Old 05-02-2007, 12:30 PM   #1
Legacy
Member#: 10188
2007 Forester XT
Default What do you think of spacers to convert 5x100 to 5x114.3 ?
Someone is selling a set of spacers that will changes the bolt pattern from 5x100 to 5x114.3. They are 5mm so as I understand it this will change the offset to 5mm lower ET48 becomes ET 43.
Is it safe to run these and are there any bad side effects to using them ?
Legacy is offline   Reply With Quote
Old 05-02-2007, 12:46 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...bad-bad-bad-bad idea
and they are NOT 5mm...aint possible
Old 05-02-2007, 12:47 PM   #3
Crawdads
Member#: 30907
SWP GDB-G
Its pointless...the main advantage of the larger 05+ STi bolt pattern is not the wheels, its the bearings and hub design. Anybody who is doing a swap is doing it for that, not for the bolt pattern.
Find some wheels that fit.
Crawdads is offline   Reply With Quote
Old 05-02-2007, 01:22 PM   #4
Daishi00
Member#: 78952
2005 WRX
CGM
It's gotta be somewhere between a 20mm and 30 mm spacer, so good luck getting that to fit.
Daishi00 is offline   Reply With Quote
Old 05-02-2007, 02:09 PM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Avoid it. Get wheels with a 5x100 bolt pattern. "Converters" are just a bad idea for so many reasons.
Old 05-02-2007, 07:38 PM   #6
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
#1 being an additional point of failure.
aerosaaber is online now   Reply With Quote
Old 05-02-2007, 09:16 PM   #7
Legacy
Member#: 10188
2007 Forester XT
Fair enough, just a bad idea. Thanks.
Old 05-03-2007, 09:28 AM   #8
captain spaulding
Member#: 104639
'06 WRX Wagon
Red
It's most def. not pointless.. There are way more wheels available in 5x114.3 versus 5x100, which is probably why the OP is asking this question.
Adapters can be safe(hubcentric, correct bolts, correctly torqued), however with subarus having such high offsets from the factory and adapters usually run about 20mm, you're going to have to find a wheel with atleast ET60 offset in order to achieve an ET40..
captain spaulding is offline   Reply With Quote
Old 05-03-2007, 11:39 AM   #9
Crawdads
Member#: 30907
SWP GDB-G
Trust me, I know how hard it is to find wheels for 5x100 cars...
That being said, I still found them....I even found them with the correct offset to allow me to mount huge tires without even a spacer.
there is no reason to use an adapter when you can buy the correct wheel....its like getting a foot transplant because they don't have shoes in your size...and more than likely the adapters will be so thick that the mad tyte JDM wheels that caused to you use the adapters will no longer fit the car anyway...basically a futile effort...and pointless.
Old 05-03-2007, 01:38 PM   #10
Daishi00
Member#: 78952
2005 WRX
CGM
If you want 5x114.3 so badly just do the conversion.
Old 05-03-2007, 01:43 PM   #11
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
best analogy evAR!!!1111
kennyvb is offline   Reply With Quote
Old 05-03-2007, 02:05 PM   #12
captain spaulding
Member#: 104639
'06 WRX Wagon
Red
Yes, I was just stressing as the wheel bearings are not the only reason to switch to 5x114.3..
What do you think of alacrity024ís tendency to refer to himself in the 3rd person... snvin Off-Topic 46 05-03-2006 03:17 PM
what do you think of my idea to promote fitness? *opinions needed* skimmilk68 Off-Topic 5 11-10-2005 03:37 PM
what do you think of my addition to my subaru family Seeinstars Member's Car Gallery 31 10-13-2005 09:49 PM
What do you think of this 3 gauge cluster? STiMUL8 Interior & Exterior Modification 4 12-29-2004 10:04 PM
Going to get an alignment, what do you think of these specs?? mrtrex Brakes, Steering & Suspension 8 04-28-2003 10:01 PM
