Vancouver Impreza Club
Old 04-29-2007, 11:43 AM   #1
snow111
Member#: 60153
2002 Impreza TS
Sold it.
Default What are the signs you need a new clutch
Hi,
Need some advice/help. I have 2002 TS wagon, no significant mods except coilovers, front/ rear strut bars, and upgraded WRX mags. I had the clutch replaced about 30k under factory warranty, it was chattering a lot when the car was driven cold. After that, the chattering stopped, and no problems.
Now I have 64k, and yesterday when i accelerated hard in 3rd and 4th gears, i saw the revs go from 3g's- about 4 or 5 g's but did not really feel the car accelerating.
Are my worst fears coming true? If I do need a new clutch, do you know whether Subaru would replace another clutch for me, as this one only has about 34k's on it? I don't drive hard much at all, mostly just all city driving, to and from work. Could all that downtown driving wear out your clutch?
Any advice as always is appreciated, from the VIC.
snow111 is offline   Reply With Quote
Old 04-29-2007, 11:47 AM   #2
FNR32
Member#: 84147
03 WRX
Well that was the clutch slipping im sure, but as to if u need another one, im not sure. It could just be glazed and will go away once it warms up (happened in my wrx a few times) or it could be screwed. I don't think u can get another clutch under warranty, but it never hurts to ask.
FNR32 is offline   Reply With Quote
Old 04-29-2007, 11:57 AM   #3
snow111
Member#: 60153
2002 Impreza TS
Sold it.
see below
Old 04-29-2007, 12:03 PM   #4
snow111
Member#: 60153
2002 Impreza TS
Sold it.
hey thx. im a newby, what do u mean by glazed? is there a coating on it like a donut? :-)
Another question, are suby clutches weaker than compared to other cars. I think I read somewhere if you are buying an impreza, the automatic tranny's the better way to go.
Old 04-29-2007, 12:18 PM   #5
madcat
Member#: 82465
2014 Forester 2.0 XT
MBP
There's nothing wrong with the stock Impreza clutch -- under normal driving, they should last a lot more than 34,000 km. Driving style has a lot to do with clutch wear. It's possible to kill a clutch in 1 km if it's overheated enough. Slipping the clutch with a lot of revs, say on a hard launch, or a hill start will cause a lot of wear to the clutch.
I don't know where you heard that auto Imprezas are better. Autos are for people that don't have use of their left leg.
madcat is offline   Reply With Quote
Old 04-29-2007, 12:24 PM   #6
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
No, there's no sugar coating on the clutch. What ends up happening is the surface of the clutch becomes "polished" or "glazed" due to the fly wheel and clutch surfaces rubbing against each other too much. When this happens, there isn't enough friction for the clutch to catch onto the flywheel, hence slippage.
If I were you, find out how fast your car goes in 3rd gear at around 3-4k RPMs. Then, when you find a safe area to test to see if your clutch is slipping or not, do your acelerate in 3rd to see if your car is traveling as fast as it's suppose to be going at that same RPM/gear. If not, then your car probably has a worn-out clutch.
Some people notice the clutch slipping more often while trying to acelerate up a hill.
Subaru's are known to have some-what of a finiky transmission. When you push 140-300hp through all four wheels, something has to give. It's either your tires breaking free and burning rubber, or your half shafts snapping, or your transmission gears breaking or your clutch slipping. When you pump 200hp to the ground through two wheels, then it's usually the tires that break free and squeel. Output that same amount of power through four wheels, and it could be the transmission gears that break. That's what gives the Subaru transmission such a "bad rap." I do know of someone who broke his 1st gear while launching hard with sticky tires - this was done with an old RS with 165hp!
Between clutch and transmission, I'd rather have the clutch give out rather than the gears to be broken.
Good luck with the clutch.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 04-29-2007, 12:24 PM   #7
snow111
Member#: 60153
2002 Impreza TS
Sold it.
I don't know where you heard that auto Imprezas are better. Autos are for people that don't have use of their left leg.[/quote]
Thx, madcat. I think it was in one of the nasioc forums that someone somewhere said a high proportion of the impreza non wrx wagons were auto, as the clutch is weaker that other cars. i also heard the wrx owners saying their stock clutch is not up to par, but like you said if you do a lot of spirited driving, most stock clutches won't be up to par. i'm just thinking on my old mx-3 precidia v6, i had over 120k's and never had a problem with the clutch, and i drove that car harder than my impreza.
Old 04-29-2007, 01:11 PM   #8
GlobalWaste
Member#: 74792
GlobalWaste is offline   Reply With Quote
Old 04-29-2007, 01:25 PM   #9
madcat
Member#: 82465
MBP
My 73,000+ km stock clutch has no problem holding 250 whp, but I would expect the WRX clutch to be beefier than the TS. Still, 34k isn't very long at all.
Driving a car hard isn't necessarily hard on the clutch, as long as you aren't constantly dumping heat into it (slipping).
Old 04-29-2007, 02:18 PM   #10
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Originally Posted by amarpauld View Post
I'm at 96k on my stock clutch... drag racing and autox included
And it's on its way out now, eh Paul?
semaj is offline   Reply With Quote
Old 04-29-2007, 06:43 PM   #11
buster
Member#: 41811
02 WRX
I'm at 96k on the stock clutch too. Been running 240+whp for 2-1/2 yrs now and have done 2 track days and 40+ autoX events.
buster is offline   Reply With Quote
Old 04-29-2007, 09:21 PM   #12
GlobalWaste
Member#: 74792
Old 04-30-2007, 02:16 AM   #13
snow111
Member#: 60153
2002 Impreza TS
Sold it.
QUOTE=Penphoe;17895391 If I were you, find out how fast your car goes in 3rd gear at around 3-4k RPMs. Then, when you find a safe area to test to see if your clutch is slipping or not, do your acelerate in 3rd to see if your car is traveling as fast as it's suppose to be going at that same RPM/gear. If not, then your car probably has a worn-out clutch.
Hey Darren Z,
I tried this today, and there 's no slippage. Keeping my fingers crossed for now.
Thx again for everyones input.
What are the signs of a bad Alternator? wrx03.4wz Electrical & Lighting 13 12-23-2009 09:34 PM
What are the signs your Struts/ Springs are wearing out? snow111 Brakes, Steering & Suspension 9 02-12-2007 04:54 PM
The top 3 signs you need a new Oxygen sensor are? sovereignmk1 Legacy Forum 6 08-10-2004 07:29 PM
What are the signs of a motor that is about ready to let go? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-19-2004 10:11 AM
What are the signs you're running rich? Canadian 2.5RS Normally Aspirated Powertrain 11 01-09-2003 08:07 PM
