Old 04-30-2007, 05:59 AM   #1
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
Default How to wrap header?
I have this APS header and this header wrap.
Now I need them to come together.
Does anyone know where there is a write-up of how to wrap the header? I saw one here, but it only had to do with using the hi-temp spray to do it.
AWD>FWD is offline   Reply With Quote
Old 04-30-2007, 01:06 PM   #2
flycaster
Member#: 60142
2011 WRX
Grey
Wet it with water, spiral wrap it with overlap, fasten it at both ends of the wrap, let it dry, spray it, done.
flycaster is offline   Reply With Quote
Old 04-30-2007, 02:03 PM   #3
Black-Falcon
Member#: 106318
14 Cadirrack
ATS
Don't go crazy with the over lap though. Only do it as much as the product tells you. or about .5" to an inch.
Black-Falcon is offline   Reply With Quote
Old 04-30-2007, 02:08 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
The overlap should be 1/2 the product width - it's a pretty basic concept, but I suppose there are some guys who might not figure this one out...
Old 04-30-2007, 02:47 PM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you'd be surprised, FC... dei says 1/4" overlap, no more, no less, and irrespective of the wrap width:
http://static.summitracing.com/globa...dei-010101.pdf
fwiw, i overlapped more than 1/4"
ken
Old 04-30-2007, 02:51 PM   #6
Badler
Member#: 133597
ken
Me too
Badler is online now   Reply With Quote
Old 04-30-2007, 02:54 PM   #7
jlp7t
Member#: 46160
2004 WRX STi
COBB DP,AP Stg. 2,Typhoon
APS + wrap = SOL when your expensive header cracks, as I don't think APS is replacing coated or wrapped headers that happen to crack.
jlp7t is offline   Reply With Quote
Old 04-30-2007, 03:35 PM   #8
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
get it welded when it cracks.
Use 1" wrap, and take your time. 1/4" overlap, pull it tight.
Zornorph is offline   Reply With Quote
Old 04-30-2007, 04:55 PM   #9
flycaster
Member#: 60142
2011 WRX
Grey
Common' guys. Think about this: if you use 1" wrap with a 1/4" overlap, you end up with 50% of the pipe with one layer, 50% with 2 layers. I don't care what the "directions" say, does that make any sense whatsoever to you? Do you think it's "good" for the pipe to be so unevenly heated???
Old 04-30-2007, 06:27 PM   #10
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i agree that the suggested method leaves a lot to be desired.
Old 04-30-2007, 08:01 PM   #11
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
Can't explain it- it's just what the guys who make it say.
Old 04-30-2007, 08:18 PM   #12
flycaster
Member#: 60142
2011 WRX
Grey
^^I realize this, and I wasn't trying to jump you here. It's just that it makes no sense - reality and common sense are good tools to keep at the top of the box.
Old 04-30-2007, 08:37 PM   #13
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
I have been hearing they crack UNLESS you wrap them.
It even says when you order the header "Wrapping or coating is strongly recommended".
Thanks for your input.
Old 04-30-2007, 10:13 PM   #14
flycaster
Member#: 60142
2011 WRX
Grey
You know, this is well worth a call or email to APS for absolute clarification before you write the check. IINM, they have denied warranty replacement for wrapping in the past....
If nothing else, it's peace of mind.
Old 04-30-2007, 10:18 PM   #15
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
I would like to put in a small point --
Why would the wrap manufacturers recommend you use LESS if more overlap were beneficial? The more overlap there is, the more wrap they sell. They probably recommend that very small amount for a reason.
I have no idea why it would be better to have small overlap, but I would think it to be related to friction or moisture.
Just my .02...
lancelucas is offline   Reply With Quote
Old 04-30-2007, 10:52 PM   #16
flycaster
Member#: 60142
2011 WRX
Grey
I understand what you're saying, but I think the reason is cost. Look, this stuff is NOT cheap. At some price point, people won't buy it. If that $70/header suddenly becomes $140/header due to tighter wraps, what happens? Me? I think it's a business decision, not an engineering decision; friction is not at play here, and residual moisture is the same problem no matter how it is wrapped. (If you use these in a wet, humid environment and don't regularly get them hot and dried out, you'll have corrosion, period.)
Consider this: why do many racers, who really believe in doing everything they can to accelerate exhaust flow and thus Ve, use multiple layers of heat wrap, and even then seal the wraps with an extra wrap of thick aluminum foil? To them, cost is no issue and performance is everything.
Good, really thick heat wrap is pretty darned impressive. I use a turbo blanket that is about 4 layers thick and I can literally put my hand on the turbo hotside when it is on the dyno - it's hot, to be sure, but not "get me to the frigging hospital" hot like it would be otherwise. Try that with ceramic coating and it's "call 911" baby.
Old 05-01-2007, 05:12 AM   #17
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
So, when I wrap it do I need those metal zip tie dealies?
Old 05-01-2007, 08:36 AM   #18
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
the dei kits come with the zip ties. I've seen race fab shops use safety wire as well.
Old 05-01-2007, 10:10 PM   #19
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
I've gonna use pipe clamps.
How much water do I need? Will it be pretty obvious as soon as I start?
Old 05-01-2007, 10:24 PM   #20
flycaster
Member#: 60142
2011 WRX
Grey
I know that is tempting, but you need to use stainless steel to withstand the heat. They may hold..they may not.
As for water, just get a bowl and dump the roll in (loosen it up a little first) and cover it with water - let it sit there a minute or 2 and it'll soak and be much easier to roll onto the pipes.
Old 05-02-2007, 12:27 AM   #21
Black-Falcon
Member#: 106318
14 Cadirrack
ATS
Might wanna wear gloves too...I was kinda itchy after doing it.
Old 05-02-2007, 04:38 AM   #22
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
We wore gloves and used pipe clamps.
I used the black Cool-It wrap, it looks very nice.
I have heard of others using pipe clamps with no problems.
All we needed to do is get a wet rag and wipe down the wrap as it came off the roll, very easy.
Old 05-02-2007, 06:41 AM   #23
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
when you guys say "pipe clamps," do you mean something like this?
if so, i don't think i've ever seen any that WEREN'T stainless...
Old 05-02-2007, 07:48 AM   #24
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
That's what I used.
I was under the impression they were stainless.
I work a lot on old POS cars/trucks using these and only the very, very old (installed in the 80's) rust.
Old 05-02-2007, 08:18 AM   #25
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
By the way, for anyone interested I only needed 1 roll for the header alone.
I used APS's heat shielding for the up-pipe and wrapped my Helix DP up to the cat with the beginning of the other roll.
How to install headers on 06/07 2.5I welli04886 Normally Aspirated Powertrain 22 03-08-2014 01:25 PM
How to wrap the bellmouth portion of the DP? lavid2002 Newbies & FAQs 5 12-28-2009 11:16 AM
How to install Headers? jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-30-2009 07:45 PM
how much heat wrap will it take to wrap headers and down pipe jeremywrx15554 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-29-2008 02:03 PM
how to wrap my thermotec jacky599r Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-18-2008 05:04 AM
