Old 04-30-2007, 09:46 PM   #1
gnarlyWRX
Member#: 97417
11.2 @ 123 25lbs
Default Hybrid misfire on start up
I just put my hybrid in today. We are trying to start it up and keep getting a misfire. The timing is correct and the belt was installed properly. I have Cp pistons, eagle rods, sti HG, pnped heads, crower 272s, ferrea valvetrain, perrin rails, ultimate racing 900cc injectors, and an AEm ems stand alone. any opinions would be helpful. thanks
Ryan
gnarlyWRX is offline   Reply With Quote
Old 04-30-2007, 10:14 PM   #2
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
ign coil firing order ,or inj firing order ? It's kinda easy to flop em around
Good luck
sense of nature is offline   Reply With Quote
Old 05-01-2007, 12:59 AM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
What block? What heads? WHAT CAM GEARS? What wiring system? What EM?
Old 05-01-2007, 01:16 AM   #4
Brydon
Member#: 107569
1998 Forester S
SRP
I'm assuming by his sig that it is a 02 wrx with a ej257 shortblock swap. What map are you using in the AEM EMS? Are you holding Stat sync or getting ignition errors?
Brydon is offline   Reply With Quote
Old 05-01-2007, 07:50 AM   #5
Drink
Member#: 102682
... ripper's
sister.
You are using a light-weight flywheel aren't you?
Drink is offline   Reply With Quote
Old 05-02-2007, 08:05 AM   #6
gnarlyWRX
Member#: 97417
11.2 @ 123 25lbs
well five minutes after i posted i realized that the coil wires were flopped and the car started. the aem is losing sync however. i guess its called Almost Engine Management for a reason. i am running a custom map. my boss is pretty knowledgable with the aem and he put something together. yes i am using fidanza's flywheel. thanks for all the help guys.
Ryan
Old 05-03-2007, 10:15 AM   #7
gnarlyWRX
Member#: 97417
11.2 @ 123 25lbs
just an update. the car is running great. we had some issues with the aem but they look like they are resolved. tonight we are going to do some more road tuning and just look everything over again. i cant wait
Ryan
Misfire all 4 cylinders on start up Ryan314 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-11-2009 09:50 PM
Loud clunking on start up on a gc8 MPowerKai Normally Aspirated Powertrain 2 06-11-2007 12:43 PM
Misfire at start-up after 1 week storage.... KIMUTAKU Vancouver Impreza Club Forum -- VIC 8 12-14-2006 02:36 AM
02 RS misfire at start up DFL2.5RS Normally Aspirated Powertrain 5 11-23-2004 09:13 PM
OBS stumbling and stalling on start-up? Diz Normally Aspirated Powertrain 2 06-13-2001 07:14 AM
