04-30-2007, 05:23 PM | #1 |
Member#: 68955
South East
Vehicle:2005 WRX Hybrid Needs Paint |
Blouch TD05H-18G 8cm^ Turbo Installed! (With Pics)
Just finished the install...Preliminary road tune with ST...Feels very strong at 20psi!! Protune will happen May 18. Looking foward to feeling the power after the tune!
Mods: Blouch TD05H-18G 8cm^2 (TD06 Compressor Housing) APS DR525 FMIC APS CAI APS Turbo Inlet APS Twin Vent BOV PE800cc Injectors Walbro 255lph Fuel Pump NGK Iridium 1 step colder Prodrive Boost Control Solenoid Cobb Uppipe and Turboback Exhaust w/high-flow cat Tuning Update: The first round of tuning has been done on this setup with a conservative map. The car is very smooth and pulls very hard all the way to redline. Matt Holland (ShaggyGT on here) did the tune and did a great job! Great guy to work with as well. 93-pump gas tune: 310whp/278wtq - mustang dyno It's so smooth it feels like it does this with little effort. We think there may be a little more to gain with another round of tuning. I may revisit that as well as a race-gas tune. Spooling (3rd gear pull - 5mt) 16psi @ 3300rpm 18psi @ 3500rpm 20psi @ 3600rpm 21psi @ 3700rpm It's awesome!! Stock TD04 on right:
04-30-2007, 05:39 PM | #2 |
Member#: 139485
Vehicle:2004 16g WRX DomTune Java Black Pearl |
worm worm worm!
04-30-2007, 05:45 PM | #3 |
Member#: 12454
Vehicle:10 Toyota Taco K8 SV650SF |
SWEET!! Thats a td05 housing? That thing is no joke.. looks alot bigger than my little 16G
04-30-2007, 05:46 PM | #4 |
Member#: 78118
Vehicle:2002 Corvette coupe 05 Legacy |
why does my tdo5 18g 7cm look sooo much smaller than yours when compared to the stock turbo???
04-30-2007, 05:48 PM | #5 |
Member#: 68955
South East
Thanks! Oh....The Blouch came with the TD06 compressor housing. Updated OP...
04-30-2007, 05:58 PM | #6 |
Member#: 78118
i was ganna say wow i got screwd that turbo u have is huge
05-01-2007, 10:10 PM | #7 |
Member#: 62856
Vehicle:MBP SQC#197 Stockpiling parts... |
So what does the larger housing do compared to the regular housing? More top end at the cost of slightly more lag?
05-02-2007, 09:39 AM | #8 |
Member#: 127421
Vehicle:2002 Subaru WRX WRB |
05-02-2007, 09:44 AM | #9 |
Member#: 127421
05-02-2007, 10:43 AM | #10 |
Member#: 68955
South East
No...
TD05H is the turbine wheel 18G is the compressor wheel TD06 is the compressor housing 8cm^2 is the turbine housing Blouch indicates this particular turbo uses td06 18g wheel in a td06 compressor housing. Blouch also states the td06 compressor housing maximizes compressor efficiency. Whether or not that is just marketing -- I don't know. I'll be seeing the numbers soon. |
05-02-2007, 10:52 AM | #11 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
i haven't seen a lot of downsides to larger compressor housings. perhaps (when you get really big) interference with tgv or bellhousing...
fwiw ken |
05-02-2007, 11:07 AM | #12 |
Member#: 35269
Vehicle:2011 WRX |
Were your vacuum connections on the blouch different from the OEM sizes?
I just installed a Blouch 20g and mine were way off. I'm still trying to figure it out because with all the reducers I have on mine, I'm not comfortable with it. |
05-02-2007, 11:37 AM | #13 |
Member#: 68955
South East
Ken -- thanks man, that's good to know. With this housing and the APS turbo inlet, I had to modify the uppipe brackets and uppipe to get it lined up correctly. The turbo housing is almost touching the bell housing and I had to grind a little off the turbo housing to clear the breather tube that comes up from the engine block.
Anything larger and I'd go rotated mount. |
05-02-2007, 11:44 AM | #14 | |
Member#: 68955
South East
I'll have a prodrive 3-port boost control solenoid in hand tomorrow and will work out the vacuum lines and any reducers once I have the part in hand. This gets rid of the restrictor pill issue completely. In the mean time, I'm running wastegate spring pressure (15psi) with a line running from the turbo compressor to the wastegate actuator. My first attempts at tuning this turbo with the stock boost control solenoid and Street Tuner got me 23psi with 0***37; WGDC. And the boost would have kept on going if I had not let off . I knew then I needed to change something mechanically. |
05-02-2007, 11:50 AM | #15 |
Member#: 35269
Vehicle:2011 WRX |
I'm glad I wasn't alone
I'm going EWG and looking for options for another boost solenoid so I'm hoping to bypass all the stock hoses, pills, etc. How about your upper coolant line on the turbo? Mine is an extremely tight fit and the rubber is sitting on the housing. It's not leaking but I really don't like how it's sitting on there. Besides that, this thing is beautiful. EWG and a tune and I'll really start ranting about it. |
05-02-2007, 12:02 PM | #16 |
Member#: 68955
South East
Yeah, my upper coolant line was tight, but not touching anything. I thought if it were any tighter, I could trim it a bit for a better fit.
I agree -- this thing is a beauty. It was pulling crazy hard at around 22psi! Just need to get these minor issues sorted and away we go! |
05-02-2007, 12:07 PM | #17 |
Member#: 35269
Vehicle:2011 WRX |
Maybe I'll try to find a smaller OD coolant line for it. Seems like my only option.
Glad to see someone else with a Blouch Rock on! Make sure you post up after your tune! |
05-02-2007, 12:12 PM | #18 |
Member#: 36135
Vehicle:2005 WRX Aspen White |
very nice!
05-02-2007, 12:25 PM | #19 |
Member#: 142490
Vehicle:2002 SUBARU WRX WHITE |
thats a very sweet set up you got there....!!
05-02-2007, 03:52 PM | #20 |
Member#: 68955
South East
Thanks guys! I'll post up the tuning results.
b0dh1: I helped a friend install a Blouch Dominator III on his STi in Feb. This is the one with the 52 lb/min wheel. The thing is a real beast -- almost scary When you hit it the turbo screams as you are thrown back in the seat. |
05-03-2007, 09:54 AM | #21 |
Member#: 88032
Blouch 18G turbocharger
Great turbo, you can't go wrong with this 18G on a 2 litre WRX. We have a project car using 18G 7cm^2 put down 321whp, 280wtq @20psi on 98ron (93octane) straight pump; and pulls 339whp, 297wtq @21psi on 100ron (95octane).
The car break all fours lose even on third gear on a JDM 6 speeder. Note that it wears 18 inch footer. Mods: HKS Super Mega Flow Intake Silicon Turbo Inlet Hose SARD R2D2 Racing Blow off Valve SARD Fuel Pressure Regulator @ 3 Bar Ported Stock Exhaust Header 3 inches Down-pipe & Mid-pipe 2" Flex Up-pipe Remus Titanium Exhaust ECU Reflash Blouch TD05-18G 7cm***178; Turbocharger Uprated Turbo Boost Controller Solenoid Large Top Mount Intercooler 800cc Mod Injectors 255lph High Pressure Fuel Pump Write up here: http://www.sg-autotec.com/history_contents3.html Dyno video here: http://www.sg-autotec.com/video01.html |
05-03-2007, 10:05 AM | #22 | |
Member#: 35269
Vehicle:2011 WRX |
05-03-2007, 06:12 PM | #23 |
Member#: 140621
TXIC
Vehicle:2005 WRX Platinum Silver |
Same turbo i plan on going with in a couple months. Keep us up to date on the tune!
05-03-2007, 08:58 PM | #24 |
Member#: 89818
Vehicle:02 WRX Aztec |
What exactly did you have to do to make it fit on the up-pipe? Is it aftermarket?
05-03-2007, 09:08 PM | #25 |
Member#: 35269
Vehicle:2011 WRX |
SOLD: Blouch TD05H-18G Turbo (2.4" in / 8cm^2 hotside) | guru_method | Engine/Power/Exhaust | 7 | 05-09-2010 04:19 AM |
TD05H 18g 8cm...Thoughts? | cthor | Proven Power Bragging | 49 | 10-15-2009 02:10 PM |
FS in TN: TD05H-18G 8CM turbo | JonR | Engine/Power/Exhaust | 3 | 04-19-2008 09:32 PM |
MY02 WRX TD05H-18G 8cm^2 | Steve.804 | Proven Power Bragging | 9 | 12-03-2007 12:16 AM |
Blouch TD05H 18g - actuator question | WRblueX_Guy | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 08-17-2006 09:02 AM |
