Old 12-15-2001, 07:51 PM   #1
fastwrx
Member#: 7398
2004 2004 WRX-STi
Default Drying Rex after washing
Hi all,
I have a hard time drying my car after washing. I've used both a synthetic chamois from Griot's and "the Absorber." Neither seems to work that great. Always leaves a film of water behind. Any hints? Thanks!
Mike
fastwrx is offline   Reply With Quote
Old 12-15-2001, 08:00 PM   #2
Jakezor
Member#: 9624
2002 ImprezaWRXsedan
Platinum Silver Metallic
Air dry at 90mph+
I use a real chamois and then just go for a quick drive (usually not that fast).
Jakezor is offline   Reply With Quote
Old 12-15-2001, 08:15 PM   #3
Skyline
Member#: 6074
2002 Impreza WRX
Sedona Red Pearl
Default MF Towel!
Follow up after your Absorber with a Microfiber Towel. It'll pick up the leftover water very quickly and without harm to your paint.
Fyi, I use a Water Bandit synthetic chamois for drying, and MF Towel for practically everything else.
/mel
Skyline is offline   Reply With Quote
Old 12-15-2001, 08:17 PM   #4
Tats
Member#: 5692
WTF? YES! I am
better than you!
I use the California Water Blade first then the "Absorber".
If you're using the Absorber and you have a water residue left then your just not doing it right. ou may get the occasional haze but it will always dry clear.
Tats.
Tats is offline   Reply With Quote
Old 12-15-2001, 09:21 PM   #5
GoodFinder
Member#: 8943
2006 MINI + Corvette
Both Blue
I must not yet be using the "Absorber" right because I too have a very difficult time getting it properly dry. Comments and suggestions on how to dry the WRX after washing are very desired and helpful! GoodFinder
GoodFinder is offline   Reply With Quote
Old 12-15-2001, 11:20 PM   #6
DubbleURX
Member#: 10448
Fastwrx...
Well first of all i have the absorber also and well it works good but always leaves just the little after each wipe.
Now noone else knows what we are talking about cuz look at their profiles and look at the colors of car??
Our cars are black. It shows EVERYTHING
My friend has a silver one and i used my absorber on his car and with a couple wipes his is all fine and can't see any of the stuff i can with mine.
It's cuz the car is black thats it, blue would have a little hard time too but we are really bad.
But what I do to totally get rid of it is
1. Go over whole car with the absober
2. Go over whole car again with absorber
3. Get out the meguiars quik detail and do the whole car
4. Drive to whereever your going
5. get out and with the quik detail again get all the spots where the drips come down and leave more marks (rear bumper and behind the spoiler supports, the front doors from the drops off the mirror, front bumper from the grill)
6. All done Then by that time its already dirty again so start over
Danny
DubbleURX is offline   Reply With Quote
Old 12-15-2001, 11:27 PM   #7
02 T-WREX
Member#: 11449
2006 STi
SGM
Default drying
First... when you rinse the car off before drying, make sure you just let the water stream off the car. Don't spray the car, just let the water flow off... that way there will be less water for you to dry off. Then use the Absorber to get most of the water off (it will ALWAYS leave streaks). Follow up with a damp Microfiber towel to get rid of the streaks. This method is really quick and will keep scratches to an absoulte minnimum. If you are REALLY anal (like me)... just lay the absorber on the car one section at a time without wiping, then use the microfiber to finish up. That way the ONLY thing to ever be wiped against the car is microfiber.
-Chip
02 T-WREX is offline   Reply With Quote
Old 12-16-2001, 01:01 AM   #8
ascott
Member#: 6545
Rally Blue Pearl
I'm with Tats
I have one of those California Water Blades. Use that to get most of the water off, then follow up with the Absorber to get the spots the bade couldn't reach.
Big issue with the blade: the car must be absolutely clean. The blade won't scratch, but it will drag anything that is already on the surface along.
ascott is offline   Reply With Quote
Old 12-16-2001, 02:21 AM   #9
jesse370
Member#: 12147
2005 g-35
ivory pearl
Also the type of wax you use can help too. The wax I use like 70% of the water just beads off my car, the rest gets picked up with a shamy real easy. And my car will show what you missed.
jesse370 is offline   Reply With Quote
Old 12-16-2001, 05:11 AM   #10
whitewag
Member#: 10164
2002 Black Sedan
looks stock
I have my car waxed pretty well so most of the water just drip's right off. Other than that I bought a leaf blower to get in the door's, inside of the side mirrors and the rest off the car.
whitewag is offline   Reply With Quote
Old 12-16-2001, 07:59 AM   #11
GRWRX
Member#: 4129
2002 WRX sedan
Do what Chip says, the water almost disappears by itself. I've been doing that for years.
GRWRX is offline   Reply With Quote
Old 12-16-2001, 10:50 AM   #12
Skyline
Member#: 6074
2002 Impreza WRX
Sedona Red Pearl
Default Maybe it's the Absorber?
I had thought the Absorber was functionally equivalent to the Water Bandit that I use...but maybe not? I really don't have any issues with using the Water Bandit exclusively to dry everything. I dry all the surfaces with it, and follow up with the MF towel for difficult to reach places, like mirrors, etc.
What is your technique for using the Absorber? With my Water Bandit, I lay it out on the surface and drag it across. It soaks up all the water right away.
If you want to try out the Water Bandit, I got mine at www.kleanride.com.
Hmm..
/mel
Old 12-16-2001, 01:46 PM   #13
2.52G
Member#: 2026
2000 RS Coupe
SRP
I don't know what you guys are talking about. I have a black 99 and I wash my car, dry it, take it for a quick ride to get out the hiding water, take out the absorber again and get anything I missed, never really left any streaks. One thing I do is when I squeeze the absorber I squeeze it till there is no water left. I don't know I'm going now
2.52G is offline   Reply With Quote
Old 12-16-2001, 03:08 PM   #14
lilo
Member#: 11277
2002 WRX MBP
Burn the Worms!
Default Old Standard
Terry cloth towels work best for me. I use
roughly 30, one foot square towels, folded in
quarters, and each side is used for a one foot
area. The towels are used for only two or
three washes. Thrown in the washer with only
detergent, then washed again without detergent.
I buy a bag of 12 at Pep Boys every other
week. Terry cloth can really pick up water,
and I believe that by rotating them often you
run less of risk of picking up any particles that
will scratch the surface.
What can I say, I love my WRX.
But whatever works for some doesn't for others.
To each their own.
lilo is offline   Reply With Quote
Old 12-16-2001, 05:57 PM   #15
juztin180
Member#: 11804
Water blade will scratch your car, so be careful.
Its not that "it" scratches it, but whatever it drags across.
Absorbers suck too. I just use a damn towel and get it over with..my cars got swirls anyway.dunno what im gonna do when i get my REX, but i'm buyin' silver..cuz i have white now and my girls car is black...i hate 'em both wash-wise
where do you buy these MF towels? <- hehe...sounds funny, damn MF'n towels
juztin180 is offline   Reply With Quote
Old 12-16-2001, 07:01 PM   #16
DubbleURX
Member#: 10448
Old 12-16-2001, 07:10 PM   #17
Skyline
Member#: 6074
2002 Impreza WRX
Sedona Red Pearl
Talking
Hahah.. I like that. You can get your MF'n Towels at www.yosteve.com. The towels he sells are the same as the Microfiber Magic Towels sold at a certain well known online retailer, but for half the cost. Top notch quality, least likely to scratch your paint. I use them for cleaning windows, drying the car, dusting the dash, etc etc. They're the ultimate do-it-all towel.
If you want to get bath towel sized MF, www.neatitems.com has those.
/mel
Old 12-16-2001, 08:27 PM   #18
rakman
Member#: 7906
04 Sti Black
02 WRX Red
1) California Water Blade first to get rid of most of the water
2) "absorber", chamois leather or micro fiber towel for what's left
( I prefer the micro fiber)
Whole drying process takes 10-15 minutes
rakman is offline   Reply With Quote
Old 12-16-2001, 09:32 PM   #19
128d
Member#: 7792
2002 Prodrive
widebody Cosworth 2.5 6sp
rakman- I have heard that the California Water Blade can cause debris to scratch the paint. Have u noticed anything yet?
128d is offline   Reply With Quote
Old 12-16-2001, 10:13 PM   #20
whitewag
Member#: 10164
2002 Black Sedan
looks stock
I've used the california water blade and it does promote scratches if your surface and the blade is not completly clean. I don't like to drag anything on the car if possible. Pat dry with a cotton towel works great.
Old 12-16-2001, 11:23 PM   #21
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
I used the big blue Mf towel from CMA today when I washed my car and I must say, it absorbs ALOT of water.
The towel pretty much dried my WHOLE car, because it was the only MF towel I had, i had to use it and only it to dry my scoobie. I suggest reading up at www.autopia-forums.com they have TONS of great ideas, I plan on buys a few more MF towels, probably 3 for drying, and 3 small ones for buffing.
Thats just what I plan on.
Bryan
2k2 is offline   Reply With Quote
Old 12-17-2001, 02:31 AM   #22
DubbleURX
Member#: 10448
Anyone ever use the cotton diapers for waxing and such?
MY friend uses that on his ca and he says it works great.
But damn for a diaper they must be able to get fullwith lotsa liquids right? Maybe thats a good idea to try.
That or just go buy some MF'N towels!!!
Danny
Old 12-17-2001, 04:04 AM   #23
Darwin
Member#: 2704
2001 Impreza 2.5 RS
Blue Ridge Pearl
The water blade works great, you just have to run your finger along the edge after each stroke. I haven't picked up a single noticable scratch from it after doing that.. (The cats are another matter, dammit!)
Darwin is offline   Reply With Quote
Old 12-17-2001, 07:50 AM   #24
lilo
Member#: 11277
2002 WRX MBP
Burn the Worms!
Actually Danny, it depends (no pun intended).
Most diapers will actually leave
scratches in the paint due to their
fiber construction, stitching and the
fact that they will not "pickup"
particles like terry cloth towels. I have
not personally used MF towels,
however I believe that both have a
"pickup" capability due to their makeup. I still use terry cloth for
waxing and drying.
Disclaimer: Whatever works for you,
works for you.
Danny
Old 12-17-2001, 08:30 AM   #25
rakman
Member#: 7906
04 Sti Black
02 WRX Red
128d:
I've had no scratches from the water blade. I clean and rinse it after each car wash and store it somewhere it won't attract dirt.
However, I do have virtually undetectable circular "swirl" marks - I think from using an orbital polisher
ABS, Airbag, and Rear Diff light on after washing engine Acejam2k Factory 2.5L Turbo Powertrain 6 06-02-2010 12:32 PM
Drying off after a shower Reciprocity Off-Topic 61 09-08-2009 04:59 PM
pics of my sti after wash WRXout Member's Car Gallery 19 02-28-2005 02:16 AM
rough engine after wash - what got wet? angus Factory 2.0L Turbo Powertrain 15 04-03-2002 04:27 PM
Took a couple pictures after washing. dwx Member's Car Gallery 19 03-08-2002 03:09 PM
Message Board Statistics All times are GMT -4. The time now is 09:18 AM.
