Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-04-2007, 11:06 PM   #1
Idjiit
Member#: 5310
2013 Sonic Turbo
Default How to sort out all the Cat 5 in my home?
So... when we moved in, the whole place is wired with Cat 5, but is only setup for a single telephone line. I want to wire the whole place with ethernet, but am having trouble just figuring out what outlets which wires go to (there's 9 outlets total). The fastest way is probably just to wire all of them, but I don't have enough stuff.
I figured the easiest way would be to just tie off the telephone lines at each jack and test with a multimeter at the other end (reading for Ohms just to complete the "circuit") but... no dice. I'm really not an electronics guy at all, so I figure I'm missing something very obvious... help!
Idjiit is offline   Reply With Quote
Old 05-04-2007, 11:07 PM   #2
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Unhook all of it & use a toner... Ideal Tool #62-140 TRACETONE TESTER
(available at Home Depot)
Unhook all of it, assortment of resistors & ohm each set...
Unhook one, run around the house with a phone & find dead jack.
Unhook two, run around the house with a phone & find dead jack.
Unhook three, run around the house with a phone & find dead jack.
Mark all wires & rehook as needed.
Get help?
GLwagon is offline   Reply With Quote
Old 05-04-2007, 11:08 PM   #3
Idjiit
Member#: 5310
2013 Sonic Turbo
I have no idea what that is.
Old 05-04-2007, 11:09 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Easiest way would be with a tone injector/tracer. Next would be to short a pair on each wire, one at a time, and find the other end with your ohmeter.
edit- too slow.
Old 05-04-2007, 11:10 PM   #5
Idjiit
Member#: 5310
2013 Sonic Turbo
That's what I'm doing, but I'm getting zero results. What ohm range should I be looking at?
Old 05-04-2007, 11:19 PM   #6
Idjiit
Member#: 5310
2013 Sonic Turbo
Tried it again on a different outlet and now it's working.
Hopefully this doesn't mean that the first outlet is ****ed because that's the one I really "need".
Old 05-04-2007, 11:22 PM   #7
WRX2FFU
Member#: 73872
EJ25 ,EJ22,EJ20,EA82
what type of meter are you using?
how many pair is the cat 5? 4 pr?
if i remeber right you only need 2 pair for ethernet(been a while)
Try another pair at the first jack.
WRX2FFU is offline   Reply With Quote
Old 05-04-2007, 11:42 PM   #8
chris84bond
Member#: 51723
Correct.....you would need to do a work around to get this to work though....
I'd just run all new CAT5e....You don't know how old the cable in the walls is right now, and it's fun to crawl in insulation in the summer to wire your house....I did it to mine
chris84bond is offline   Reply With Quote
Old 05-05-2007, 12:37 AM   #9
Idjiit
Member#: 5310
2013 Sonic Turbo
So... I did end up finding it by shorting a different pair. The first the I tried was blue and blue/white which yielded nothing, the second was brown and brown/white which I was able to complete. Just for the hell of it I wired it up to an RJ45, and it worked. Should I just let it be?
Oh, and for rewiring... the wire in this unit is only a couple years old.
Still trying to work out all the grimlins... paintbing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-06-2008 01:13 AM
How to clear out all temp files in WIndows XP? Hazdaz Off-Topic 8 09-15-2006 10:42 PM
My car's finally in the body shop! Selling all the extra stuff in my room - LOOK Cashis Private 'For Sale' Classifieds 17 01-19-2006 05:14 AM
Does anyone know what snails eat, other than all the damn plants in my fish tank? PeterJ Off-Topic 9 10-13-2003 05:57 PM
finally found out what the hesitation is in my car! 01b4RSK Legacy Forum 5 10-09-2002 12:23 AM
