat shield? That doesn't seem possible without removing a whole bunch of stuff. i sprayed a ton of WD40 on the thing and tried to twist it out with needle nose pliers - of course that didn't work. Does anyone have past experience with this job? Thanks.
adamoliver is offline   Reply With Quote
Old 04-28-2007, 03:15 PM   #2
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
yeah, the front a/f sensor is a pain. those of us who've done uppipe installs know. best way to get at it is front under the car. use a 7/8" open end wrench and you should be fine. i would use pb blaster vice wd40 as well.
anthonyrb98 is offline   Reply With Quote
Old 04-28-2007, 04:24 PM   #3
hondaeater69
Member#: 60324
it's also easier to unplug the sensor first, then unscrew, alleviates the twisting of the wires. works on install too.
Old 04-28-2007, 05:16 PM   #4
adamoliver
Member#: 56057
2003 WRX
pearl blue
thanks for the insight, guys. Looks like it's another trip to the hardware store!
Old 04-28-2007, 05:50 PM   #5
WeldingHank
Member#: 98645
2002 WRX Wagon
7/8" flare nut wrench the THE best for removing stock WRX 02 sensors.
WeldingHank is offline   Reply With Quote
replacing front o2 sensor with wideband? vincent-h Service & Maintenance 3 03-23-2009 12:38 PM
FS: 05 STi Front A/F Sensor and rear o2 Sensor - Brand new in box! Timmy Burns Engine/Power/Exhaust 3 01-24-2008 10:38 AM
replace factory front a/f sensor w/ a wideband sense of nature Built Motor Discussion 9 10-08-2007 06:39 PM
hrs to replace front 02 sensor buskibum Normally Aspirated Powertrain 10 07-20-2007 08:09 AM
Replacing front Oxygen Sensor mstein Normally Aspirated Powertrain 10 05-18-2007 09:55 PM
