Old 12-17-2001, 09:52 AM   #1
weaversm
Member#: 13391
1993 Impreza L
Agean Blue
Question misfiring problem
I'm the third owner of an '83 Impreza L wagon with 170,000 miles on the odometer. Second owner said she thought engine had been replaced at around 150,000. Anyway, the engine has developed a problem and I need some help, Please! The engine seems to be missing at rpms below about 3000 when it's cold and misfiring at the same when engine warms up. Once I get past 3200 rpm the power kicks back in. I replaced the spark plugs (goodness knows they needed it) and, get this--that seemed to correct the problem for a few days. When it started missing again, I checked the spark plugs and they looked fine. When the engine warms up there is a popping sound coming from behind the engine. Does this mean it is firing late? Any suggestions for this 51-year-old granny? Thanks!
weaversm is offline   Reply With Quote
Old 12-17-2001, 09:54 AM   #2
weaversm
Member#: 13391
1993 Impreza L
Agean Blue
Default Oops! make that a '93 Impreza L wagon!
Sorry! The misfiring problem is on a '93 Impreza, not an '83!
Old 12-17-2001, 10:06 PM   #3
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Try puoring some water on your coil pack. If you see it arcing between the plugm wire's then you need a coil pack. They're around a hundred dollar's and it only take's a ten mil socket to remove it.
Misfire problems fellfrosch7 Service & Maintenance 7 04-26-2005 05:03 PM
Misfire problems WRX98Outback Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-26-2004 03:06 AM
Misfiring problem please help Pochebum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-12-2004 03:54 PM
misfiring problems shortfuseWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-19-2004 08:11 PM
My misfire problem.... solved! 8Complex Mid West Subaru Owners Club Forum -- MWSOC 15 07-16-2001 04:07 AM
