Old 05-02-2007, 09:35 AM   #1
zentrandi
Member#: 130577
03 gga WRX 10' LGT
Both silver
Question Burning clutch smell and slipping
My car is at 85k miles and i bought it used with 2 previous owners at 75K and yesterday my clutch didnt engage correctly at 4th gear, so now i smell this metallic burn so I let it cool overnight. This morning the smell wasnt there, but when i got to work, I could faintly smell it, and as i drove to work, it felt like it was slipping a little in 1st and 3rd mostly and somewhat on 2nd.
So the question is:
Should I think about replacing my clutch?
if so:
Exedy Stage 1 Single Plate Organic Clutch?
or
Exedy OEM replacement Organic Clutch?
I dont have much of a power goal. All i want is stage 2 with AP maybe upping the boost to 15psi max. The car is pretty much stock, minus the resonator, and with K&N filter. But in the future, i want to have a full TBE and catless UP and silicone charge pipe and y pipe.
So if i need replacement, would the OEM kit suffice?
Thanks in advance
zentrandi is offline   Reply With Quote
Old 05-02-2007, 08:31 PM   #2
zentrandi
Member#: 130577
03 gga WRX 10' LGT
Both silver
bump for no answer
Old 05-05-2007, 12:35 AM   #3
gregor2001
Member#: 84443
2012 STI Ltd WRB Sdn
2009 OBS Silver WifeWagon
Sounds like your clutch is shot, Exedy OEM or other OEM replacement is all you need for the mods you mentioned and is the easiest on your tranny.
gregor2001 is offline   Reply With Quote
Old 05-06-2007, 01:17 AM   #4
brine55
Member#: 131644
2002 wrx
psm
yea my clutch began to do the same exact thing and it got worse, i would get the exedy OEM one since its a little less harsh on the tranny and since you have an 03, they are known for not being the strongest, but the exedy should hold more than enough torque then you are planned for
brine55 is offline   Reply With Quote
burning clutch smell after driving 02blkwagn19 Transmission (AT/MT) & Driveline 2 12-22-2007 01:30 PM
Clutch smell and smoke rbailey644 Transmission (AT/MT) & Driveline 0 01-17-2005 12:15 PM
Burning clutch smell, brand new car Balve General Community 5 11-10-2004 03:15 PM
Question for STi owners - burning clutch smell from reverse? avatarr Transmission (AT/MT) & Driveline 13 03-23-2004 09:19 AM
Burning clutch smell dragonglen Baja Forum 3 10-28-2003 11:20 PM
